Question about Brother IntelliFAX 4100 Laser Fax
Mfc7000 prints colors but not in black...whats
Process:
mfc7000 prints colors but not in black...whats wrong? Any help appreciated.
    Problem Solver:
  • 8 Answers
I had a kodak 5300 and had the same problem with it. It was the print head.
Posted on Feb 26, 2009
Toshiba 3511 color print problems
Hope it's not the calibration. This could happen due to transfer belt timing problem. There are sensors and reflectors inside the transfer belt assembly. They may be dirty. Clean them or replace the transfer belt if required.
Oct 03, 2012 | Toshiba E-Studio 3511 Color Copier
WHILE TEST PRINT CYAN INK NOT SHOWING WHAT SHOULD I DO SIR
This issue will only occur if an ink cartridge(s) is or was installed inthe wrong position (slot) in the machine. When a cartridge is installed, the ink tube system is filled with the ink from the cartridges, to prepare the machine for printing. If the cartridge is inthe wrong position the tube will fill with the wrong color.
NOTE: If you just installed or replaced the ink cartridges and your printed documents are missing colors please refer to the solution - I just installed or replaced my ink cartridge and my printed documents aremissing colors. What can I do? Blank
To resolve this issue you will need to clean the print head.
NOTE: It may require 10 to 15 cleanings to clean the ink tubes and print head. During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to completethe cleaning process.
1. First verify the position of the ink cartridges:
a. Open the ink cartridge cover and check to make sure the ink cartridges are in the correct order.
b. Starting from the left side, the correct order is Black, Yellow, Cyan(blue), and Magenta (red).
- If the ink cartridges are installed in the correct order, close the ink cartridge cover and continue to STEP 2.
- If the ink cartridges are not in the correct order, remove the ink cartridges that are installed in the wrong position by pressing down on the release lever(s), located above the ink cartridge and remove the cartridge(s) from the machine.
Next, reinstall the ink cartridge(s) in the correct position in the machine by gently pushing the cartridge in until it clicks.
When all the cartridges are installed, close the ink cartridge cover.
2. After closing the ink cartridge cover, the LCD will prompt - Did youchange XXXX (XXXX = the color) This message will be displayed for ink cartridge that was removed. Press the - (Minus Key for No). This willkeep accurate data of how much ink is left in the cartridge.
1. Press the INK key.
2. Press OK to select Test Print.
3. Press OK to select Print Quality.
4. Press the COLOR START key.
5. Review the Check Sheet. The colors on the Check Sheet should be in a specific order: Black, yellow, Cyan (Blue) and Magenta (red).
a If the colors on the Check Sheet are in the correct order and are notmissing any dashes, press + (Plus Key for Yes) on the key pad and continue to STEP 7.
b If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - (Minus Key for No) on the key panel and continueto STEP 6.
6. The machine will need to perform cleanings to flush out the incorrectcolor or dried ink from the ink tubes and print head.
a. The LCD will ask you BLACK OK. If black is fully printed and is the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
b. The LCD will ask you COLOR OK. If any of the 3 colors (yellow, cyan (blue), and magenta (red) are fully printed and are the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
c. The LCD will say START CLEANING + for YES and - for NO. Press + for YES to start cleaning. The machine will go through a cleaning cycle that will take approximately one to two minutes.
d. After the cleaning is completed, the LCD will say PRESS START. Pressthe BLACK START key. This will print out the print quality check sheet again for you to check and see if your print quality issue has been resolved or not
NOTE: If you wait 1 minute after the cleaning cycle is completed, the display will return to date and time. You will need to go back to STEP 3 to print the Print Quality Check Sheet again.
e. If the ink color order is correct and all of the dashes are present, press + on the key pad to select YES and continue to STEP 7.
If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - key to select NO. Repeat the cleaning process byfollowing STEPS 6a through 6d. You may have to perform this procedure up to 15 times in order to clean the ink tubes and print head
NOTE: During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to complete the cleaning process.
7. Test by printing the document that had the reported problem (wrong color printing).
Dec 08, 2010 | Brother DCP 165C Compact Color Inkjet...
Trying to print from microsoft word . Keeps printing in black. Color cartriges 75% full. What am I doing wrong?
  • Go through the Print menu (from Microsoft Word)
  • On the Print Dialog screen, select Properties
  • Click on the Color Tab
  • Make sure Color button is selected (not Black or Grayscale)
  • Press OK
When color is selected, the printer will print Black as well.
If Black is selected. the printer will not print color.
Hope this will work for you.
If this answer is helpful, please give a rating.
luciana44
Dec 13, 2009 | Brother MFC 240C All-In-One InkJet Printer
Printer wont print
Try remove all cartridges then put back it one by one.Make sure the color cartridges are not empty too.The printer need all cartridges not empty to initialized and working.
Nov 25, 2009 | Brother MFC 490cw Color Inkjet...
Hp 2605dn Black cartridge is printing 1/8" LEFT of other colors.
That problem is frequently on HP 2600 series.
You must try to change all remanufactured toner cartridges with HP OEM with no exception, the best alignment it is when you change the black cartridge and the printer make a cleaning page process. Cartridge HP OEM should be almoust empty. It Is not necesarry to be a new one. After the alignment process, you can put the remanufacturated cartridges back on.
This was work for me. 100%
Sep 27, 2009 | HP Color LaserJet 2600n Printer
Epson R265 printing colours incorrectly
For the black and white issue, check the settings and make sure that it isn't set on "sepia". As for the color issue, it is quite possible that you are out of ink. Printers may use more of one color than another depending on what you're printing. Change your color cartridge.
Jul 02, 2017 | Epson Stylus R265 InkJet Photo Printer
Balck ink not working
machine needs to go into a cleaning process once you installed new cartridges to identify that there is a new one placed there.it will need 5 cleanings to do that.if you are using refillables or generic cart,then it wont properly mix up with the others causing that specific color not to print
May 19, 2008 | Brother MFC 210C All-In-One InkJet Printer
Epson stylus photo RX500
Turn the printer off overnight and try the head cleaning process again. Leaving it unpowered for an extended period softens the ink and makes the cleaning more effective. It may require several cleaning cycles.
Apr 05, 2008 | Epson Stylus RX500 All-In-One InkJet...
Works great but won't print.
not good folks..check driver first. Also, would be helpful to have the operating system indicated for more effective help
Dec 11, 2007 | Lexmark X1150 All-In-One InkJet Printer
Brother IntelliFAX 4100 Laser Fax Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
