Question about Whirlpool GR465LXLS Electric Kitchen Range
Burners indicators say they are on but no heat
Hi
I have a Whirlpool Electric Range Model # WERP4120PQ1.
The problem is that the range blew a fuse and once replaced there is no heat coming from the burners when they are turned on. The light by the switch comes on and the oven works but not any of the burners.
There was also an E2 F3 error code.
Can anyone help? Please.
Thanks
Wondering
  • Thomas Malailua
    Thomas Malailua May 11, 2010
    your oven requires 220 volts too function,so if your oven is working properly then we know its receiving the proper voltage from your home.,so all burners are out at the same time .that shouldn't be hard to find ,a wire has shorted and then tripped your breaker .your going to remove the back of the range and look for a burnt wire that is in common with all burners[or supplies voltage to all burners]if one burner goes out/or shorts out if wont stop the other burners from working,thats why its a wire that supplies all burners.you can take a look at your ranges wiring diagram to get a clue on the path the voltage takes to get to the burners.but many times you will see eveidence of burning on the wires
  • 15,935 Answers
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board.
If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe.
If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#%RW
Posted on Oct 01, 2010
Whirlpool electric range oven broiler not working
Hello. This is a common failure for this range. Replace part number
9762215, price varies but about $100 average.
Apr 07, 2014 | Kitchen Ranges
Kenmore Electric Range Model #911 9237313-All burners quit at once?
Have you checked your fuse box. The Electric Range is on a separate circuit. Check to see if it is tripped or off.
If it has tripped and you reset it, that usually means there is a problem with the electric range.
Let me know if that helps.
Jan 22, 2012 | Kenmore Kitchen Ranges
Whirlpool RF302BXYW Ser# FD1227461 oven quit working (surface burners are okay)
Several possibilities:
1: Fuses blew under the top cover. Oven fuses will not affect top burners.
2: Element has burned out. Top element only heats when you try to warm the oven.
3: controller has burned out. A controller can cost $150 - $600 for digital. You might want a tech to confirm before you change this one.
Apr 17, 2010 | Whirlpool RF302 Electric Kitchen Range
Heating elements
I have a Whirlpool super capacity 465, the surface light for the burners comes on, the burners don't heat up, nor does the oven,(the light that says oven is on does not light up). I checked the main circuit breaker, that works. Are there any fuses in the range that would need to be replaced?
Thank-You,maddie
Feb 01, 2009 | Whirlpool GR460 Electric Kitchen Range
Whirlpool sotve
Hi marywell,
Alot of times this is a sign that the voltage to the range is only half of what it should be. You may have a breaker kicked, or a bad fuse in your fuse box. When the range is only getting 110 volts instead of 220 volts, the oven will slowly heat but nothing else will work. check your breakers and I bet you will have the problem solved. Have a nice night and I hope this will FixYa. Please don't forget to rate me.
Mike
Sep 29, 2008 | Whirlpool RF367 Electric Kitchen Range
Whirlpool electric range burner power light stays on but no heat
Hello givemeanidth.
Welcome to Fixya
You said, have a Whirlpool electric range (model rf363pxpt0) with standalone burners - the burner power indicator light stays lit whether the heat control knob is on or off, there is no heat coming from the burner on or off. You pulled the burner from the receptacle and one of the tabs broke off and stayed in the receptacle. You removed the tab and made sure no pieces remained in the receptacle then bought a replacement burner, no change. You put the replacement burner in the back burner of the same size and had heat within 10 seconds. You changed out the burner with the one that had been in the back of the range, no heat. As long as the breaker to the range is on the power light stays lit but no power to that one burner only.
What is the model number and the age of your range?
Waiting for your reply.
Huuum
Sep 02, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Whirlpool Standard Cleaning Electric Rang Model RF315PXKQ
hi,
Can you please tell me if you have replaced the thermostat?If not then please do that.
Feb 24, 2008 | Whirlpool RF369LXPQ Electric Kitchen Range
Need advice on Kenmore electric range
turning frot burner on sparked and now all 4 burners don't work any more
Jan 03, 2008 | Kitchen Ranges
Whirlpool GR465LXLS Electric Kitchen Range Logo
150 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
