Question about Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark X1185 printer driver for vista downloaded, wont install
I have a Lexmark X1185 that worked fine on XP. tried to load the driver on Vista from disk. Printer would not work. went to Lexmark web site. advised printer would work on vista, but not with old driver on disk. uninstalled and downloaded correct Vista driver. When I try to install downloaded driver it says older version of driver detected. click uninstall (says successful) then restart and try again. when I do I get the same message.
  • JDOLLAR5 Mar 01, 2009
    CANNOT GET PRINTER UPGRADE TO DOWNLOAD ON VISTA
Lexmark will not work with vista but worked with my xp. what can i do?
Posted on Mar 05, 2009
When i bought a new computer with Vista I had to go to the printer's website and download a new version of the driver for the printer in order to make it compatible.
Posted on Mar 02, 2009
    President:
  • 2,692 Answers
Uninstall the whole printer throught the control panel.
Posted on Feb 26, 2009
I am trying to reinstall the All-in-one software. I get to the languages box and after that nothing. Keeps telling me no software installed I got windows 7 and it worked fine until recently.
Please use the Vista driver in Windows 7. First, check if your Windows 7 is running on 32-bit or 64-bit system type. Go to Start menu > right-click on Computer > Properties. Take note of the System Type.
To download the printer driver, use the links below; - Lexmark X1185 Driver for Vista/Windows 7 32-bit - Lexmark X1185 Driver for Vista/Windows 7 64-bit
After downloading, execute the file and follow the instructions on your computer screen.
Jun 16, 2011 | Lexmark JetPrinter X1185 All-In-One InkJet
Printer Lexmark X1100
Drivers for Lexmark X1100 in vista should be built in, in any case I will try to find a download.
Mar 15, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Printer wont install to laptop
hi... if u don't know the lexmark tech support #... its this: 1800 332 4120... or u can live chat online on support.lexmark.com
if u r the do it yourself type... go to www.lexmark.com. in the search box on top right corner type "x1185". click search. scroll downwards & click on download driver & select windows vista. before u start download check whether urs is vista 32 bit or 64 bit. right click on computer entry in start menu & click properties. check what it says there under operating system type: 32 bit or 64 bit. if its 64 bit... download vista_x64 driver from the lexmark site else select just vista. after download... comes the long process of installation which would take even more instructions. i think u can just call the tech support & it will be a first call resolution
May 21, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark x 1185 on windows vista
hi you can get the drivers from lexmark site here Windows Vista --
if you need em for download
riz.
Apr 25, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Communication problem with notebook/printer
You've encountered 1 of the many issues with Vista. The OS is so gargantuan that Microsoft had to ax many of the drivers that were included with XP.
http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_1019285789_0_en,00.html
Copy & paste the above URL into your web browser & that will take you right to the driver download page. Select the red highlighted "Driver Download" for the 1200 series printers. This will send you to the Operating System selection page. Once selected you'll see the red highlighted .exe file. Select "download now". You should see a pop-up asking you to save the file. I like to send downloads to the desktop to facilitate installation of the software. You can later drag & drop it into whatever folder you like.
Make sure to remove the XP drivers before installing the Vista drivers. Also remember to unplug the USB cable from the printer prior to installing the Vista drivers. The installation software will prompt you when to re-install the USB cable.
Good luck.
Feb 28, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
icannot conect my lexmark x1185 to my compaq vista
Jan 07, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Printer won't print
vista doesn't like non-microsoft software. It will tell you that the lexmark software is not supported. Click install anyway. Do this before plugging in the printer or vista will assign it's own driver. Which wont work. Then go into the control panel and select the lexmark as the default printer
Dec 30, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark won't work with vista
Yes works with Vista but you will need to use Vista driver not XP
Rate this solution then Download here
Delete old install before reinstalling!!!!
Release Notes Attention: To prevent issues during the installation, please uninstall all previous versions of this driver prior to installing this web package. File Information File Name: cjr1200EN.exe null.gif Version: 1.0.11.3 null.gif Released On: MAR 05 2007 00:00:00 null.gif File Size: 42452912 KB null.gif Products: Lexmark X1240, Lexmark X1250, Lexmark X1270, Lexmark X1280, Lexmark X1290 null.gif Languages: null.gif Operating Systems: Windows Vista null.gif Application: n/a null.gif Owner Name: Lexmark null.gif Data Stream: Lexmark Host Based Solution, Lexmark Scan and Copy Control null.gif Security: null.gif Install Instructions:
Dec 25, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark X1185 won't scan.
I have the same issues with a Lexmark printer, Lexmark printers are not very user friendly with Vista. What I did is create a dual boot with XP and installed the software for the printer there. If interested in that follow these instructions or contact lexmark support.
http://apcmag.com/5485/dualbooting_vista_and_xp
Nov 08, 2007 | Computers & Internet
Lexmark JetPrinter X1185 All-In-One InkJet Logo
116 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
