Question about Dirt Devil Vision Turbo W/Bonus Upright Vacuum Vacuum
The brush spun for a second then stopped spinning, it snapped one belt already and it was brand new. whats going on?
  • 134 Answers
Either the bearings on the brush are siezed or you caught the belt when you put it back together again
Posted on Feb 26, 2009
Hoover cyclean brush stopped revolving
The belt may be broken or worn If your cleaner is not picking up fluff and hair from the carpet or has become heavy to push it is possible that the belt has snapped. This belt makes the sweeping brushes spin round underneath the cleaner and brush dirt into the path of the air suction. The brushes also give that 'groomed' look to your carpet by gently brushing the carpet fibre. If you pick up something sharp or debris gets jammed in the brushes then the belt may snap. Also over time your belt will stretch, so it's a good idea to change your belt once per year to ensure the cleaner picks up dirt effectively.
Dec 14, 2016 | Hoover Vacuums
Tip
What to do when your vacuum brush stops spinning
Household vacuums come in all shapes and varieties, but many of them are similar on the inside. There is often a brush running across the length of the vacuum's nozzle, and it spins as the vacuum runs to help **** up debris. But sometimes the brush will stop running, and you'll notice a severe decline in your vacuum's performance.
Usually when the brush stops spinning, it's because something inside the vacuum is binding it up. Dirt can get lodged inside, and hair can get wrapped around a shaft. If there is too much pressure, the drive belt can even snap.
You can usually see and clean the brush just by turning the vacuum upside down, but to get to the other internal parts you have to take the vacuum apart. On canister vacuums, this is usually pretty easy because it's just the nozzle that needs to come apart. Full-size vacuums can be taken apart as well, but the process can sometimes be more involved.
If you can get the nozzle or the vacuum's base apart and get to the parts inside, you should see the brush (which is part of a long shaft), a drive belt, and some sort of mechanism that drives the brush, which is commonly a paddle or a motor.
Hair can get caught up in any of these components and cause them to not be able to spin, as can dirt and other debris. If you clean all of the components out and put the vacuum back together, it should work just fine. The brush, over time, may become frayed or damaged, and the drive belt sometimes will snap, but otherwise a good cleaning will usually make your vacuum run as good as new.
on Jun 01, 2010 | Vacuums
Henry hoover airo brush not working
yes, it probably is stretched.
Jan 07, 2014 | Vacuums
I replaced the belt with part# 40201 on my Hoover model# U5473-900; to only have it break again in 5 seconds! Is there something missing that holds it on that little bar?
Greetings,
When a brand new belt breaks in 5 seconds, this can only mean 1 of 2 things.
1. The roller brush itself may be bad and need replacing. If the roller brush's bearings lock up, and the brush can no longer spin freely, this will cause the belt to burn up immediately after you turn the vacuum on. You may test your roller brush by taking it out of the vacuum, and hold it on the very ends of the brush with your fingertips. Make sure you are only holding the bearing caps and not the brush itself. While holding the two bearing caps with your pointer fingers, try to spin the brush with your thumbs. Does the brush spin freely? If no, then you'll need to buy a new roller bush for your vacuum, unfortunately the bearings are not sold separately on Hoover vacuums. If the brush did spin freely (you should get at least 7 rotations out of one spin) then see reason number 2 below.
Your model uses Hoover Agitator Brush Part 48414132.
2. The belt was installed incorrectly. When a belt breaks immediately like this it can also be a result of it not being installed properly. When installing the next belt, after you have put the roller brush back into place, pull forward on the belt to make sure that the brush spins when you're pulling forward. Sometimes I pinch the belt underneath of the brush roller, and it will not spin freely, and will burn immediately if the belt is pinched.
It really can only be one of these two problems. I hope that this repair solution was helpful to you. If you need me to clarify something, please just request clarification here. If it did help, please be sure to rate my repair Helpful. Thank you so much!
Chris J.
Mar 13, 2010 | Hoover Vacuums
Brush not moving in Bissell pro-heat
if the belt is more then 6 months old or more, then the belt will have to be replaced reguardless of the way it lookes. belts can stretch over time and when you put the machine on the carpet the friction causes the brush to stop because the belt has stretched. i would try this first. hope this helps
Jul 30, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
I changed the belt on my vacuum,and the belt burned up,and snapped.Right after I changed it.Am I missing a piece??
Sometimes it can depend on the quality of the belt - if its brand new then it shouldn't snap the moment it is changed; if its an older belt sometimes they can break up the moment they're changed. Ensure that the model you have is correct with the correct product code of the drive belt. Also Check that the sides of the brush bar are not clogged with dirt - one way to check would be to check the brush bar rolls freely with no belt on it before putting a new one on. Another issue is something my old LG upright used to do - it used to break new belts even when the roller brush was completely clear - and the only way to get it to stop was to replace the heavy dirt bag with a new one. It seems the slightest bit of strain on a motor can make things like belts break. Hope all this info helps.
Nov 16, 2008 | Bissell Vacuums
Belt keeps snapping
Check your brush. It is likely that the brush is broken and will not spin. Hold the brush by the end caps and spin the brush and if it will not spin freely that is your issue.
Oct 31, 2008 | Bissell 3576 CleanView II Bagless Upright...
No action
I had the same problem with the belt breaking and the roller not spinning. I read about giving the roller a couple of revolutions to seat the belt, so I put another new belt on. It still didn't spin. I realized it was the end cap that was not spinning so I took off the roller and gently pried off the end cap and there was an enormous amount of thread spun around inside of the small area. I had to keep digging it out with tweezers. Quite unbelievable. I also found that when it spits out instead of sucking up, it needs to be cleaned. Check all areas, especially the part that is round that you have to twist open. (Inside, behind the foam filter and UP).
Jul 13, 2008 | Eureka 2961AVZ Bagless Upright Vacuum
Belts breaking frequently
I had the same problem. Broke 2 belts before I got online and noticed this site! What I found was, the roller ends were not turning freely. I had cleaned the hair (nasty) off the roller, but the ends were still not able to spin around without some force.
What I did was, removed the roller and on the 2 ends there are 2 black plastic caps which fit over the bearing, I removed the plastic caps and put a little WD-40 on the bearing, or any industrial lubricant, even new motor oil will work. After putting on the WD-40, I spun the roller end around a few times and the WD-40 lubricated the bearings and Voila! The roller end spun freely!! I put the black caps back onto the bearings on both sides, reinstalled a new belt, it's been working great since.
It saves the cost of a new roller.
Todd M, Fremont CA
Feb 28, 2008 | Eureka 2961AVZ Bagless Upright Vacuum
Dirt Devil Vision Turbo W/Bonus Upright Vacuum Vacuum Logo
172 people viewed this question
Top Dirt Devil Vacuums Experts
Jim Parker
Jim Parker
Tim Venetis
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
