Question about DEI Python 1400XP Remote Start/Keyless Entry System
Remote starter wont work
I installed a remote starter on my 94 nissan altima today. The remote start wont work and the power locks and stuff do. It says i need to program the tach on the unit so it knows the vehicle is running. I cant get the darn thing to go into to program mode. Its an auto start brand model #AS-1535 SH. Im not sure whats going on but if someone can please help me i would really appreciate it.
    Problem Solver:
  • 5 Answers
There are a number of things you need to check.Make sure you have all of your voltages,acc,ign,constant12v.Make sure you have a good tach signal.On the Auto start brands a goood ground is needed.make sure your brake wire is connected.If there is a nuetral saftey wire,please connect it to ground.
Posted on Feb 27, 2009
  • 95 Answers
Just read over the tach learning procedures for this. Are you sure your hooked up to a good tach source. My notes show its the green wire at the coil. Check your connections and let me know if there good.
Nissan Altima 2000 Manual. Recently had remote starter installed and was working fine for a few days. This morning I remote started the vehicle and when I came out car was off. Try starting the car up...
the remote starter is not going to damage the starter, but if wired wrong it could damage the wiring or fuses, or run the battery down from a short.
Jun 11, 2017 | Nissan Altima Cars & Trucks
My 1995 nissan altima wont start, it has power but wont do anything when you turn the key. What could be the problem?
I am assuming that the starter will not crank over when you turn the key.It sounds like the starter solenoid is toast.Get a meter and see if there is power to the solenoid when you turn the key.It will be the smaller gauge wire .If you have power to the solenoid and you get no cranking then you will have to replace the starter(they are one unit)
Oct 03, 2010 | 1995 Nissan Altima
1993 Nissan Altima The security light is blinking and the car wont turn over. it has a good battery. Is the flashing security light preventing the car from turning over?
Yes, the security system shuts power to the starter and fuel pump. You can try disarming by unlocking and locking the doors the power door locks switch (depends on model). Place the key in the ignition and set to ON, ALL doors closed!! Cycle the locks using the power locks button on the driver's door "lock" then "unlock" if this doesnt work, try same method with the ignition OFF. Otherwise your security system is malf.
Sep 26, 2010 | 1993 Nissan Altima
94 Nissan Skyline ignition wont turn with key in. It is in park
hi this may because the wire connecting the ingnition switch may be damaged so there is no signal going to starter. so please replace the ignition switch and try starting it
Jul 11, 2010 | 1994 Nissan Altima
I got the rs1100e in a 94 nissan altima the keyless entry don't work the lights flash when i push the button but the locks do nothing?
its the problem in the wiring connection or the battery is got weak in rs1100e .check out the connections again.for more detailed help please click on the link directly http://www.bulldogsecurity.com/pdf/ModelsRS1100_1100E_114.pdf This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Mar 04, 2010 | Remote Starter with Keyless Entry
94 nissan power windows not working
I had a 94 nissan altima, If anything powered is not working there is a good chance that the quick connect clip in the drivers side door is loose or off completely. If this is the case, you'll just have to remove the drivers side door panel and reconnect the clip, but before you do that i recommend you check your fuse box. The reason I mentioned the clip is because mine fell off from time to time.
Dec 14, 2009 | 1998 Nissan Pathfinder
My 93 altima started yesterday just fine.Willnot even turn over today,there is power ,not even clicking. Checked fuses ,battery,moved relays around not sure how to check them
there is whats called a fuseable link on the + side of the battery taht may have burnt out over time!
bst get a auto electrician or a mechanic to come over & test it for you
Good luck Cheers Rob.
Jul 20, 2009 | 1993 Nissan Altima
My nissan sentra 95 wont start and its not the starter
it sounds like a starter kill relay was installed on your nissan, if there is a relay in line with the black/yellow or black/blue starter wire under your dash you may need to bypass it, or you might need to reprogram your remote to close the relay when you unlock your doors
Jul 15, 2009 | Bulldog Remote Starter & T-Harness Kit for...
94 nissan altima GXE keyless option
Any vehicle can have keyless entry installed as long as the car has power door locks.I would recommend the viper aftermarket keyless entry. It works very well.
May 14, 2009 | DEI Python 1400XP Remote Start/Keyless...
DEI Python 1400XP Remote Start/Keyless Entry System Logo
454 people viewed this question
Top Directed Electronics Vehicle Parts & Accessories Experts
Kevin Daniels
Joe Taylor
Joe Taylor
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
