Question about Ricoh Aficio AP3800C Laser Printer
I have a Ricoh 2045E I changed the toner and now get a SC680 error?
  • Roderick Mcmahon
    Roderick Mcmahon May 11, 2010
    Our you sure that it is a SC680? The srevice manual only stops at SC672 and then jumps to SC 690. There are no service bullitens posted on the \is code SC680. can you check again?
  • Anonymous May 11, 2010
    You sure about the "680"? I don't show that in the service manual?
    Problem Solver:
Maybe the SC 680 code does not exist but my AP3800C did not know that so it showed it twice, Replacing the toner solved the problem for my machine.
Posted on Aug 08, 2010
    Sniper:
  • 58 Answers
There are no SC 680 codes listed in the service manual for a 2045e
Please re check the code
Posted on Feb 26, 2010
4 Suggested Answers
Ickoajnc
  • 183 Answers
SOURCE: error code SC 546 in Ricoh 2045e
It's fusing unit but the thermistors connection can be good, but check do they are touching the surface of the hot roller and check do on the side where they are in touch with the surface of the hot roller has some attached toner on them.
Posted on Jul 11, 2009
  • 22 Answers
SOURCE: ricoh 2045e
The delivery server IP address is pushed to the machine from the scan router software. If it needs to be updated, you will have to remove and readd the I/O device within the scan router administration utility. If you do not use scan router you can set delivery option to off, and it will eliminate the error message.
Posted on Jul 22, 2009
Ickoajnc
  • 183 Answers
SOURCE: RICOH 2045E COPIER WHAT DOES ERROR CODE SD546 MEAN?
Hello!
Follow the next steps carefully and the error code SC546 will disappear.
Press the following keys by this order:
1. press the (yellow key) [Clear]
2. press then the numbers on the numbers key by order (1)-(0)-(7)
3. press the red key (cancel) [C] and hold it pressed for about 5 seconds.
4. on the screen will appear another menu different from the one
you are
familiarized it will write up in the left corner [service menu],
(if the service menu do not appear repeat the procedure again).
After this menu will appear turn off the machine from the red switch which is located somewhere in the middle of the machine and just by the left corner (the turn off switch-plug) wait for 10 seconds and turn back on the machine by the same switch-plug.
After this the error code SC546 should be disappear.
Please Answer does this was helpful for i to know does the problem has disappear or i should post some other information.
Regards
Posted on Jan 12, 2010
Toner reset
SC680 is a communication error, usually relating to the chip on the toner cartridge. Check that it is clean and that the electical connection is properly made when the cartridge is in place. It can result from a wiring error, but that is much less likely, and a failure of the BCU board - even less likely. Hope that helps.
Jan 17, 2014 | Ricoh Office Equipment & Supplies
BLACK GROUND
change the toner and the developer
Jan 03, 2014 | Ricoh Aficio 2045e 2035e Copier...
I have an sc 326 error code in my ricoh aficio 2045 copier
kindly change the developer unit and clear the error.
the machine will respond
thank you and all the best
May 20, 2012 | Ricoh Aficio 2045e 2035e Copier...
My machine aficio 2045e give error toner signal even though toner in bottle is more than50% i make every thing but still appear add toner
Inside the toner feed mechanism there is little plastic fins that tend to break off. You will probably have to replace the hopper unit (The unit that the toner tube sits in) or in that unit where the tube opening sites you can either replace the feed chuck or if your handy maybe repair the feed fins. The chuck part pops out with plastic tabs.
Sep 14, 2011 | RICOH RICOH AFICIO SP C820DNT2 40 PPM...
Where I can download drivers from the machine DSM635sp GESTETNER Thank You Jorge
Hello!
Gestetner is made by Ricoh. They only change the name. The cross reference for your model is Aficio 2045e.
You can download from the www.ricoh-support.com the driver of Aficio 2045e and your done.
Hope this helps you.
See you!
Jun 23, 2011 | Gestetner DSm635sp Digital Imaging System
RICOH 2238 C ERROR CODE SC680
SC 680 BCU/ MUSIC communication error After the engine CPU sends a message, the Music CPU does not respond within five seconds three consecutive times. • Toner cartridge memory chip loose connection • Memory chip problem • Memory chip cable wiring problem 1. Turn the main switch off and on. 2. Check if the toner cartridge is installed correctly. 3. Replace the toner cartridge. 4. Check if the harnesses are not damaged. 5. Replace the BCU.
Mar 12, 2010 | Ricoh Aficio Type 2238 (411603) Print...
Error code SC 546 in Ricoh 2045e
Jul 01, 2009 | Ricoh Aficio 450 Copier
SC680 error message on a Gestetner DSc38
The machine has a problem reading the memory chip on the toner.
Check if the chip is not lose or damaged or durty
Check the harnass or the chip reader and pins and clean.
Replace toner
after replacing the toner and the problem is still there you can do a engine clear.
contact me drbrain@webmail.co.za for doing engine clear.
Dec 22, 2008 | Ricoh Aficio AP3800C Laser Printer
Ricoh Aficio AP3800C Laser Printer Logo
320 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
