Question about Kenmore 63942 Dryer
Kenmore Model 110.76912691 gas dryer that heats intermitently
I have a Kenmore Model 110.76912691 gas dryer that runs well, but has intermitent heat. Sometimes it works and sometimes it does't. Any suggestions?
  • 135 Answers
Replace the solenoids on the gas valve. These are often intermittent befor total failure. Hope this helps!
Posted on Feb 26, 2009
Dryer not drying
check venting 1st ,
or run it with the vent disconnected do you feel good air flow
electric or gas model.
May 19, 2014 | Whirlpool WTW4950XW Washer
Service center in dubai
You didn't mention if it was gas or electric, model number, etc.
Apr 18, 2014 | AEG Dryers
Lg dryer dlg5966w wont heat, smells like gas in the drum
I have same problem. I have tried everything. Even new control board. It only intermitantly does this. When it fails to light it pumps raw gas. Only thing to try next is new ignitor.....
Jul 17, 2012 | LG D5966 Gas Dryer
Electronic moisture sensing Kenmore stackable dryer, smells like gas when it runs only. Heats up. I opened it up and looked in back, I can see a red glow then it shuts off, kind of intermitant. Whats...
This is usually caused by lint on the heating element, You should have it cleaned out by an appliance person or if you feel comfortable you can unplug the unit, remove the back panel and try cleaning it out your self. you should also try cleaning as much as possible from behind the lint filter inside the drum. Hope this helps.
May 05, 2011 | Dryers
Dryer heats intermitantly and smells like gas when it doesn't get hot . Is this a bad igniter issue?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 01, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Hello I have a Kenmore gas dryer model# 1107282210 and the dyer seems to give off a little heat but then I it will stop giving of heat and the clothes will take very long time to dry. Now I cleaned the...
HI, Check the following to address this issue further.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task. The blower housing should be disassembled, and cleaned in this case.
2. Thermostat(Secondary Cause)- Highly unlikely in your case, but possible
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat. These thermostats are located in the dryer vent duct and sometimes mounted on the blower assembly as well.
Dec 17, 2009 | Kenmore 73952 Gas Dryer
Dryer not drying
On gas dryers an intermitting heat problem is almost always the coils on the gas valve. http://www.appliance-repair-it.com/
Sep 18, 2009 | Dryers
Some times heat works but mostly cold. goes back and forth
Check that the vent pipe is not totally or partially restricted as it discharges from the house
Is this a gas or electric dryer?
Please reply with specific model number and any further questions.
Jan 19, 2009 | Dryers
Intermitant dryer heat
i have found that in some model of the kenmore the wire going to the plug on the motor is lose on the conection since the power for the heat runs throw the cintrafugl switch it happens
Mar 18, 2008 | Dryers
Kenmore 63942 Dryer Logo
210 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
