Question about Canon MX300 Office All-In-One Printer
Paper jam It tells me I have a paper jam, but I've pulled out all the paper and can't find any other pieces stuck anywhere - yet it still says I have a paper jam.
    Problem Solver:
  • 8 Answers
Have you tried turning the printer off and turning in back on?
Posted on Feb 26, 2009
I get message to pull out jammed paper but I cannot find end of the paper to pull out
Try blowing the printer out with a can of compressed air. Tiny bits of paper will often get stuck in the "eye" of the optical reader that tells the printer that it has a jam. Compressed air can blow this debris loose.
Another thing to double-check is the paper tray. Remove the paper tray and inspect the place where the paper gets pulled into the printer. Sometimes you will find a sheet of paper stuck there that isn't readily apparent anywhere else.
Aug 03, 2015 | Epson PictureMate 500 InkJet Photo Printer
Samsung SCX-4521 "Paper Jam 2" won't clear
Hi there have you tried the door at the back of the machine as there maybe a piece stuck in the fuser unit. If not open the back door and check that there is a small black lever in the middle of the two rollers sticking up as this is the sensor arm that determines that there is a paper jam or not. If this is still there then the paper will be stuck just after the paper cassette within the paper path.
Hope this helps you.
Goodluck,
please don't forget to rate me as fixya..
Feb 01, 2008 | Samsung SCX 4521F All-In-One Laser Printer
I have a 5650 lexmark printer and it keeps saying paper jams but there is not paper anywhere.. how can i find a solution... when you load paper it keepps getting stuck.. help
There could be something blocking the paper path. Try to shake the printer upside down. You'll be amazed of the things that falls off inside the printer. Also, make sure that there's no paper left inside the printer. Tiny pieces of paper will still lead to paper jams.
May 31, 2012 | Lexmark X5650 AllInOne InkJet Printer
My paper won't load - it pulls in about 1/4 of the sheet and then stops. I'm getting error code E3 and have checked for a jam but see and feel nothing. I've also used alcohol to clean the...
This is a paper jam error. Unplug your computer from the AC outlet and from the computer, next place the printer on a table or anywhere that you can get access all panels and the paper tray easily. Remove the paper tray and look for any pieces of paper that may be stuck in the printer. Look also around the back as there is usually a panel that can be removed without any tools.and check there. Also open the printer as if you were going to change the ink and look around there. Make sure you have plenty of lighting or a flashlight as even the tiniest piece of paper can trigger this error message.
Hope this helps.
Jul 17, 2011 | Canon PIXMA MP240 All-In-One InkJet...
Says out of paper when it is not
If you do not see any paper jammed and the machine still tells you there is a jam you should try unplugging the power cable for about 5 minutes. This will let the machine try and clear out any error messages stuck in memory.
If this does not work and you are 100% certain that there is no paper or piece of paper stuck anywhere in the printer then the sensor is broken and you will need to buy a new one.
Hope it helps.
Thanks for using fixya...
Nov 16, 2010 | HP Deskjet 3845 InkJet Printer
I can't see anything in the jammed spot now what?
Thanks,
Pat
Nov 08, 2010 | Office Equipment & Supplies
Paper Jams
Best paper is a about 20lb paper. Make sure you fan the paper to get air between the sheets so it doesn't try to pull multiple sheets at the same time.
Blow out with compressed air (available at office max walmart etc.
Make sure there are no small pieces of paper stuck anywhere in machine
Jan 22, 2009 | Dell A960 All-In-One InkJet Printer
Showing paper jam but no paper in machine help!!!!
please confirm that all paper detecting switches are in normal position and can move freely and no small pieces of torn paper inside-clean all switches with dry cloths or brush.-reset your copier off-on-operation.
Jul 22, 2008 | Office Equipment & Supplies
Paper jam on my brother mfc 8440
It is possible that a small piece of paper is stuck in the paper path above the primary feed roller. It will most likely need to be disassembled.
Jan 16, 2008 | Brother MFC-8840D All-In-One Laser Printer
Canon MX300 Office All-In-One Printer Logo
112 people viewed this question
old marine
old marine
Corne Viljoen
