Question about Getac C71A1A00GA00 Notebook
Tv mobile touch screen wont work
How to calibrate when icon keeps moving?
The touch screen of my Bernina 580 stopped working today and it was perfectly OK yesterday. Is there a way to fix it on my own or should I look for help?
Calibrate the diplay
The Display calibration can be opened as follows:
- turn off the sewing-/embroidery computer
- touch the two needle positioning buttons on the front panel and keep them pressed
- turn on the sewing-/embroidery computer and release the buttons as soon as the Display appears
- touch the calibration icon
- touch the center of the cross using the touch pen
-- the cross moves to the next position
- repeat this until all three positions shown are calibrated
-- the Display is closed
-- the adjustment is saved
Apr 13, 2014 | Bernina Artista 180
Touch screen not responsive after speaker replacement It worked before speaker replacement.
To calibrate the touchscreen on a nuvi 300 or 600 series:
1. Power the unit On.
2. From the Where to? / View map screen, touch Settings (wrench icon).
3. Touch Display.
4. Touch Recalibrate.
5. A new screen will display that says Press Dot.
6. Touch the center of the dot.
7. Keep touching the center of the dot as it moves around the screen.
8. When Calibration Complete appears on the screen, please touch OK.
The touch-screen will now be recalibrated.
Nov 04, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
My garmin nuvi 660 touch screen dosen't work
  3. Touch Display.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
I have a garmin nuvi 660. the touch screen isn't working
  3. Touch Display.
Oct 24, 2010 | Garmin nuvi 650 GPS Receiver
Janome MC 9000 off touch screen calibration
Thanks guys
I remembered the fix!!
On the Janome MC 9000
To calibrate the touch screen
1. Turn off
2. on Sewing arm above needle there are a series of buttons
3. Hold down bottom 3 buttons
4. While holding turn on machine
5. Using scribe
6. Touch the centre of each + as it appears
7. It will go Centre bottom rh centre top lh as you select each + position it moves of it's own accord.
8. Turn off machine
9 Turn on and test.
Important sometimes this does not entirely fix prob!!
Simply do it again "Yahoo""
Some mechanics will try to tell U the screen is on it's way out
Bollocks just calibrate.
Thanks
CYA
Nov 16, 2009 | Janome Memory Craft 9000 Computerized...
How do I know that the touch screen is working right? I touch an icon and it does not work I have to tap above the icon,,,,,,,,,,,,,
You need to reset the calibration on your phone. You can do this in settings, touch screen and calibrate. Once this is complete your phone will be back to normal.
Oct 27, 2009 | T-Mobile Wing™ Smartphone
I just got a new i68 and it wont unlock.
try calibrating your touch screen. Please use the stylus to calibrate!
The fastest way is to be on the slide-lock screen & hold the side volume button in the Up position until
"Press volume down key to check" comes up onscreen. This may or may not work on all firmware versions
on the current i9, but works on most. Make sure to hold the button firmly in the Up position. You will first
see the normal volume speaker icon show onscreen and the volume rise, but just keep holding it Up, and
eventually you should see the pop-up box noted earlier. The moment you see that pop up onscreen,
immediately press the side volume button in the down position. A white calibration screen should now
show & you can calibrate the touch screen using the stylus. Try to tap as close to the center of the little
pulsating icons as possible, as this will more accurately calibrate your touch screen. If the calibration
screen didn't come up using that method, then you can get to it from the Main menu screen.
Select "Settings", then select "Pen calibration", & follow the previous instruction.
For full help topics I have a cd available for 10 us dollars. Has 100's of mp3 ring tones wallpapers, and java games and opera java browser. Guaranteed help on every question ever asked on these phones. And all settings for all cellular services. I have answered 100 questions with this CD. If interested contact prestorose@aol.com Pay Pal only, will send out First CLASS Mail in padded envelope. If interested I will send Pay-Pal invoice that can be filled out and returned with instructions. Guaranteed safe transaction.
May 07, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
I9 Phone Unlock wont move
Try Calibrating the touch screen. Listed is the instructions how.
Apr 22, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
I have a cect i9+ mobile and when I swith it on and try to unlock it from the arrow it is not working (like it is jammed). Any solution pls?
You need to recalibrate your screen.
There are 2 ways to get to the calibration screen. Please use the stylus to calibrate!
Mar 06, 2009 | Dual Electronics CECT P168 Cellular Phone
Computers & Internet Logo
64 people viewed this question
Top Getac Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David Payne
David Payne
Are you a Getac Computer and Internet Expert? Answer questions, earn points and help others
