Question about LG enV VX9900 Cellular Phone
LG VX9100 short battery life
My phone does not maintain a charge. When I plug the charger in, it tells me the battery is full, but when I turn the phone on (still plugged in) it dies in several seconds. Off the charger, the phone will not turn on at all. How can I check the charging system to determine whether the problem is the battery, charger or something in the phone's electronics?
  • Anonymous Mar 18, 2009
  • 45 Answers
Probaly only by putting another battery in it, perhaps swap with a mate, failing that you can get one here - LG Mobile phone battery
Posted on Jul 16, 2009
HI my golf buddy will take a part charge but when i turn it on it tells me low battery. This buddy is less than a year old,used 3 times. I charged it on a regular basis. What can we do? Tkx, Mike
Sorry but what you are describing is a defective battery or batteries. The manufacturer's use the cheapest batteries they can get, and some have a very short life span. I suggest you buy a "Battery Tender" that maintains a full charge and monitors battery voltage, the battery is left on this whenever the cart is idle, it will greatly extend the life of the battery even a cheap one. I have provided a link to the product. Battery Tender Plus 021 0128 12V Battery Charger
Feb 08, 2017 | Computers & Internet
My phone SE T303 ran out of battery so i plugged it in to charge, the red light came on. When I came to turn the phone on it didn't work. so i plugged in the charger without the battery inside, then put...
short answer is your battery is dead and needs to be replaced. It is hoped you didn't short out the charging port within the phone itself... It is doubtful but can happen..
Jun 02, 2017 | Sony Ericsson T303 Mobile Phone (Shadow...
My Lg Xenon is not charging properly. It says full battery after i charge it but then when i talk to someone on the phone after about 20 mins it starts beeping saying it has low battery and eventually...
I had a similar problem with a brand new LG Xenon. The battery charger said it was charging but the phone didn't charge. When the battery life on the phone died the phone would not turn on with the charger. I plugged it into my USB port on my laptop and the phone fully charged for real. I got 4 days before I had to recharge it again. Try USB cable to a PC to charge phone. Charger is probably bad. I am getting a replacement and will see if that works.
Oct 21, 2010 | LG Xenon GR500 Cell Phone
LG enV2 Battery not chairging
It might be your charger or your charger port.
First check the charger by using another charger to test if it will charge.
If not charging that means your charging port is faulty needs to be changed.
Jan 21, 2010 | LG enV2 EnV-2 VX-9100 VX9100 Premium Pink...
Phone dies after only texting maybe three or four times even though it was just taken off the charger.
How old is the phone? These kinds of batteries need to be handled with care. Meaning, for the battery life to be high, you must fully charge phone, then use the phone till the battery is dead, then fully charge again. Do not charge if there is still juice in the battery and do not take off charger after only partially charging the phone. This will help maintain the life of the battery.
Sep 10, 2009 | LG RUMOR Cellular Phone
Cannot charge LG EnV2 VX91000 phone
The issue is the charger port on the ENV2 breaks fairly easily.Thefirst step is to contact your carrier to see if it is coveredunderwarranty. If it is, great get it replaced.
If not, you have 3 options:
1. you can get the charging port repaired. The cost is about 50 dollars. I recommend Cellulardr.com
2. you can get a new phone. cost ???
3.You can get an external battery charger to charger the batteryseparatefrom phone. cost about 25 dollars. Check out the following linkforones that are available on ebay. A extra battery is a good idea aswell so you can have one charging at all times.
LG VX9100 ENV2 External Battery Chargers
Hope that helps
Jun 30, 2009 | LG enV2 EnV-2 VX-9100 VX9100 Premium Pink...
Env2 charger wont fit in the hole and wont charge my phone
The issue is the charger port on the ENV2 breaks fairly easily. The first step is to contact your carrier to see if it is covered under warranty. If it is, great get it replaced.
3. you can get an external battery charger to charger battery separate from phone. cost about 25 dollars. check out the following link for ones that are available on ebay. LG VX9100 ENV2 External Battery Chargers
Dec 16, 2008 | Verizon Communications enV2 Cellular Phone
Lg env2 not charging
The issue is the charger port on the ENV2 breaks fairly easily.The first step is to contact your carrier to see if it is coveredunder warranty. If it is, great get it replaced.
3.You can get an external battery charger to charger the batteryseparate from phone. cost about 25 dollars. Check out the following linkfor ones that are available on ebay. A extra battery is a good idea aswell so you can have one charging at all times.
Hope that helps
Aug 04, 2008 | Verizon Communications enV2 Cellular Phone
Correct procedure for charging battery
read da manual which cms wid da battery on hw lng 2 charge it wen newly purchased. charge wen battery is cmpltly drained.smtimz it may refuse 2 chrg so get a universal charger nd alwz use it 2 crg
Sep 06, 2007 | LG enV VX9900 Cellular Phone
LG enV VX9900 Cellular Phone Logo
428 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
