Question about Motorola Mobility SLVR L7 Cellular Phone
PHONE DEAD i flashed my L7 with the monster firmwire upgrade using RDS lite, the monster pack flashing was going on, suddenly RDS lite rebooted my phone. after some time i got a message to restart the phone manually but when i tried to restart, it didnt got started..and my phone is dead. so plz tell me how to fix the problem..
I WANT TO DOWNLOAD PC SUITE FOR MY MOTOROLA MOBILE
Posted on Feb 27, 2009
How to get flash mode off a phone
How to fix Motorola Flash Mode Of Death To do this you must have a fully charged batery, i know when your phone is stuck in flash mode you cant charge your battery so your gonna have to buy a new one or try to charge the battery i another phone.
First download Motorola RSD Lite 3.2 from here http://www.cpfxwireless.com/downloads
Then download the Monster flash file from here http://www.cpfxwireless.com/downloads (Same place i no)
Then extract your monster flash file, save it to somewhere on your computer.Plug in your phone when on motorola flash mode .Open RSD lite , find your monster flash file wherever you saved it then click on start. You can always use the Motorola Software update , but i already had the latest software on my phone so there was nothing to update
Jun 29, 2010 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola razr v3xx is stuck on bootloader how do i reflash or solve this problem?
At this point, I'd make sure the * # and Power keys are not depressed by any chance. Maybe they are stuck. I'm afraid it might be a hardware issue, the only suggestions I could make is to flash a monster-pack but this would most likely not work and will erase anything on the phone anyway.
If not, try using Flash & Backup 3.0.7 and see if it detects your phone. If it does, try backing up ur current software and then try to flash a compatible MP (Monster Pack) from http://www.modmymoto.com/forums/downloads.php?do=cat&id=142
Try that.
Oct 20, 2009 | Motorola Mobility RAZR V3xx Cellular Phone
DEAD AFTER FLASHING
sounds like it got wet... go to the service veriz or tmob whatever it is they can retreeve your memory onto another phone
Jun 06, 2009 | Motorola Mobility SLVR L7 Cellular Phone
Error (-48)
Error(-48) is somekind of hardware communication error. The easiest way to fix it will be to flash the firmware. Here's how to do it.. It will take a while(around half an hour) but its worth it and will also improve the sound clarity of your phone.
What u need :
1) Motorola Driver
2) RSD Lite or Flash&Backup 3
3) Monster Pack(Flash update for(Lseries including SLVR)
Firstly you need to backup all your files that stored on phone memory because it will delete everything in your phone when you flashing.
Start RSD Lite and let it connect to your phone. If your phone is not detected (and you are certain you have everything installed), disconnect the data cable, then shut your phone off, and manually put it into bootloader mode. You do this by pressing and holding down the "*" and "#" keys while pressing and holding down the on button until you see text display on your screen. Now connect the phone back to the data cable. Now click the button labeled "...".
http://www.hackthel7.com/gif/flash1.gif
This will bring up the open file dialog box. Find the file you want to use (in this case select your monster pack file) and then click the button labeled "Open".
http://www.hackthel7.com/gif/flash2.gif
Click the "Start" button. Now you should see various messages displayed on the screen as the program processes each code group and does various other things.
http://www.hackthel7.com/gif/flash3.gif
This is what the phone will display during a flash:
http://www.hackthel7.com/jpg/upgrade.jpg
After it's finished and your phone has given you a confirmation tone, you can click "Close" and disconnect your phone from the cable and check out your changes.
If you should get a message like this where the program seems to hang:
http://www.hackthel7.com/gif/flashstuck.gif
OR
http://www.hackthel7.com/gif/flash4.gif
Don't panic. Just close the program, chance are your phone is just fine. Sometimes this happens. This is usually caused by a checksum error. There could be more serious cases where you phone appears dead. In this case try to reflash your file again. You could also try reflashing another file.
Sep 30, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Motorolla L6 keypad malfunctioning
if the flex has replace already and the problem still persist, flash the phone in RSD lite with monster pack..good luck....
Sep 16, 2008 | Motorola Mobility L6 Cellular Phone
Aye
do a monster flash. WARNING: YOU WILL LOOSE ALL OF THE DATA ON THE PHONE!
if you want to keep all of the data, follow these instructions.
Aug 01, 2008 | Motorola Mobility SLVR L7 Cellular Phone
How to get a motorla out of boot loader mode?
hi u need to load back the phone operatin system so therefore u need to flash yr phone with a monster pack and to flash it u can use RSD 3.6 and download the monster pack for the bootloader of yr phone tht should do the trick....
Jun 20, 2008 | Motorola Mobility RAZR V3
Flashing L7
Could be that the file you were trying to flash was corrupt and ended up screwing up your firmware. Unfortunatley, I have no other advice than to take it to a service center for repairs, or installing a new board..
May 19, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Motorola RAZR V3i Cellular Phone
hopefully when you where doing this you made a back up of your original firmware so you can just reload it using the RSD Lite
May 16, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Is my v360v dead??
can not send picts from my phone from South Africa to Greece please can u help
Feb 11, 2008 | Motorola Mobility V360 Cellular Phone
Motorola Mobility SLVR L7 Cellular Phone Logo
83 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
