Question about Sony STR-DE625
SONY HT-DWW1600. WHEN GETS NICE AND LOUD TURNS ITSELF OFF AND SAYS PROTECT ON THE DISPLAY. HELP!!!!!!!!!!!!!!!!
  • 121 Answers
It is getting too warm and shutting down to protect itself. This could be caused by insufficient ventilation or by shorted speaker wires.
Posted on Feb 26, 2009
Fan check blinks on the display and then shuts the system off?
Can you see or hear if the fan is running? Is there sufficient clearance (4 inches) between it and the nearest surface for airflow? Is it clogged up with dust bunnies? You may be able to fix it yourself.
Unplug the unit. Look inside the vent at the rear. Reach in with a non-conductive probe to see if the fan turns freely. If not, it's bound up and needs replacement or unclogging.
If it turns freely with power off but doesn't rotate with power on, it's dead.
If it turns sufficiently fast with power on and you still have Fan Check, it's a sensor.
Resolve this issue and it will probably stop trying to protect itself by shutting off.
Feb 14, 2010 | Samsung HT-WX70 Theater System
Samsung HT-TZ312 shows "protect" and it turns off
A short on the speaker wires can cause this but most likely your amplifier bias is off or you have a shorted transistor.
First unplug all connections, even the power. Let it sit for a minuit then power it back up.
If it clicks off them it needs professional service.
If it turns on inspect all of your speaker wires for shorts them reconnect them one at a time.
Hope this helps,
Cheers
Feb 03, 2010 | Samsung HT-TZ312 Theater System
SONY HT-5500D PROTECT IS FLASHING NO SOUND
Protected in short means that the amp is no longer powering the speakers due to one of the following: 1. Volume is up too loud 2. Equipment Failure 3. Dirty power
Turn amp on by pressing the function button on the remote of a source that has nothing on it or is not powered on. If it still says PROTECTED even though you are on a source with no sound coming in, then the equipment is in need of repair. If it simply comes on normal displaying the source turn the volume down till it says MIN. Find the range of your speaker and amp power by selecting a source with music or movie audio and slowly turn it up till either its too loud or says protected. Be sure to double check all speakers and wires to ensure wire integrity as well as proper connection.
Jan 11, 2010 | Sony HT-5500D System
Samsung hiome cinema protect error message
you need to change 5q tranzistor.if you dont have short circuit on pin 9 to ground on flat who comes from amplifier
Aug 04, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
PROTECT DISPLAYED ON RECEIVER
This generally means you've got a short somewhere, and the received is trying to protect itself.
My suggestion is to disconnect all of your speakers at both ends, and reconnect them.
Most times this happens because a speaker wire is lose, and the positive and negative connections are touching each other, causing it to short out.
Mar 24, 2009 | Sony STR-DE485 Receiver
Samsung ht-tz212 protect!
resistor smr60 is 470r / 470 ohm
Nov 08, 2008 | Audio Players & Recorders
Problem "protect"
Hey guys, just had the same problem and found out it was because I had disconnected the central speaker. This it was creating a back impedance or something and reonnecting did the trick! i.e. check your speaker connections and check that they work... duff speakers could cause the problem too!
Sep 20, 2008 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
Protect push power
hi, everytime i switch on my sony hi fi it the display screen says protect push power. It won't let me do anything not even put cd's in. If you could help that would be very much appreciated.
Jun 12, 2008 | Sony LBT-XGR6 CD Shelf System
Surround sound keeps shuting off
the system go to protect mode in case of trouble in output stage(power output component and cords and speakers.
try to connect each speaker one by one until you find the bad one change cord first for the bad one and check if not working you must change speaker itself.if all above does not solve the problem you must pass your sony to service center
Mar 23, 2008 | Sony HT-DDW700 System
Protection mode keeps kicking in
This happens less often in "normal surround" mode
Apr 01, 2007 | Sony STR-DE485 Receiver
Sony STR-DE625 Logo
106 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
