Question about Acer TravelMate 4200 Notebook
Sound working but altered higher frequency range
Headphone output and built in speakers all sound the same.
Hardware or software?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 94 Answers
It has something to do with the hardware.
Posted on Feb 26, 2009
No sound on my technika 42" 3dtv
If the headphone jack socket works the audio output for the set is good, I suspect a dvd etc will also work if connected to the rear input audio and video jacks.
This does not leave too much, headphone jack dirty or defective, speakers for whatever reason are switched to off in the main menu.
the sound for the headphone socket if it is built into the set is the same audio going to the speakers.
Dec 05, 2012 | Televison & Video
250W, 8 Ohms speakers on 150W, 6-16 Ohms Amplifier.. What is the effect of this?
If your amp states that it will support a range of 6 - 16 ohms, an 8 Ohm speaker will work fine on it. If the speakers you hook up to it are lower than 6 ohms, it may work until you turn it up, then it will either shut down or burn out the finals. If you hook up a speaker that has a higher than 16 ohm, it will not get very loud, and it shouldn't hurt the amp.
Feb 14, 2012 | Concept Car Audio & Video
The speaker of my computer doesn't work even the headphone what do you think the problem is?
1. Check the mute button - some computers have a hardware mute on the case. Also check the software mute button.
2. Check you default sound output device in the sound or audio control panel. Which device is the default output device?
3. Does windows "chime" when it starts?
Jul 04, 2011 | Computers & Internet
Im tryin to hookup aftermarket subs but the lineout converter isnt working, it sounds like alot of treble comin outt of the subwoofers. is there anyway to find a low frequency wire to tap into for the subs
instead of finding a low frequency line to attach to your LOC (line output convertor) use the built in crossover on yours subwoofer amp or an external crossover to limit the frequency range going to the subs
May 07, 2011 | Car Audio & Video
Where on my mixer should I plug the subwoofer into? Or would plugging it in somewhere else be better ?
This will depend on whether your sub-woofer is powered (has it's own built in amplifier) or not. If it is not powered it will need connecting to an amplifier. If it is powered you will need a line level output either on the amp or the mixer.
Many modern amplifiers (and some mixers) have a dedicated output for sub-woofers in which case this is the best place for it because the higher frequencies will have been filtered out.
Some high quality amplifiers like the JAMO MPA 101 have a filter switch and adjustable filter level for powering sub-woofers. You then just connect the speaker to the speaker terminals in the normal way.
Otherwise on a p.a. mixer you could use the main output, one of the auxiliary, monitor or sub-mix outputs. If you are not using the main output you will need to route signal to the appropriate output accordingly. Either way your output signal will cover the full frequency range - your subwoofer may have built in filtering or you may need to use some sort of crossover to split the signal between the sub-woofer and the rest of your speaker system.
Feb 25, 2011 | Audio Players & Recorders
How to connect sansui HT 2501 5.1 home theater to pc
In general, the PC's soundcard and video capabilities will determine the answer to the question. And which direction you want to run. Is the PC a source or the end-unit or both? Your PC hardware and software documentation would describe various scenarios.
The PC is a common source of audio. Any PC should have a minimal headphone output, which would be functionally the same as the analog L/R speaker output. Simply adapt the cables for RCA connection to your audio system, get into yourt PC's sound controls (usually proprietary), max out the volume and set its output for something like FULL range speakers.
Run it to any available Line Level input on the HT.
Digital outputs, same same.
Sending sound TO the PC will depend on IT and the software it uses.
Jan 13, 2011 | Sansui Audio Players & Recorders
Hdmi audio not working when conected to tv
Follow these steps to change the audio output settings for the HDMI option.
  1. Follow steps 1 through 8 above.
  2. From the Windows Vista™ default Start menu, click Control Panel.
    View Picture
  3. In Control Panel, using the default Control Panel Home setting, click Hardware and Sound.
    View Picture
  4. In the Hardware and Sound window, under Sound click Manage audio devices.
    View Picture
  5. In the Sound dialog box, click to select Digital Output Devices (HDMI).
    View Picture
  6. Click Set Default, and then click OK
    View Picture
Note: The default audio setting for your notebook is Speakers / Headphones.
You must change the audio output back to the Speakers / Headphones option for the computer to once again be able to use the internal speakers and headphone jack.
Sep 24, 2009 | Gateway T-1620 Notebook
No sound at laptop speaker but audio output is ok
I have lenovo notepad 3000n100 with winXP sp2.
I downloaded realtek audio from ibm site and installed.
Now sound is coming at my output port but the in-built laptop speaker is not giving any sound output.
The hardware is ok as the sound was coming at in-built speaker before formatting. The previous audio driver set up file i have lost.
Plz help.
Apr 16, 2009 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
Technical spec for plantronics C60 headset
Plantronics CS60
Type: Headphone
Acoustic Seal: Sealed/Closed/Sound Canceling
Headphone Frequency Response: Hz
Headphone Sensitivty: 14 dB/1mW dB/1mW
Wireless Technology: Infrared
Battery Time: 9 hours hours
Battery Type: Alkaline
Radio Frequency Range: 1.8GHz
Transmission Range: 100 m.
Compliant Standards: TCO '07
Jan 16, 2009 | Plantronics CS60 Professional Headset
Aiwa cx na555u
Dear shelnaaqua,
Please connect the headphone to your system and check the sound quality,If it sound good then the connection of the speakers are not ok. This system has HI & low frequency output. Connect woofer to LOW frequency output and tweaters to HI frequency.
please take trouble to vote for me if this solve your problems
ramesh22
Jun 07, 2008 | Aiwa NSX-A505 CD Shelf System
Acer TravelMate 4200 Notebook Logo
24 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
