Question about Jura Capresso C3000 Espresso & Coffee Maker
Capresso C1300 LCD stays on stating "Hot water cycle necessary"
Jura-Capresso C1300 machine will not make coffee. UNIT GOT STOCK IN THIS STAGE DISPAY READ: HOT WATER CYCLE NECESSARY. UNIT DOES NOT MAKES COFFE UNTIL THIS STAGE PASSED. Is there any solution to this?
I had one that set for 6 months that had that problem. Air had gotten into the water lines. Opened the hot water tap a few times and then removed the end of the water line that runs from the solenoid to heater block to at the solenoid end to bleed air out. It could also have been some calcium deposits that blew out with the air blocking the line. Then I replaced the end of the line, powered the machine up and it worked normally. Note: Jura Capresso and Capresso machines are complicated and it takes some mechanical know how to open them up and service them. They also have four special screws on the back that requires a special tool to open
Posted on Dec 24, 2013
SOURCE: jura capresso
The dial on the upper right is all you need to do. Turn from the coffee cup to the water symbol. Water will pour out the spigot from the frother wand so put a cup under it. Close the tap when prompted by turning the dial back to the cup symbol
Posted on Dec 21, 2007
SOURCE: Jura Capresso Problem
check out this link:
http://www.kuntze.de/E/index.htm
Posted on Dec 30, 2007
  • 6 Answers
SOURCE: My Jura Capresso C1300 reads Need Hot Water Cycle
*** in the pipes
Posted on Apr 15, 2009
EsWorld
  • 1618 Answers
SOURCE: my jura capresso says system fill...it makes a lot of noise
System fill is usually when the machine auto solenoid fill valve is putting water into the boiler. If it is making noise then the solenoid is clogged or there is no water getting to the solenoid.
Posted on Jun 18, 2009
  • 10 Answers
SOURCE: Need an "O" ring Jura Capresso C1000
ebay has them
Posted on Nov 22, 2009
My Capresso s8's display is blinking and making strange noise
All Jura machines in the series C, E, F, J, S & Z models have the same problem. The Jura recommended maintenance is insufficient or erroneous:
1- When new machine is set up, the owners click OK for use of Filter cartridges. This helps only to display reminders for replacing the filter.
2- The instruction also advises, regular use of Filters, eliminates descaling the machine. That is not accurate. Reminders for descaling are delayed or eliminated. This allows accumulation of Calcium deposits in the entire hydraulic and coffee system.
3- Cleaning tables recommended & sold by Jura do not remove Calcium deposits in the coffee/water passages. The automatic descaling method recommended by Jura also leaves the coffee side of the machine unclean. The error message in your machine is due to Calcium deposits in the Brew group, coffee outlet & the faucet dispensing coffee in the cup. I suggest all Jura machine owners should manually descale machine. Manually descaling includes use of 6 to 10 rinse cycles with descaling solution in the water tank. The error message "Clean Machine" is accurate & pointing to descaling the Brew group, coffee outlet tube and coffee dispensing faucet by using rinse cycles.
After the rinse cycles are complete, refill Descaling solution & continue descaling the rest of the machine using hot water dispensing function, until the tank is empty. Finally, give a final flushing of machine to flush out remaining descaling solution inside the machine.
Services Unlimited Inc Parts Guru Since 1988
Sep 23, 2016 | Jura Capresso Impressa S8 Coffee Maker,...
Turning dial after choosing strong, we want 4 oz, but turning dial toward 4 it may goe to 5 and then up to 7 down to 6, up to 8, etc.
Operating Manuals - Jura Capresso Coffee Machines
capresso.125west.com/html/operating_manuals.html
Operating Manual Impressa F9 and F9 Limited Edition. Operating Manual Impressa F7. Operating Manual Impressa E8. Capresso C1300 Superautomatic ...
Sep 06, 2015 | Jura Capresso Impressa E8 Espresso/Coffee...
Capresso c1300
Just a guess here but if you are not using soft water you may have a hard water scale coating on the sensor. The sensor is preventing the heating element from powering up because it thinks there is no water. Try filling the machine with vinegar for several hours (no more than overnight) This will dissolve hard water deposits and hopefully clear the sensor. (the sensor should be a simple continuity contact. If you can look inside and see a metal button and it is fouled clean it off.)
Aug 31, 2014 | Jura Capresso Coffee Makers & Espresso...
I have a jura capresso S7. I am finding water in
This is normal, after each cycle the brew unit will empty the drainvalve for excess water, this will ensure that the water used for each new cup is fresh from the watertank.
Jul 14, 2009 | Jura Capresso Impressa S90 Espresso...
Jura capresso z5 not working
Call Nick or Anthony at Style Cafe on 0844 2279229 they have a wealth of knowledge on these machines and can Service them if required
Jun 11, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
Capresso c1300
I believe you have to go through the steps of running a hot water cycle which is on page 9 of the owners manual, 7.1 listed under "FIRST TIME PREPARATION" A. through F. If you don't have the manual, send me your e-mail and I can send it to you.
Feb 12, 2009 | Jura Capresso C1300 Coffee Maker, Espresso...
My dispay on my jura E8 says error 5.
Simple fix - got the machine serviced, needed a new thermoblock apparently, could also have been one of the couple of sensors they replaced. Total cost including box, bits and carriage - £180 plus change.
Expensive but now I have it back, it all seems worth it!
Nov 30, 2008 | Jura Capresso Impressa E8 Espresso/Coffee...
Jura Capresso C3000 Espresso & Coffee Maker Logo
571 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Colin Stickland
Colin Stickland
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
