Question about Yard Machines 158cc Push Lawn Mower #11a 034f200
Reving too high dosent idol - Yard Machines 158cc Push Lawn Mower #11a 034f200
  • 76 Answers
If the mower is reving up and down it sounds like a carb issue it most likely needs rebuilt and adjusted I would also change the air filter on it after you get it repaired to help keep the carb clean.
Posted on Feb 26, 2009
Johnson seahorse 6 hp
Check to see that you have proper air flow through the cowlling. It sounds like it's not getting enough air to the breather.
Dec 05, 2013 | Boating
1994 ford tempo; vehicle upshifts late, won't shift until 35-40 mph after high reving fro 35 mph, then again at 65 mph after high reving from 55 mph to 65 mph.
Sounds like your transmission is on the fritz. Try changing the fluid and filter see if that helps. If that doesnt try a can of anti slip from any good parts place (Napa). If this dosent help it's time for a rebuild on the transmission
Jul 23, 2010 | 1994 Ford Tempo
It is a 98 kx60 it is really hard to start and it dosent seem to have any power up high or down low.is this because it needs a new top end?
Yes. You need a new top end. Being very hard to start, and having no power, sounds like you have no compression left. You need a new Piston Kit. Wiseco make one for your model.
This is a very high reving little bike, the piston and rings in them dont last very long.
Jun 19, 2010 | Motorcycles
Idol runs fast after starting vehiicle
the idle air control valve is stuck,or there is a vacuum leak.check the vacuum lines,the throttle cable is not sticking and the idle control valve which is on the side of the throttle body and the throttle position sensor.check all the plugs on these for a good connection.
Jul 13, 2009 | 2003 Chevrolet Venture Passanger
Engine stalls
I would start by checking your IAC (idle air control) valve. It is usually located within or near the throttle body. The inpection procedure varies across vehicle makes and years, I would consult a Chilton's (or similar) repair manual for the exact procedure. If such a book is unavailable, you can remove the IAC and check for excess buildup of carbon or other debris. Let me know what you find!
Mar 23, 2009 | 2005 Hyundai Sonata
The car is idoling to high around 2 rpm what does this sound like
ignition time is in adavance so check the ignition time and correct it
Jul 29, 2008 | 1992 Isuzu Rodeo
Ok... chev blazer 2003 is accelerating on its own..
might wanna check ur throtle position sensor
Jun 13, 2008 | 2003 Chevrolet Blazer
Yard Machines 158cc Push Lawn Mower #11a 034f200 Logo
242 people viewed this question
Top Yard Machines Garden Experts
Dwain Pippen
Jim Parker
Jim Parker
Kiltnar
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
