Question about Zenith ZHX-313 System
DVD plays double and black and white
My DVD plays double
I lost my volumen boton and my remote control please i need help
Posted on Mar 10, 2009
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
Will only play DVDs in Black and White
Onkyo DV-CP706B 6-Disc DVD Player (Black) - Amazon.com
www.amazon.com/Onkyo...Player-Black/.../B001AMS...
Amazon.com, Inc.Color: BlackChange .... It's quieter than it was before, and it plays ALL DVDs, even if you can see some visible damage ..... THere was no color-just black & white.
Onkyo dvd player no color only black white Questions ...
www.fixya.com > Forum > Tags > dvd player no color only black white
Onkyo dvd player no color only black white related problems. Ask your Onkyo dvd player no color only black white questions. Get free help, advice & support ...
Onkyo dvd player plays black white Questions & Answer
Dec 29, 2015 | Onkyo Dr-s2.2 5.1 Dvd Home Theater...
My dvd player is hooked up to t.v. but only plays movies in black/white
How is the DVD player connected to the TV? If you are using component video, check that the cables are connected correctly.
If you switch the order on two of the cables, the black and white result is common. So double-check that the red, blue and green connections (RPbPy) have been connected to both devices in the same order. Next try a different set of component video cables, in case one of the wires is damaged.
If possible, try a different type of connection to rule out a damaged input/output. Connect the TV to a different DVD player or the DVD player to another TV, if possible, to rule out similar damage.
Please add a comment with the connection type for additional support. I hope this helps.
Oct 07, 2012 | Vizio L37 Television
Alba dvd/tv combo playing dvd's in black and white
There are a couple of things you could try with this. One, is to make sure that the video input is connected properly. The second would be to make sure that the DVD that played in black and white automatically changed your settings to PAL rather than NTSC
May 13, 2012 | Televison & Video
My dvd player only plays movies in black and white
my dvd player only plays movies back in black and white...not color. why?
Jan 21, 2010 | Cyberhome CH-DVD 300 DVD Player
My dvd player is playing in only black and white. I cannot figure out how to get it to play in color
I have the same problem.My dvd plays in Black And White.I found out A bulb in the tv burned out.The tv will still play color,but any dvd player will play in Black and White.The bulb is $130.00 to 230.00.Hope you have a warrenty like i doo.Thanks Hope ive helped.John from Riverside RI.
Nov 16, 2009 | Panasonic DVD-S35 DVD Player
VHS plays in colour and DVD plays in black and white.
there is a circuit in the color section to put the tv to black and white if the color subcarrier is missing from the broadcast signal.
it is called a color killer and needs to be adjusted.
it is for a technician to do.
it operates off the 3.58mhz color subcarrier.
Aug 18, 2009 | Jwin Electronics JD-VD138 DVD Player
Plays vhs tape in only black and white (no color).
my old series of ROOTS is playing in black and white and says on cover that they are in color
Jul 03, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Dvd plays in black and White
There are a couple of things you could try with this. One, is to make sure that the video input is connected properly. The second would be to make sure that the DVD that played in black and white automatically changed your settings to PAL rather than NTSC.
Jul 06, 2008 | Apex Digital AD-1110W DVD Player
Zenith ZHX-313 System Logo
47 people viewed this question
Top Zenith Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Greg Cann
Greg Cann
Are you a Zenith Audio Player and Recorder Expert? Answer questions, earn points and help others
