Question about RCA HD50LPW164 50" Rear Projection HDTV
My RCA M61WH185 now keeps shutting off and turning back on without any picture. If I leave it off a while it comes on with a picture for about 30 minutes then cycles through again with turning off and on with no picture. I might have heard a buzzing sound but I cannot be sure.
  • 4,234 Answers
If you can solder, first look for poor solder connections. Resolder any connections that appear grainy or have rings. Please note that there are potentially dangerous high voltages present inside the set even when unplugged. The bottom line here is that either there are bad connections that are causing circuit characteristics changes or there are defective parts. Trying the resoldering is the easiest at this point. Update this with any symptom changes if the resoldering does not completely resolve the problem.
Posted on Feb 26, 2009
Model M61WH185 turn on then shuts back off
it means that you need to take it in or you have somthing hooked up wrong
Nov 02, 2011 | Televison & Video
Replace your LAMP if all of your Fans are running! If lamp fan is not running Lamp will not turn on .Call FOX for Lamp 1-800-227-5369
Jun 20, 2011 | RCA Televison & Video
M61WH185 rca scenium front panel flashes 5 times and no picture
this is the tv's way of saying that my lamp is getting weak or is about to go.
Sep 06, 2010 | RCA Scenium M61WH185 61" HDTV
Television shuts off after 30-45 mins and won't turn back on
Check the solder connections around the flyback transformer for cold solder joints this model is nortorious for bad connection in the HV area. Also check and if need be replace the 5volt supply capacitor on this board also look for puffy tops on the capacitors, replace with same value and voltage ratings.
May 25, 2010 | RCA HD56W66 56" HDTV
RCA D52W20-No Pic-Turns off after several seconds.
You can get the parts at the following link they have both the Red tube and the circuit board for your model. Leave them a email or call they will have what you need.
Jun 21, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Need help
cable connection broke . how can i fix it
Jul 14, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sound but no picture
Sounds as if the lamp has gone out...accordianman
Feb 27, 2008 | RCA Scenium M61WH185 61" HDTV
Rca 52 inch keeps shutting off and picture is curved
The curved picture indicates failing parts in the pin amp section and probably some faulty parts in the scan amplifier sections. The set is being turned off by the uPC because there is a fault indicated, and it is going in to protect mode.
The set will have to be properly serviced.
Jerry G.
Aug 21, 2007 | RCA 32V420T 32" TV
RCA HD61LPW42 runs for an hour then pic goes out for a minute and comes back
sounds like another crappy color wheel issue, just like my samsung hln617w.
Aug 04, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
Televison & Video Logo
102 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
