Question about RIM Blackberry 8310 8320 8330 Curve 8100 8110 8120 8130 Pearl Car Charger / Veh
Curve 8330 has a trackball issue
It wont scroll down but it will all the others. how do i take it out to clean it
  • 152 Answers
Good evening!
Removing (or replacing) the trackball on the Blackberry phone is very easy.
Shut off your blackberry phone (I would take out the battery).
Quickly examine the trackball itself on your phone. Use something with a small tip, like a screwdriver (NOT A KNIFE! Could damage the mechanism), and slide it underneath the silver ring around the ball. Gently lift up, might also want to try lifting both sides to help lift it off.
Once off, set aside the silver ring. You should now see the trackball mechanism, to remove it, simply flip the phone over and it should just fall out (can also tap it a few times which helps). The mechanism is simply held in magnetically.
You should now be able to see where the trackball was. You can now take a cotton swab with a small amount of rubbing alcohol and clean around in that area. If you examine, you will see small rollers around the trackball, you can also clean these.
This is the best way to clean the trackball. If all else fails you can replace the trackball. You can order one off amazon, they are very cheap, ranging from $2-10.
To put in the trackball, simply reverse the steps. The trackball device only goes in 2 ways, if it simply doesnt fit, turn it. It requires minimal force to put it back in. To put the silver ring back in, just match up the 3 little clips and gently push it back in.
Put the battery back in and give it a test.
Hope this helps!
Posted on Apr 06, 2009
Blackberry curve 8330 keyboard and trackball doesn't work
Your trackball and the keyboard seems not working. You may need a replacement for both parts.
Jun 17, 2017 | RIM BlackBerry? Curve 8330 Cellular Phone
DOESN'T SCROLL DOWN
2 things are going on here. Either your trackball is really dirty or is broken. It is pretty straight forward process to clean or replace.
Clean Blackberry Curve 8330 Trackball
Jun 14, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
Blackberry Curve 8330 trackball
Under screen/keyboard option there is an area for trackball sensitivity both horizontal and vertical...Increase both and you should be fine.
Aug 19, 2009 | Cell Phones
Got my trackball a bit wet and now wont work, what should i do?
You might have damaged some circuitry, but can try cleaning the trackball with alcohol and a Q-Tip. You need to roll the ball around with the alcohol-soaked Q-Tip, then let it try. This will have the nice side effect of helping drive off any leftover water, too.
Aug 13, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Blackberry 8330 won't scroll
Blackberries really takes time to load specially on a reboot mode...i suggest to remove the lock of your trackball and clean it with a denatured alcohol specially the trackball underneath then place it back... that will solve your problem ..if everything elsa fails then have it replace
Jul 11, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Trackball want scroll down
Please change the sensitivity, to change the sensitivity follow the below steps
  1. select option in the main menu
  2. select Screen Keyboard
  3. set the horizontal/vertical sensitivity as 100%
May 16, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Trackball fell out of my blackberry curve. I need to scroll down. Is there an alternative method?
You have to have the trackball, there is no other way to scroll. You can probably get one from your local phone store.
May 13, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
CUrve 8330 having trackball error
Hi
It seems that there might be something blocking it, like dust, press the trackball down and then try to scroll quickly towards the bottom, try it a couple of times, it should fix your problem
David
CellUnlock.net
Feb 26, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
RIM Blackberry 8310 8320 8330 Curve 8100 8110 8120 8130 Pearl Car Charger / Veh Logo
1,379 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
