Question about Kenmore 22422 Top Load Washer
Tub wont sit level
After i moved back in april, i reconnected my washer and went to use it. when i opened the lid the wash tub was not sitting right. i couldn't get it to move so i had a friend come help. he just grabbed the agitator and lifted it back into place. ever since then my wash tub leans toward the back and is always off balance. i have leveled the machine and that is not the problem. i took the shell off tonight and all the springs are in place. the only thing i noticed is there is a seal or belt that is just kinda there not doing anything. i have been reading other peoples problems for over an hour and cant find any similar posts. can u please help me before this turns into a bigger problem?
  • 7 more comments
  • klsax Feb 26, 2009
    110.22292100
    a bit to the right but mostly straight back
    i can try. do u need the whole side or the bottom?
    apparently the file size for my pictures are to big. i could email them to u if u would like
    message sent
    i didnt do anything with the back legs. i just adjusted the front ones until it was level in all directions. i will chek into that in the morning. before my friend lifted it back into place it was inoperable. i just thought that maybe from tiping it on a 2 wheeler and the tub getting stuck out of place may that caused some damage,
    the front legs a almost all the way in or up i mean it cant get any lower.. i wont be able to try this until this afternoon. i also noticed last night that there is a fine dust on the floor under the washer, it is black and smells like grease
  • klsax Feb 27, 2009
    so i put it all back together and leveled it the way u said and the owner manual said and the tub is still tilted . i ran a small load of just water all the cycles work it just is unbalanced when it spins. i took a top view picture so u can see what im talking about. im begining to think im gonna have to spend money and call someone before it is really broken from running it like this all the time. if u have any other ideas for me to try that would be great. if not thank you so much for your time!
  • MsMicki Feb 27, 2009
    I moved my washer to put in new flooring. When I moved the washer back I've had problems. When it spins it vibrats so much it moves around. Have to sit on it to keep it from moving so much. Not sure what to do.
  • 50 Answers
What is the model number of the unit?
Posted on Feb 26, 2009
  • 7 more comments
  • Nikki Nicholson Feb 26, 2009
    Does it lean to one side more then straight back?
    Is there anyway you could get me a side view picture with the cabinet off?
    I have an idea what it might be. I need to see a view with the transmission and motor so basically the lower half of the machine from the left side.
    sure send it to chucksservice@bmts.com
    I know you said you leveled it. But please bear with me. Did you pull the machine forward as in make the back legs come off the ground and let it fall not hard but firmly. The reason I ask is your counter balance spring is sitting almost perfectly vertical and you back legs look like they have not moved at all. Your suspension plate is tilted slightly backwards. The back legs are spring loaded and take a little force as in up completely off the floor then release. As for you friend grabbing the agitator and lifting it back into place, I really don't know how that would help. I will have another of my techs take a look at the pictures and get his opinion in the morning.
    Oh and you have to put the cabinet on to level it properly. Thought I should mention that.
    Lower the front down a bit as well. It does seem to be on quite an angle.
    The black powdery residue could be residue from you coupler. The coupler is rubber and located between the motor and the transmission. If it were transmission oil it would be thick and sticky and smell awful. When fresh from the transmission it is a corn syrup color.
  • Nikki Nicholson Feb 27, 2009
    I wish I could have been more help. But this unit will need someone to have a closer look. At this point it could be anything.
Shakes like crazy spin
Your maytag washer tub and basket assembly sits on a base counter balanced by 6 springs. Is is possible to move the tub around by hand. The best test is to start a spin with the unit empty of cloths, allow the tub to reach speed for a few seconds, lift the lid and check the tub position after it stops, if the tub is off center with the lid opening, re center the tub and run spin again. If your tub returns to an off center stopped position you most likely will need the base kit replaced. The base kit replaces the entire bottom of the unit along with new springs, and snubber, if so packaged per your application. Maytag experienced a defective stamping dye when these bases were stamped, thus they were stamped crooked. This test is performed with the machine it's self relatively level on the floor. If the tub assy leans and favors any one direction while you are trying to center it with the lid open, you may have a rusted or broken counter spring in side the unit. Pleazer Appliance...
Apr 11, 2014 | Maytag Washing Machines
The washer turns on and fills up but then stops. If you bang the lid a few times it will usually continue on the cycle and be fine. You have to repeat the lid banging for every load though. The lid...
Sounds like the switch that the lid presses is either broken or has been knocked loose.
Or the little plastic or metal "switch actuator" (the little poker) that presses the switch has broken.
I believe the washer thinks the lid is open because it will fill up but wont't wash until it knows the lid is shut.
Jul 18, 2011 | Whirlpool Washing Machines
Washer doesn't sit level in new laundry room
A washing machine may wiggle, rattle or move across the floor. It is often accompanied by excessive, or loud noise. There can be several causes and the problem is worse with some units more than others.The most common cause is an unbalanced wash load. Open the lid/door, and attempt to redistribute the clothing to balance the weight. Heavy loads, especially things like comforters, are more likely to become unbalanced than small loads. If you do a lot of heavy loads, you should consider a heavy duty/large capacity washer when it comes time to replace your current unit. A washer must be level both from side to side as well as from front to back. Washing machines have adjustable feet to enable you to level them. See your manual on how to level your washing machine.The outer tub/basket, is supported by springs, pistons or counterweights to keep it balanced. The weight of all that water in a wash load requires a powerful balancing mechanism. If the balancing system becomes detached from one or more points, it will not be able to balance the load properly. Furthermore, even if everything appears to be in place, as the appliance ages, the springs or pistons/shock absorbers, may begin to wear out and not support as much weigh as needed.
In order to check properly for internal issues,unplug the washer and open the cabinet. Because of the variety of balancing mechanisms, you will have to inspect your machine to determine how it is balanced. Once you discover the mechanism, then inspect it for integrity. In the case of old parts that appear to be in working order, you may not be able to tell if they need to be replaced. They may be weak but appear to be in good condition. If no other solution resolves the problem, then replacing the balancing springs or other moving support parts may be the best action.Another common cause for excessive movement, or rocking, is the floor on which the washer sits. The washer is heavy and even more so when filled with water. Any floor, other than a concrete slab, will tend to pick up and amplify the vibrations from the machine.There are a couple things you can try. If you have access to the joists under the floor, you may be able to beef up the support. Another thing to try is placing a large sheet of plywood under the washer. It should be 3/4" or even 1" thick and as large as possible to distribute the weight. Use a sheet big enough for both the washer and dryer to sit on. If possible fasten the plywood to the existing floor.
May 23, 2010 | GE WSXH208A Front Load Washer
Our Kenmore 70 Series washer bangs so severely during the spin cycle that I'm afraid it's going to launch itself into space. I already used a level to make sure that the machine is sitting properly on the...
Open the lid and check to see of the inner tub is loose. Grap it on opposing sides. Lift on one side and press down on the other side. If the tub moves easily the tub nut located inside / under the agitator at the top of the tub is loose. Also another thing you can do is reset the rear auto adjusting legs by tipping the washer forward until the rear legs are at least 2 inches off the floor and drop it back in place. They will self adjust. Good luck and if none of the above work repost here.
Jan 11, 2010 | Kenmore 24032\24036 Top Load Washer
Washer is all over the place!
If you've recently had the washer apart for maintenance, you probably have managed to unlevel the washer. The rear feet of Whirlpool manufactured top loaders are auto-leveling. You can usually tell if the washer if off level if the back appears to be sitting lower than the front. You can reset the level by following these very simple steps:
1. Make sure the wash tub is empty.
2. Open the washer lid and grab the rim of the wash tub opening (do not grab the tub).
3. Place one foot against the bottom front center of the washer.
4. Pull the washer towards you so that the back feet come off the floor. You should hear a clicking noise as the rear feet automatically level.
5. Lower the washer back in place and use a level to ensure the washer is level front to back and side to side.
This is a common issue when moving or doing maintenance on the washer. Many consumers do not know about the auto-leveling feature of these washers.
If you find that the washer is still unlevel after resettting the back feet, adjust the front feet by using a wrench to adjust the feet.
I would attempt these procedures first before assuming a bent shaft. I have never seen that occur. Its not to say that it can't, but its probably not common.
If you have any questions, or if you still need assistance, please let me know. I hope this helps you.
NOTE: Kenmore washers are manufactured by Whirlpool.
Oct 01, 2009 | Kenmore 23822 Top Load Washer
Washer is not draining after wash or rinse cycle
Check your lid switch.
If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
If the switch is not activated by a lid strike, it will activated by a hinge actuator located next to either the left or right lid hinge. You will need to remove the operator console in order to access this type of switch.
If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
A new lid switch (if needed) can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. All these sites offer competitive pricing, so shop all them for the best price.
If you have questions, or need additional assistance, please let me know. Please post back with a complete model number (located on a nameplate around the wash tub opening) with your questions, so that I may be able to provide you with better assistance. I hope this is helpful.
NOTE: You do not need to bail or empty the wash tub to complete this repair.
Sep 04, 2009 | Washing Machines
Series 90 Kenmore washes but won't rinse or spin
A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price. If you still need assistance, please contact me and let me know. If my diagnosis is not correct, please post back and elaborate a bit more so I can assist you further. If your washer is not configured this way, or if you still have questions, please let me know.
Jun 16, 2009 | Washing Machines
Kenmore 80 series won't run after filling up
The symptoms you describe are typical of a lid switch problem. The lid switch is usually located on the right hand side under the cabinet. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the right side of the wash tub opening. Make sure the lid strike is still on the lid and intact, first. Then, check the mounting screws that hold the lid switch in place (two screws along the tub rim on the right hand side). Often all that is required is to tighten up the mounting screws and this will realign the lid switch where it can be properly activated by the lid strike.
If the lid switch is broken, you can find a replacement at searspartsdirect.com. If the model number you have this listed under is correct, just type it in the search menu at the Sears website. Type the COMPLETE model number from the washer nameplate (located around the wash tub opening under the lid). You can find the switch under the "Top and Cabinet" heading as item number 11. The lid strike should be listed under the same heading as item number 20. If you do not wish to order online, take the part numbers provided by Sears and go to your nearest appliance parts retailer. These are common parts that most will carry in their store inventory. The following link explains how to replace the switch:
I hope you find this information helpful. If you require additional assistance, please let me know.
NOTE: You can also check repairclinic.com or pcappliancerepair.com for parts as they also offer competitive pricing.
PS You DO NOT have to drain the washer to complete this repair. Once the lid switch is replaced, the washer should drain on its own.
Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
Tub out of balance
Assuming the machine is level I would first push the wash basket to the right rear corner while holding it there look to see if the spring on the left front corner is connected, if not reconnect it if its gone order a new one. Hope this helps
Dec 27, 2007 | Fisher and Paykel GWL11 Top Load Washer
Kenmore 22422 Top Load Washer Logo
76 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
