Question about Samsung ML 1710 Laser Printer
Samsung 1710 drums keep spinnning non stop.
I have Samsung 1710.
I have strange hing going on, when I put new cartridge in and turned it ON, it just keep spinning and hot air going from the little vent, but printer still spins its drums. Printer light is green at that time.
May be you have an Idea what is going on...
    Sergeant:
  • 199 Answers
I think you try with compatible cartridge they not have proper cut hole to fix cartridge in the printer
if yes,
change top cover of the cartridge with old one
Posted on Feb 26, 2009
Paper jam in middle
hi,your priner cartridge is checkig ,cartridge drum jam in to the papper is jam,or printer fuser unit replace
Apr 06, 2014 | Samsung ML 1710 Laser Printer
When I turn my printer on, the light goes green, but it keeps doing the "boot up" sound without stopping. If I let it go long enough I can smell the motor getting warm. It doesn't stop and will...
Try taking out the Drum and toner cartridges, ensure there are no blockages in the paper channels. Re-install and reconnect to mains.
Please rate this answer.
Cheers
Bob
Jan 09, 2011 | Samsung ML 2010 Laser Printer
I have a Samsung 1710 laser printer. It prints the text fine but there is a 1/64 (aproximately)wide vertical line of broken printing on the right side of each page. Also, the paper does not appear to be...
Sounds like the printer cartridge is bad. The first thing I would try is replacing that and then see where you are. The broken line on the right side is likely due to a worn imaging drum coating, common with Samsung.
Feb 05, 2010 | Samsung ML 1710 Laser Printer
Dell 1710 printer. When printing just tthe top 2
Have you tried replacing the drum? That is the part that the toner cartridge actually sits in.
Jan 28, 2010 | Dell 1710n Laser Printer
Is there an easy fix to the Dell 1710 that squeeks prior to and during the print cycle? I recently replaced the catridge and image drum.
If you power up without the cartridges and it runs without noise then the problem is in the new cartridge or drum, if it makes noise even with them out then you may need a new fuser assembly. www.precisionroller.com may have that unit.
Jan 13, 2010 | Dell 1710 Laser Printer
Samsung ML-1710 Printer - see below
Try to put new cartridge in.If this doesn't fix the problem, it can be that the fusing unit heater roller teflon coating is worn out and this roller needs to be replaced.
Apr 28, 2009 | Samsung ML 1710 Laser Printer
Samsung ML 1710 Laser Printer, over active feeding
sounds like there's something in the print queue..disconnect it from the computer, and try it again.
Feb 19, 2008 | Samsung ML 1710 Laser Printer
Dell 1710 lights
You need to replace the drum and toner to correct the issue. That's the sign of the drum at its end of life.
Nov 02, 2007 | Dell 1710n Laser Printer
Blank stripes on page left to right
If the blank stripes go up and down the page (vertical) then it sounds like the laser lens has simply got toner on it. remove the toner and photo conductor units. Look for the glass panel that covers the laser lens and simply wipe it off with a cloth. Some machines incorporate a lens wiping pad that can clean the lens without taking out the parts. I can not remember if the 1710 does or not.
Sep 06, 2007 | Samsung ML 1710 Laser Printer
Printer
Swap in another cartridge and see if it fixes the problem.
Apr 19, 2007 | Samsung ML 1710 Laser Printer
Samsung ML 1710 Laser Printer Logo
95 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
