Adobe InDesign CS2
Problem for Adobe InDesign CS2
Color preview problem in CS2
By Mini Me - usenet poster
I've a problem with viewing images with colourspace Adobe RGB (1998), which
looks very strange to me.
I have calibrated my monitor with this test image:
All steps looks ??quidistant (properly distributed and distinctable). As
bridge says, there is the Adobe RGB colourspace included.
If I load this image in CS, then they grey scale looks correct, but the
colours are clipped at the high end. Espacially the three red bars on the
right side are quite indistinctable. If I switch to "proof" with my monitor
colourprofile, the picture looks correctly.
Almost the same happens with photographs from my Canon 300D ("Rebel"), taken
with Adobe RGB. Bridge also shows the pictures with to strong colours.
Most other programs do show the test image correct, e. g. MS-IE, XnView,
IrfanView. Only the "Preview" of Windows XP does also show that squeezed
colors.
Is there no way to show Adobe RGB pictures in CS2 correctly after loading?
J??del.
Solution #1
posted on Aug 02, 2007
Somewhat Helpful)
Reynolds
Rank: Apprentice
Rating: 0%, 0 votes
Of course I can.
That, indeed, I cannot do by eye.
Color management software then
Anyway - your answer does meet my point. But thank you.
Johannes.
J??del.
Was this helpful?
Yes
No
Solution #2
Not Helpful)
Chandler
Rank: Apprentice
Rating: 0%, 0 votes
J??del.
Colour space ( a constant) isn't the same as monitor profile (will change
over time on the same monitor) and it sounds like your MP is either not
correct or not loading correctly. You will see the correct colours in non PS
aps because they are not colour managed and use the embedded ICC profiles
for display information.
Are you using another "profile loader" as well as Adobe Gamma, if so remove
Adobe Gamma from start up.(You don't want two profiles loaded)
Also, in Edit policies set to "Preserve embedded profiles"
MH
Was this helpful?
Yes
No
Solution #3
Not Rated)
Jimmy NY
Rank: Apprentice
Rating: 0%, 0 votes
You cannot calibrate your monitor by eye with a test image.
You need one of the devices (Spyder/Monaco etc) to measure the output of
your monitor and create a profile. The profile tells Adobe that a color
that should be a certain shade of green actually measures out to whatever
you monitor can put out. Color management software then makes the
translations so that your first print should be a reasonable, but not
necessarily the best possible, match to colors you see on screen.
Soft proofing as you describe is just plain unreliable for general use. It
is only useful for a few specific purposes and even then is not very
accurate.
Was this helpful?
Yes
No
Popular Solutions for Adobe InDesign CS2
Questions and Unsolved Problems for Adobe InDesign CS2
Do you recommend Adobe InDesign CS2?
Answer
Answer
I can no longer open PM65 files since I am using my laptop with Vista. I am trying to open them in... (More)
Answer
I can not print a 40 page layout from InDesign CS2. I can print ads that I have created in InDesign... (More)
Answer
I have indesign cs2 and need to work on a file created in indesign cs3. To open the file requires... (More)
Answer
Converting a Word file to InDesign to make flash cards. Questions on one side answers on the back... (More)
Answer
I've heard of this before. I don't have any rogue empty boxes floating around. What else causes... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Adobe InDesign CS2:
Top Graphics Pub... Experts
Rank: Guru Guru
Solutions: 1454
Experience: I have owned a computer networking sales and service company.
Ask Me
Find more Graphics Pub... Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
