Question about Toshiba Satellite Laptop with AMD Athlon 64 X2 Dual-Core Processor QL-60 - Onyx Blue PC Notebook
Built in webcam has gray or black screen
I just bought a satellite L355D-S7901 laptop and just went to use the built in webcam and cannot get it to work. I see me in the preview but not when it is actually in use.
What do I need to do?
  • eleizar_cris Apr 22, 2009
    I have a webcam that works... But when i have formatted my pc into WindowsXPSP1 and installed my webcam.. it only displays a blank gray screen... but when i try to install it on other pc's it works fine... I have tried to install different drivers but it still displays blank screen... so i have install other codecs so that it can render the video but it still doesn't work... when i press the capture button on my webcam it says that i have pressed too fast... is this a virus???
5 Suggested Answers
  • 66 Answers
SOURCE: Toshiba Satellite L355D-S7901 will not boot
pull the ram individually and see if that allows the computer to boot. If that does nothing then you would need a new motherboard.
Posted on Nov 06, 2009
  • 13433 Answers
SOURCE: my laptop says its missing
You need the windows vista disc, insert it to the laptop, and select Repair my computer when it loads.
Then select start up repair from the top:
If you didn't receive a disc with the computer, any windows vista disc would do, can you get one from somewhere? borrow?
Posted on Sep 28, 2010
askmarv
  • 57 Answers
SOURCE: Does my Toshiba satellite L355D-S7901
Hi!
This unit does not have DVI out, rgb/vga.. You can refer to this link.. http://cdgenp01.csd.toshiba.com/content/product/pdf_files/detailed_specs/satellite_L355D-S7901.pdf
Hope this helps.. :D
Posted on Feb 22, 2011
DJ Skywalker
  • 507 Answers
SOURCE: when restoring toshiba L355D-S7901 what
Read this forum:
http://www.howtogeek.com/forum/topic/recovery-error-on-toshiba-satellite-a205-s5864?replies=21
Posted on Jun 20, 2011
Toshiba Satellite Laptop wont boot up
does it shows the flash screen which displays *********** board? if yes then you can check by installing a fresh copy of windows and if nothing comes on the screen then you may have defective mother board.another thing if *********** board is fine and you find that your system is not installing the OS,you need to zero-fill your hard drive then,coz you may have a corrupted hard drive.
Apr 07, 2012 | Toshiba Satellite L355D-S7901 Series...
Problem with L355D-S7901 random shut off
check all leads from motherboard to hard drive including electrical extensions and all of your cd/dvd drives make sure connections are secure dust free and not faulty
computers need all power and data to travel through every working device and to finish its cycle
so any faulty lead will end in computer error or shutdown or fail to boot
make sure your computers RAM modules are securely seated with no dust in the sockets also the Cmos battery has charge and seated with no dust in the sockets
some motherboards cmos batteries are soldered in
might be getting hot check your CPU make sure it has a thermal paste and a dust free and secure seating
could be a memory dump you might be running to many programs at the one time placing to much strain on the CPU you might not have enough RAM random access memory
hope this helps you
Mar 23, 2012 | Toshiba Satellite L355D-S7901 Series...
When restoring toshiba L355D-S7901 what does "error 10-FA11-045D" mean? i get that code when its creating the crc files. how can i fix this?
Read this forum:
Jun 20, 2011 | Computers & Internet
Toshiba Satellite L355D-S7901 problem : after i switch on the laptop, its stuck at " toshiba leading innovation" . it cnt be hard disk coz ive checked it wit other HDD.. it also cnt be ram,...
Try to remove the laptop battery, hard disk. connect the laptop to AC power then start the laptop. Then try to check whether you can login to the BIOS setup or not.
Jun 06, 2011 | Computers & Internet
Help me please my toshiba satellite l355d-s7901 not starting up it only stay in long beeping sound when i power it on please do help me
i doubt it that its a long single beep ... chk out this website it has the beep codes u wil be able to understand what the issue is if u do not get it plz reply with the beep code and the meaning given on the website
http://networking.ringofsaturn.com/PC/beep.php
Feb 04, 2011 | Toshiba Satellite L355D-S7901 Series...
Can i replace a toshiba l355-s7901 motherboard with a toshiba l355-s7915 motherboard
Going out on a limb here, but I'm going to state yes, except the s7901 has hot keys in the center strip under the LCD screen. Above the Keyboard, where the Power On button is located. The s7915 doesn't.
Toshiba Satellite l355-s7901,
http://www.notebookcheck.net/Toshiba-Satellite-L355D-S7901.14988.0.html
You can click on the photos towards the bottom to enlarge.
Toshiba Satellite l355-s7915,
http://www.notebookcheck.net/Toshiba-Satellite-L355-S7915.19879.0.html
Same with the photos at the bottom.
I know this doesn't seem like a very professional answer/solution, but in viewing both of the laptops the ports, (USB, DC Power Jack, etc.), and the peripherals, (DVD optical drive, add-in card drive, etc.), seem to be in the same place.
Viewing a Service Manual for the Toshiba Satellite l350 series of Notebook PC's, shows removal procedures to be the same across the board, no matter what model deviation it is.
As long as it's one of the Satellite l350 series.
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Go down to the second Satellite file header. The one that starts with Satellite A10.
Now go down to the second line, and then go across to L350, and click on it.
This is a PDF file. May take up to 30 seconds before you see the first page, and additional time to fully download.
Do I know for a fact they will interchange? No, I do not.
I'm willing to bet strongly that they will.
Nov 20, 2010 | Toshiba Computers & Internet
Toshiba Satellite L355D-S7901 will not bootup. Hard drive light, lights and just stays on.
Nov 06, 2009 | Toshiba Satellite X2 RM-72 Notebook
Toshiba Satellite Laptop with AMD Athlon 64 X2 Dual-Core Processor QL-60 - Onyx Blue  PC Notebook Logo
642 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
