Question about Microsoft Computers & Internet
Convert in cell
Whar is the formula to convert 1234 in text like one thousand two hundred thirty four,
    Novelist:
  • 121 Answers
Did you try this?
=SpellNumber(A1)
Here is a web site with other solutions.
Website
Have a great day,
ArmyMason
Posted on Feb 26, 2009
Write 139,852 in word form
One hundred thirty nine thousand eight hundred and fifty two
Sep 20, 2016 | Computers & Internet
What extent AC do I requirement to cool my chamber?
The regular is actually 3500 in order to four thousand Btu's associated with air conditioning have to make up for the quantity of temperature created with a one thousand watts lighting. Instance: ten By one thousand watts lamps will need among thirty-five, 000 as well as forty, 000 Btu's associated with air conditioning. Five By one thousand watts lamps will need among seventeen, five hundred as well as twenty, 000 Btu's associated with air conditioning. They are common recommendations because space circumstances, background air flow temps as well as air flow techniques almost all differ.
Oct 04, 2014 | Heating & Cooling
I have to convert 75,893,938 into word form what is the easiestt way to remember how to do this??
Write the first number out( Seventy Five) Then at the first comma write out what it represents (million) Then write out the next number (eight hundred ninety three) then what the next comma represents (thousand) then the next number (nine hundred thirty eight). Put it all together and you get your answer (seventy five million eight hundred ninety three thousand nine hundred thirty eight) its easy if you break it down section by section and remember what each comma represents. I hope this helped you out
Sep 01, 2011 | Office Equipment & Supplies
I NEED MS EXCEL CONVERT FORMULA FOR NUMBER TO CURRENCY
Here is a very popular bit of code from Microsoft that will convert any currency amount in a cell to English words. All code and text from below here is the work of Microsoft.
Summary
This article shows you how to create a sample, user-defined function named ConvertCurrencyToEnglish() to convert a numeric value to an English word representation. For example, the function will return the following words for the number 1234.56: One Thousand Two Hundred Thirty Four Dollars And Fifty Six Cents
The Function Wizard can also be used to enter a custom function in a worksheet. To use the Function Wizard, follow these steps:
1. Click the Function Wizard button, and select User Defined under Function Category.
2. Select ConvertCurrencyToEnglish, and enter your number or cell reference.
3. Click Finish
To Create the Sample Functions
1. Insert a module sheet into a workbook. To do this in Microsoft Excel 97 or Microsoft Excel 98, point to Macro on the Tools menu, and then click Visual Basic Editor. In the Visual Basic Editor, click Module on the Insert menu. In Microsoft Excel 5.0 or 7.0, point to Macro on the Insert menu and click Module.
2. Type the following code into the module sheet.
Function ConvertCurrencyToEnglish (ByVal MyNumber)
Dim Temp
Dim Dollars, Cents
Dim DecimalPlace, Count
ReDim Place(9) As String
Place(2) = " Thousand "
Place(3) = " Million "
Place(4) = " Billion "
Place(5) = " Trillion "
' Convert MyNumber to a string, trimming extra spaces.
MyNumber = Trim(Str(MyNumber))
' Find decimal place.
DecimalPlace = InStr(MyNumber, ".")
' If we find decimal place...
If DecimalPlace > 0 Then
' Convert cents
Temp = Left(Mid(MyNumber, DecimalPlace + 1) & "00", 2)
Cents = ConvertTens(Temp)
' Strip off cents from remainder to convert.
MyNumber = Trim(Left(MyNumber, DecimalPlace - 1))
End If
Count = 1
Do While MyNumber <> ""
' Convert last 3 digits of MyNumber to English dollars.
Temp = ConvertHundreds(Right(MyNumber, 3))
If Temp <> "" Then Dollars = Temp & Place(Count) & Dollars
If Len(MyNumber) > 3 Then
' Remove last 3 converted digits from MyNumber.
MyNumber = Left(MyNumber, Len(MyNumber) - 3)
Else
MyNumber = ""
End If
Count = Count + 1
Loop
' Clean up dollars.
Select Case Dollars
Case ""
Dollars = "No Dollars"
Case "One"
Dollars = "One Dollar"
Case Else
Dollars = Dollars & " Dollars"
End Select
' Clean up cents.
Select Case Cents
Case ""
Cents = " And No Cents"
Case "One"
Cents = " And One Cent"
Case Else
Cents = " And " & Cents & " Cents"
End Select
ConvertCurrencyToEnglish = Dollars & Cents
End Function
Private Function ConvertHundreds (ByVal MyNumber)
Dim Result As String
' Exit if there is nothing to convert.
If Val(MyNumber) = 0 Then Exit Function
' Append leading zeros to number.
MyNumber = Right("000" & MyNumber, 3)
' Do we have a hundreds place digit to convert?
If Left(MyNumber, 1) <> "0" Then
Result = ConvertDigit(Left(MyNumber, 1)) & " Hundred "
End If
' Do we have a tens place digit to convert?
If Mid(MyNumber, 2, 1) <> "0" Then
Result = Result & ConvertTens(Mid(MyNumber, 2))
Else
' If not, then convert the ones place digit.
Result = Result & ConvertDigit(Mid(MyNumber, 3))
End If
ConvertHundreds = Trim(Result)
End Function
Private Function ConvertTens (ByVal MyTens)
' Is value between 10 and 19?
If Val(Left(MyTens, 1)) = 1 Then
Select Case Val(MyTens)
Case 10: Result = "Ten"
Case 11: Result = "Eleven"
Case 12: Result = "Twelve"
Case 13: Result = "Thirteen"
Case 14: Result = "Fourteen"
Case 15: Result = "Fifteen"
Case 16: Result = "Sixteen"
Case 17: Result = "Seventeen"
Case 18: Result = "Eighteen"
Case 19: Result = "Nineteen"
Case Else
End Select
Else
' .. otherwise it's between 20 and 99.
Select Case Val(Left(MyTens, 1))
Case 2: Result = "Twenty "
Case 3: Result = "Thirty "
Case 4: Result = "Forty "
Case 5: Result = "Fifty "
Case 6: Result = "Sixty "
Case 7: Result = "Seventy "
Case 8: Result = "Eighty "
Case 9: Result = "Ninety "
Case Else
End Select
' Convert ones place digit.
Result = Result & ConvertDigit(Right(MyTens, 1))
End If
ConvertTens = Result
End Function
Private Function ConvertDigit (ByVal MyDigit)
Select Case Val(MyDigit)
Case 1: ConvertDigit = "One"
Case 2: ConvertDigit = "Two"
Case 3: ConvertDigit = "Three"
Case 4: ConvertDigit = "Four"
Case 5: ConvertDigit = "Five"
Case 6: ConvertDigit = "Six"
Case 7: ConvertDigit = "Seven"
Case 8: ConvertDigit = "Eight"
Case 9: ConvertDigit = "Nine"
Case Else: ConvertDigit = ""
End Select
End Function
Apr 15, 2010 | Broderbund Learn MS Windows XP and Excel...
Convert numbers to text in excell
  1. Start Microsoft Excel.
  2. Press ALT+F11 to start the Visual Basic Editor.
  3. On the Insert menu, click Module.
  4. Type the following code into the module sheet. Option Explicit 'Main Function Function SpellNumber(ByVal MyNumber) Dim Dollars, Cents, Temp Dim DecimalPlace, Count ReDim Place(9) As String Place(2) = " Thousand " Place(3) = " Million " Place(4) = " Billion " Place(5) = " Trillion " ' String representation of amount. MyNumber = Trim(Str(MyNumber)) ' Position of decimal place 0 if none. DecimalPlace = InStr(MyNumber, ".") ' Convert cents and set MyNumber to dollar amount. If DecimalPlace > 0 Then Cents = GetTens(Left(Mid(MyNumber, DecimalPlace + 1) & _ "00", 2)) MyNumber = Trim(Left(MyNumber, DecimalPlace - 1)) End If Count = 1 Do While MyNumber <> "" Temp = GetHundreds(Right(MyNumber, 3)) If Temp <> "" Then Dollars = Temp & Place(Count) & Dollars If Len(MyNumber) > 3 Then MyNumber = Left(MyNumber, Len(MyNumber) - 3) Else MyNumber = "" End If Count = Count + 1 Loop Select Case Dollars Case "" Dollars = "No Dollars" Case "One" Dollars = "One Dollar" Case Else Dollars = Dollars & " Dollars" End Select Select Case Cents Case "" Cents = " and No Cents" Case "One" Cents = " and One Cent" Case Else Cents = " and " & Cents & " Cents" End Select SpellNumber = Dollars & Cents End Function ' Converts a number from 100-999 into text Function GetHundreds(ByVal MyNumber) Dim Result As String If Val(MyNumber) = 0 Then Exit Function MyNumber = Right("000" & MyNumber, 3) ' Convert the hundreds place. If Mid(MyNumber, 1, 1) <> "0" Then Result = GetDigit(Mid(MyNumber, 1, 1)) & " Hundred " End If ' Convert the tens and ones place. If Mid(MyNumber, 2, 1) <> "0" Then Result = Result & GetTens(Mid(MyNumber, 2)) Else Result = Result & GetDigit(Mid(MyNumber, 3)) End If GetHundreds = Result End Function ' Converts a number from 10 to 99 into text. Function GetTens(TensText) Dim Result As String Result = "" ' Null out the temporary function value. If Val(Left(TensText, 1)) = 1 Then ' If value between 10-19... Select Case Val(TensText) Case 10: Result = "Ten" Case 11: Result = "Eleven" Case 12: Result = "Twelve" Case 13: Result = "Thirteen" Case 14: Result = "Fourteen" Case 15: Result = "Fifteen" Case 16: Result = "Sixteen" Case 17: Result = "Seventeen" Case 18: Result = "Eighteen" Case 19: Result = "Nineteen" Case Else End Select Else ' If value between 20-99... Select Case Val(Left(TensText, 1)) Case 2: Result = "Twenty " Case 3: Result = "Thirty " Case 4: Result = "Forty " Case 5: Result = "Fifty " Case 6: Result = "Sixty " Case 7: Result = "Seventy " Case 8: Result = "Eighty " Case 9: Result = "Ninety " Case Else End Select Result = Result & GetDigit _ (Right(TensText, 1)) ' Retrieve ones place. End If GetTens = Result End Function ' Converts a number from 1 to 9 into text. Function GetDigit(Digit) Select Case Val(Digit) Case 1: GetDigit = "One" Case 2: GetDigit = "Two" Case 3: GetDigit = "Three" Case 4: GetDigit = "Four" Case 5: GetDigit = "Five" Case 6: GetDigit = "Six" Case 7: GetDigit = "Seven" Case 8: GetDigit = "Eight" Case 9: GetDigit = "Nine" Case Else: GetDigit = "" End Select End Function
uparrow.gifBack to the top How to use the SpellNumber sample function loadTOCNode(2, 'moreinformation'); To use the sample functions to change a number to written text, use one of the methods demonstrated in the following examples: uparrow.gifBack to the top Method 1: Direct Entry loadTOCNode(2, 'moreinformation'); You can change 32.50 into "Thirty Two Dollars and Fifty Cents" by entering the following formula into a cell: =SpellNumber(32.50) uparrow.gifBack to the top Method 2: Cell reference loadTOCNode(2, 'moreinformation'); You can refer to other cells in the workbook. For example, enter the number 32.50 into cell A1, and type the following formula into another cell: =SpellNumber(A1) uparrow.gifBack to the top Method 3: Paste Function or Insert Function loadTOCNode(2, 'moreinformation'); To enter a custom function into a worksheet, you can use Paste Function in Excel 2000, or you can use Insert Function in Excel 2002 and in Excel 2003. Excel 2000 loadTOCNode(3, 'moreinformation'); To use Paste Function, follow these steps:
  1. Select the cell that you want.
  2. Click Paste Function on the Standard toolbar.
  3. Under Function category, click User Defined.
  4. Under Function name, click SpellNumber, and then click OK.
  5. Enter the number or cell reference that you want, and then click OK.
Excel 2002 and Excel 2003 loadTOCNode(3, 'moreinformation'); To use Insert Function, follow these steps:
  2. Click Insert Function on the Standard toolbar.
  3. Under Or select a category, click User Defined.
  4. In the Select a function list, click SpellNumber, and then click OK.
Apr 01, 2010 | Microsoft Windows XP Professional
Suppose 1011 amt convert in words like 'One
Hiii
    'Main Function
    "00", 2))
    End If
    Count = 1
    Else
    MyNumber = ""
    End If
    Count = Count + 1
    Loop
    Select Case Dollars
    Case ""
    Case "One"
    Case Else
    End Select
    Select Case Cents
    Case ""
    Case "One"
    Case Else
    End Select
    End Function
    End If
    Else
    End If
    End Function
    Case Else
    End Select
    Case Else
    End Select
    End If
    GetTens = Result
    End Function
    End Select
    End Function
Hope this will solve ur problem
Regards.
G'Day
Sep 10, 2009 | Microsoft Office Professional 2007 Full...
In MS Excel, convert a Number in Text formate
Dear,
you've use macro to this.
Press Alt+F11
it will open Microsoft Vsual Basic Editor.
Click on Module in Insert Menu and paste the following codings:
Function ConvRs(ByVal MyNumber)
Dim Rupees, Paise, Temp
Place(3) = " Lac "
Place(4) = " Crore "
Place(5) = " Arab " ' String representation of amount
' Convert Paise and set MyNumber to Rupee amount
Paise = GetTens(Left(Mid(MyNumber, DecimalPlace + 1) & "00", 2))
End If
Count = 1
If Count = 1 Then Temp = GetHundreds(Right(MyNumber, 3))
If Count > 1 Then Temp = GetHundreds(Right(MyNumber, 2))
If Temp <> "" Then Rupees = Temp & Place(Count) & Rupees
If Count = 1 And Len(MyNumber) > 3 Then
Else
If Count > 1 And Len(MyNumber) > 2 Then
MyNumber = Left(MyNumber, Len(MyNumber) - 2)
Else
MyNumber = ""
End If
End If
Count = Count + 1
Loop
Select Case Rupees
Case ""
Rupees = "No Rupees"
Case "One"
Rupees = "One Rupee"
Case Else
'Rupees = Rupees & " Rupees"
Rupees = "Rupees " & Rupees
End Select
Select Case Paise
Case ""
'Paise = ""
Paise = " Only"
Case "One"
Paise = " and One Paisa"
Case Else
Paise = " and " & Paise & " Paise"
End Select
ConvRs = Rupees & Paise
End Function
' Converts a number from 100-999 into text *
MyNumber = Right("000" & MyNumber, 3) 'Convert the hundreds place
End If
'Convert the tens and ones place
Else
End If
End Function
' Converts a number from 10 to 99 into text. *
Result = "" 'null out the temporary function value
Case Else
End Select
Case Else
End Select
(Right(TensText, 1)) 'Retrieve ones place
End If
GetTens = Result
End Function
' Converts a number from 1 to 9 into text. *
End Select
End Function
save this as as ConvertRs.xla in Microsoft\AddIns folder
now, you'll have to activate this AddIns:
in your Excel Worksheet select:
Tools\Add.Ins...
Check the ConvertRs option
now this will be used as User Defined Function.
you can insert it from the Function Options or just enter the following command in the desired cell where you want the result:
=ConvertRs(Cell Reference)
Cell Reference means where the number is available, you want to convert.
Try this and then tell me the responce.
Bhasker Kumar
Jul 09, 2009 | Microsoft Computers & Internet
Formula for converting currency fig to words
You need to make some changes to the VB script.
here are the steps to guide you
Open Excel - press Alt F11, Click on Insert, Select Module - Copy paste the below mentioned script>>>
Function SpellNumber(ByVal MyNumber, Optional incRupees As Boolean = True)
Dim Crores, Lakhs, Rupees, Paise, Temp
Dim DecimalPlace As Long, Count As Long
Dim myLakhs, myCrores
Place(2) = " Thousand ": Place(3) = " Million "
Place(4) = " Billion ": Place(5) = " Trillion "
' Convert Paise and set MyNumber to Rupees amount.
End If
myCrores = MyNumber \ 10000000
myLakhs = (MyNumber - myCrores * 10000000) \ 100000
MyNumber = MyNumber - myCrores * 10000000 - myLakhs * 100000
Count = 1
Do While myCrores <> ""
Temp = GetHundreds(Right(myCrores, 3))
If Temp <> "" Then Crores = Temp & Place(Count) & Crores
If Len(myCrores) > 3 Then
myCrores = Left(myCrores, Len(myCrores) - 3)
Else
myCrores = ""
End If
Count = Count + 1
Loop
Count = 1
Do While myLakhs <> ""
Temp = GetHundreds(Right(myLakhs, 3))
If Temp <> "" Then Lakhs = Temp & Place(Count) & Lakhs
If Len(myLakhs) > 3 Then
myLakhs = Left(myLakhs, Len(myLakhs) - 3)
Else
myLakhs = ""
End If
Count = Count + 1
Loop
Count = 1
Else
MyNumber = ""
End If
Count = Count + 1
Loop
Select Case Crores
Case "": Crores = ""
Case "One": Crores = " One Crore "
Case Else: Crores = Crores & " Crores "
End Select
Select Case Lakhs
Case "": Lakhs = ""
Case "One": Lakhs = " One Lakh "
Case Else: Lakhs = Lakhs & " Lakhs "
End Select
Select Case Rupees
Case "": Rupees = "Zero "
Case "One": Rupees = "One "
Case Else:
Rupees = Rupees
End Select
Select Case Paise
Case "": Paise = " and Paise Zero Only "
Case "One": Paise = " and Paise One Only "
Case Else: Paise = " and Paise " & Paise & " Only "
End Select
SpellNumber = IIf(incRupees, "Rupees", "") & Crores & Lakhs & Rupees & Paise
End Function
End If
Else
End If
End Function
Case Else
End Select
Case Else
End Select
End If
GetTens = Result
End Function
End Select
End Function
>>>Save it as a file on the computer - Select the cell where you want to insert the function - go to Insert - Function - User Defined - Spellnumber - Select the reference value against my number and type true in incrupees.
It would give the value in Word format.
The limiation is it can be only use in teh same workbook.
Next time when you want to use the formula, either you have to redo the process or use this workbook and copy paste data in another one.
Let me know if you face any difficulty.
Feb 13, 2009 | Microsoft Excel for PC
Need Formula
TEXT CASE
Convert to UPPER, Proper or lower
Auto Convert to UPPER, Proper or lower
Stop VBA Being Case Sensitive
SELECT CASE VBA
Select Case Statement. Great alternative to Else If Statements
CONVERSION
VBA: CBool(),CByt(),CCur(),CDate(),CDbl()Double,CDec(),CInt(),CLng(),CSng(),CStr(),CVar().
Example
dDate=cDate("25-Jan-07")
Convert Numbers to Words
Convert Numbers to Dollar Amount in Words
Spreadsheet Converter. Versions: HTML/JavaScript,Excel ASP.Net and Excel Java/JSP. $
SQL Database Migration $
Converters. Database Converters, Spreadsheet Converters, Text Converters, E-mail Conversion, Document Conversion, PDF Conversion and more! $
CSV Converter $
IMPORTING
Import SQL Into Excel-SQL Tester $
Import Excel Into Access $
CONDITIONAL FORMATTING
Conditional Formatting
More Than 3 Conditional Formats
Conditional Format Fonts for greater than 3
CUSTOM FORMATS
Custom Formats
Excel see a cells format as having four Sections. These are, from left to right: Positives;Negatives;Zeros;Text.
To hide zeros cell-by-cell use a Custom Number Format like 0.00;-0.00; where 0.00 is desired format for non zeros. Note the use of -0.00 for negatives.
To hide zeros on the Workbook level go to Tools>Options>View - Zero Values.
Dec 15, 2008 | Microsoft Windows XP Home Edition
Help me solve
1. Four Hundred Seventy-Eight Ten Thousandths
2. One Thousand Four Hundred Thirty Five Ten Thousandths.
3. Three Thousand Two Hundred Five Ten Thousandths.
4. Four thousand Seven Hundred Eighty Four Ten Thousandths.
5. Four Hundred Ninety Seven Ten Thousandths.
OR
1. Zero point zero four seven eight.
2. Zero point one four three five
3. Zero point three two zero five
4. Zero point four seven eight four
5. Zero point zero four nine seven
Thanks and please take a moment to rate as fixya.
Jul 06, 2008 | Audio Players & Recorders
Computers & Internet Logo
32 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
