Question about GE GSS20IEM Side by Side Refrigerator
THE DOOR WON'T OPEN TO LET THE ICE DROP MODEL GSS20IEWB WW
ICE WILL FALL INTO THE FUNNEL AND AGAINST THE BACK OF THE DOOR BUT IT WON'T OPEN TO LET THE ICE FALL INTO THE GLASS.
  • ddufour Apr 07, 2009
    The door won't open, the ice will fall down against the door, but the door has to be manually opened. nothing is jamming it. I've cleaned it out. the refrigerator is only 8 months old
  • 686 Answers
Somethin jammed
Posted on Feb 26, 2009
Ice guide seems to be broken, how can i remove the cover to access on mod. ed22tqxfnoo.. what will it take to replace it ?? t
I have a Whirlpool side-side freezer-refrigerator model ED22TQXFNOO. When I try to use the ice dispenser in the door. nothing happens. No noise as if the motor is turning the spiral gear to push the ice to the end of the storage bin so the ice will drop in the shute to be dispensed. I cleaned out the storage bin for any build up of frozen chucks of ice. The storage bin is all the way in. There's plenty of ice, but it won't dispense.
(1) Is there a Micro switch in the lever I push to signal the motor to turn?
(2) What inergizes the switch in the back that lifts the bar to let the ice fall into the ice dispenser?
Nov 29, 2010 | Whirlpool Refrigerators
GE REFRIGERATOR'S ICE DISPENSOR PROBLEM
CAN U TELL ME WHAT YOU DID TO FIX THIS PROBLEM. I AM NOW EXPERIENCING THAT EXACT PROB!
Nov 09, 2009 | GE Refrigerators
Little door that lets ice fall into glass won't
need to check door chute hinge it could be broken
Nov 05, 2009 | Kenmore Refrigerators
Whirlpool side by side ice maker
its possible that ice is jamed in the ice crusher compartment this happens to me as well the ice drops down to fast causing it to clog and then stays open until it all of a sudden you pick it up on the floor thanks from gilles
Mar 15, 2009 | Refrigerators
Ge, tfx26kpda ww, ice maker only dispences crushed ice
At least yours is making ice. Mine wount even make ice. While toubleshooting my prob, I notice a metal rod on the bottom of the ice tray. This rod opens and shuts a plastic "trap door" in the tray. The position of that door determines whether the ice is crushed or whole. If the trap door is open the ice falls through the dispenser freely. If the door this closed the ice is force thorugh metal teeth where it is crushed then dispensed. Open the freezer door and take the ice tray out. You should see a hole at the back of the freezer that the metal rod goes through. In that hole there is a plastic square that moves up and down. If the set your dispenser to crushed ice, leave the door open, push in the door switch at the bottom, and press the dispenser. The plastic square does nothing while the motor is turning. That allows the door to stay closed and forces the ice through the metal teeth. If you set the dispenser to whole ice and do the same thing the plastic square is suppose to lift up forcing the door open and letting the whole ice drop freely. The plastic square probably does nothing even if you set it to whole ice. That mean the trap door never opens focing the ice to always get crushed.
Unfortunately, I have no solution because mine works and I had no need to investigate further. I hopes this helps you figure out the problem though
Good Luck.
Jan 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker - flap won't open, cubes collect in chute
the actuating paddle that you are depressing to dispense ice actually pushes the door open at the top of the dispensor, soundsas if thered an issue withthe actuator arm
Nov 18, 2008 | Frigidaire FRS26R4A Side by Side...
Water in door will not shut off.
most like the dispenser micro switch is stuck open.. it could also be the inlet water valve.. but I could check the switch first...let me know
Sep 29, 2008 | GE GSS20IEM Side by Side Refrigerator
Lg lfx25960 Ice Dispenser
I had the exact same problem on my LG LRSC26940 and was able to fix it fairly easily. First remove the Ice Funnel by pulling down on it. Then remove the entire dispenser panel by getting your fingernails underneath and pulling out. Disconnect the electrical connecter to the front panel PCB. Remove the 4 screws attaching the bracket that the Ice Funnel connects to. This exposes the solenoid that opens the Ice Door flapper. In my case, the electrical connections to this solenoid were bad. I simply scraped the spade terminals on the solenoid off with a screwdriver and crimped the connectors with a pliers. I put it all back together and it is working fine now.
Dec 12, 2007 | LG LFX25960ST Stainless Steel French Door...
Icemaker flap/door does not mechanically open
The description says you have an LG fridge?  I may need the entire model # from the sticker inside the fridge to tell for sure, but there is a motor behind the dispenser controls that opens the door.  Let me know if you need more help.  Also, you can view parts and diagrams at http://www.appliancepartspros.com/.
Oct 21, 2007 | LG LFX25960ST Stainless Steel French Door...
GE GSS20IEM Side by Side Refrigerator Logo
77 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
