Question about Hobart Handler 125 115 Volt 30 To 125 Amp Arc Single Phase Wire Welding Package #500487
SNAP-ON FM140A MIG WELDER. HOW TO SET UP WIREING TO UPGRADE TO 30AMP OPERATION FROM 20AMP SYSTEM.
  • mkholcik Mar 01, 2009
    MY FM140A MIG INDICATES THAT IT CAN RUN 130 AMPS ON A 20AMP PLUG BUT NEEDS 30AMPS TO RUN AT MAX OF140AMP OUTPUT FOR THICKER STEEL. THE MAIN CORD IS A 3-12 WIRE. I HAVE BEEN TOLD THAT I CAN CHANGE THE PLUG END AND INSTALL AN 30AMP WALL PLUG TWIST LOCK UNIT WITH 10GAUGE WIRE THEN UP GRADE THE BRAKER TO 30AMPS. WILL THIS WORK???
  • Ron Jones
    Ron Jones May 11, 2010
    Is it the mains you want to upgrade ? dont even think about upgrading the set this will blow all the electronics.
  • 92 Answers
Hi, yes it can be ugraded but,( theres always a but,) you will need a feed from the mains to a rated connection on the main fuse box, this is not a DIY job, certain rules and regulations prohibit the unqualified. the new line will run to it's own fuse box, then to wherever you want, garage or w/shop with electrical cable 1.5biger than your max (30 amps) best be safe , you cooker socket is thirty amp, but thats max, there are some people that would increase the fuse size, ending up,( If they arel lucky), for a total re-wire those unlucky guy's arn't around to tell the tale. contact your provider and get it safe.
lets know how you get on
Posted on Mar 01, 2009
Rossi 220BZ Gas/Gasless Inverter Welder MIG MAG ARC Portable Welding Machine
The Rossi 220bz mig welder comes set up to use gas welding, that is with the Mig electrode connected to the positive terminal, inside the machine.
To use gasless mig wleding, the mig wire must be disconnected from the positive terminal inside the machine and reconnected to the Negative terminal - inside the machine. Open both the side coveres of the welder using a phillips screwdriver. Use a 13mm spanner to undo the hex nut holding the thick copper Mig lead to the terminal named positive, then lead it through the machine to the terminal on the oppisite side of the machine, labelled negative and screw it in place there with a 13mm hex screw. Be carefull not to bump any of the many electric parts inside the machine.
If you run the Mig welder in gasless mode with positive earth and positive elecrode it will blow the household electric fuse.
If you run the Mig welder in gasless mode with negative earth and positive electrode it will work, but the end of the Mig gun tip will get very very hot and start smoking abnormally from excessive heat.
But if you take the side covers off and rewire it (takes about 10 minutes) to negative Mig Electrode, the Mig gun tip remains cool and does not overheat. You will have to cut just one white cable tie, to get an extra inch or so of free Mig cable, so the thick copper Mig lead will reach accross to the terminal on the other side of the machine named negative. Stick the earth lead at the front in the positive terminal.
I did this on my Rossi 220bz mig welder.
http://www.weldequip.com/gasless-mig-wire.htm
Jun 25, 2013 | Welding Tools
Mig welder gas stays on all the time
Hi:
The problem must be the solenoid valve. This one must be stuck and remains open always. Dirt or metal shavings can the reason.
Change the solenoid valve.
Nov 05, 2011 | Snap-On 3 Snapon Mig Welder Gas Nozzle Ya...
My welder only welds for about 2 seconds then trips house breaker. i have a good dedicated 20amp breaker for the welder. what could cause this? the welder breaker in back of machine does not trip.
Is enough for this machine, but probably is not a fuse dedicate it just for this end side.
If you can turn all lights off and other items that might be in use with the fuse. If you can't then upgrade the fuse to a 30amp.
Jan 10, 2011 | Miller MilWeld MLL907263 /AutoArc XLT142...
Why does my mig welder keep popping the fuse?
House fuse??. If that's problem... then you need a dedicated line to your machine with a 20 amp minimun fuse, or upgrade the current one to 30amp.
Dec 21, 2010 | Welding Tools
I am having a issue with the feed and the welder quits welding after about a inch of welding then will intermittently weld for a second or two then stop again. I use this welder to keep my family tractor...
First thing I would check is the relay that sends power to the transformer when you pull the trigger. That can be one of the hardest parts of a Mig welder to troubleshoot because you can read full voltage through the thing with a multimeter when the contacts are dirty and it's not functioning properly.
That's assuming you're losing power. If it's a feed issue then we can address that later.
lp
Nov 22, 2010 | Snap-On 3 Snapon Mig Welder Gas Nozzle Ya...
30amp aux fuse blown 20 amp brake/hazz and 20amp turn blown 30amp brake blown i'm thinking bare spot in wireing someware what do you think?
that is a lot of blown fuses, start with grounds engine to batt and engine to body, then battery main to starter, i have a suspicion that when you crank the truck the voltage is being routed into the body and light circuits
Nov 10, 2010 | 1997 GMC Sierra
I have an old mastercraft 110 volt ac stick welder model 110-104 have not used it for years have lost the instruction manual plate on the machine says primary voltage is 115 and primary amperage is 26.6...
35 amp should do nicely however make sure the mains cable is of the correct size, better still, get a qualified Electricion to install it.
Usualy 30amp could be used but using 35amp gives you some reserve
Oct 03, 2009 | Miller Electric Mfg Co 903505 Invision...
Wire feed stopped after tack welding on set-up jig
i had the same problem. its probably a bad solder on the wire feed pot. not hard to fix ,but you need a solering iron .BE CAREFULL 1 unplug welder.
2 remove pot and the nut underneath.
3 remove case from welder and remove controll box.
4 run the soldering iron over the joins , then put it all back together, should work fine.
Jul 22, 2009 | Hobart Handler 140 Mig Welder
Snap on welder ya212a
not a relay
is contactor
info on contactor
c atkins carlyle
Mar 20, 2009 | Welding Tools
Hobart Handler 125 115 Volt 30 To 125 Amp Arc Single Phase Wire Welding Package #500487 Logo
1,510 people viewed this question
Top Hobart Welding Tools Experts
Matt Olenzek
Matt Olenzek
Delage guy
Delage guy
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
