Question about BargainCell AT&T HTC 8925 Tilt Smartphone Accessory Bundle - 2-In-1 USB Hot Sync Charging Cradle with AC Charger
ATT Tilt Battery Won't Charge
My ATT Tilt got damp... I dried it and put it in a ziplock bag with rice for a day. It worked fine for about a week and then it was time to charge it.... The battery wouldn't charge. The battery eventually drained and wouldn't charge.... it just quit... even when it was plugged into the charger. I bought a new battery and put it in the phone and then I connected it to the charger ... same problem ... the amber light came on and the charging icon appeared. It showed it was charging and I actually saw the percent go from 34% to 33% instead of charging it was using up the battery. So, what do I need to do?
I had the same problem. unfortunately, after several trips to the AT&T store and my office IT department, there's nothing that can be done. the AT&T store suggested cleaning my ports with a small amount of WD40 on a q-tip to clear out any rust that may have formed, so you could try that. If not, get on ebay and buy a spare battery and a charging console (where you can put the battery by itself to charge) and continuously switch them out. its not fun, but that's what i had to do, and i've been doing it for a year now.
Posted on Mar 20, 2009
My boyfriend sprayed cleaner directly on the tv remote and it quit working any suggestions
One could try wrapping it in a ziplock bag with dry white rice for a couple of days and see if that absorbs moisture or trying to dry it with a hair dryer (riskier). This is the sort of device one might wipe off with a slightly soapy, barely damp cleaning cloth or such a cloth with what is called a dielectric cleaner. There is a tiny chance that the cleaner has dissolved a bit of dielectric grease between the battery and battery contacts. If so, replacement of that grease might solve the problem. The good news is he did not spray himself with the cleaner so he still works.
Jan 14, 2018 | Televison & Video
Tip
Don't put your phone in rice, there is a better solution when you drop it in...
Any time did you receive a package or simply when get an electronic device out of the box you see these little bags that say : "silica gel do not eat". Don't discard them, keep them in a very dry place inside little ziplock bags, their mission is to absorb humidity and they are very good at it. When your phone get wet, simply shake it with a towel, then put it inside the ziplock bag and wait until next day.
on Dec 05, 2014 | Cell Phones
How to dry
Put it in a ziplock bag with uncooked rice in it for a couple of days. No guarantee something inside the headset isn\'t already damaged so it\'s a crap shoot if it works again.
Aug 04, 2014 | Motorola Mobility H730 Bluetooth Headset
CORDLESS HANDSET GOT WET,
Dry it as much as you can...
Let it sit in the sun under a towel NOT IN DIRECT SUNLIGHT! if you have a blowdryer with a highspeed/COLD setting, that will help also.
*DO NOT use a heat setting that is too hot for you too hold your hand in front of or you may damage the electronics!
Then if the phone still doesnt work, put it in ziplock bag full of (uncooked/dry) rice and wait until the next day. The rice will soak up the moisture (like those little moisture packets that you find in dried food and stuff that say "don't eat"). It will not ruin the phone, but put the phone in the bag first and then the (dry/uncooked) rice.
*DO NOT shove it in the rice because you could get a grain lodged in a port or something!
Try using enough rice to completely cover the phone. Don't worry about wasting a bag of rice either, you can still wash and cook it!
*DO NOT try to microwave or stick the phone in the oven!
May 27, 2014 | Panasonic KX-TG6051M Cordless Phone
Smartphone submerged in water
Make sure that you immediately remove it from the water and remove the battery and the simcard / memory card from your cellphone. Then towel dry it and put it in a ziplock bag with about a cup of uncooked rice. Leave it there for 1 - 2 days to let the rice absorb the moisture. Then after 1 - 2 days, cross your fingers and try to turn on your cellphone. =)
Jan 09, 2012 | HTC Wildfire Cell Phone
I dropped it in a tiolet, and now the screen is foggy, and the buttons wouldn't work, but now it dosen't turn on.
Take the battery and back cover off the device, put in a ziplock bag (all of the pieces) and fill with rice. Close up and let sit for 2-3 days then put together and turn on. This should dry out the device.
Aug 22, 2011 | Sanyo SCP-2700 Cell Phone
Accidentally soak in fresh water,after drying thru hair blower ,there is power but showing black the lcd
Probably no saving it but there is something you can try. Remove the battery and put the camera in a one gallon ziplock bag full of fresh uncooked white rice. Leave the camera and the rice sealed in the bag for about a week and the rice should absorb any residual water that may still be in the camera.
It is a long shot but it has been known to work.
Jun 18, 2011 | Canon Cameras
A bottle of water exploded in my bag and my ds lite got wet too and now it wont turn on or charge
From what I read online to people that had a DS get wet was remove the battery.... Place the DS in a ziplock bag full of rice. I guess the rices will absorb the moisture left in the unit.. I don't know if this will work ... but it is worth a try.. Most people felt that you needed to leave it in the bag for at least 3-4 days or up to a week.... hope it helps
Oct 19, 2009 | Nintendo DS Lite Console
I dropped my s 7000 fujifilm camera in the water.
Take the battery out and inspect the battery closley. If you see a pink rectangle on the contact face then the battery has to be replaced. You may be able to dry it fully by putting the camera and the battery(seperately) into a ziplock bag half full with uncooked rice. Leave them for a full 2 days and then remove them. Shake the cam and battery as to remove any small pieces of rice that may remain.
Sep 29, 2009 | Fuji FinePix S7000 Digital Camera
I pod got wet wont work
Ipon the ipods case up. then Put the ipod in a zip lock bag full of uncooked raw white rice. seal the bag and leave it in there for 2 days. rice absorbs water. it should dry it up.
dont try to plug the ipod in or it will fry the circuit and you will destroy it.
If you need to know how to open an ipod case go to my website.
http://fixyouripod.weebly.com
Mar 12, 2009 | Apple iPod MA446LL/A MP3 Player
BargainCell AT&T HTC 8925 Tilt Smartphone Accessory Bundle - 2-In-1 USB Hot Sync Charging Cradle with AC Charger Logo
1,737 people viewed this question
Top BargainCell Cell Phones Experts
matt
matt
Jim Goldsmith
Jim Goldsmith
Are you a BargainCell Cell Phone Expert? Answer questions, earn points and help others
