Question about Frigidaire FEB27S5A Electric Single Oven
My oven won't heat to the right temp.
Ok so my oven has one of the bulb ignitors...its a kenmore...an older model...the oven heats up to 250 and stays there and the flame keeps going out...i set it up to 400 the other day for about 2 hours and it still stayed at 250...yes i have an oven thermometer so i am sure of the temp...the ignitor turns red still so im pretty sure its not that...what else could it be?
  • dkotasmommy3 Feb 26, 2009
    how would i do that?
    ok ill try that thanks
  • 8,197 Answers
Check the temp censer in the oven It went bad.
Posted on Feb 26, 2009
  • Jyackle5
    Jyackle5 Feb 26, 2009
    I would just replase it. it cost about 10 dollars. It is a metal rod that sticks out of the back of the oven.
I have an electric kenmore model 362 oven/stove trouble.
Are you sure that there is not a buton on it that says degrees Celcuis of Farenheit. It happened to me a few years ago. If there is such a button try pushing it to see if it will go back to normal.
Feb 28, 2013 | Ovens
Kenmorw built-in oven (Model #30129) won't maintain cooking temp, flame is off and on continously, take twice as long to bake or broil food. If the temp is set for 500, the oven temp might be 250.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Aug 06, 2011 | Ovens
Bake cycle wont work gas kenmore with electric controls you can set temp it goes to preheat and nothing happens broiler works and all the tops work
here is a tip i wrote covering that
What the problem is when your gas oven ignitor glows,but no heat for the...
MessageRate.ThreadID = 9947539; MessageRate.ProductID = 0;
The problem beleive it or not is that the bake ignitor is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake ignitor(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of ignitor make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake ignitor. I know it seems improbable that if the ignotor comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the ignitor comes on yet the oven won't heat that a weak ignitor is the cause 100% of the time
Aug 03, 2011 | Kenmore Ovens
Pilot lights oven then has trouble staying lit
heatman101
Jul 24, 2011 | Kenmore 47834 / 47832 / 47839 Electric...
Kenmore gas oven model 36275578690 oven wont light
heatman101
Apr 20, 2011 | Kenmore Ovens
The oven is not firing up .you set the temp. and get nothing
heatman101
Apr 13, 2011 | Kenmore Ovens
MY KENMORE OVEN WON'T HEAT UP! What do I do? Everything else works but the digital temperature just stays at 100!
heatman101
Oct 13, 2010 | Ovens
Does not turn on always while cooking and temp. doesn't stay even
heatman101
Oct 10, 2010 | Ovens
I have a Magic Chef Chateau Gas range. The upper oven does not heat properly. It comes on, but never gets up to operating temps.
you could have a bad ignitor check that it is actually igniting the gas and you can see flame, also check the cavity sensor a probe that sticks into the oven at the top usually on the left top corner but if the bake cycle works with good results them it is ok
check for flame when it starts give it a mibute to ignite, if it does not then you need to replace the broil ignitor.
Sep 19, 2009 | Ovens
Kenmore 911.30464, 30465, 30469.....Wont ignite at all
there is a second ignitor for the oven unlatch bottom panel remove heat panel there is your burner and ignitor
Jan 15, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Frigidaire FEB27S5A Electric Single Oven Logo
164 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
