Question about Flow M9 Snowboard Binding
Snowboard binding can a size 6 snow board boot fit snug into a womans large binding?
  • 30 Answers
No womens large bindings are rated womens size 8 or larger, and mens 7-9. If you have burton bindings you can shorten the adjustable strap. but make sure you strap in and when you crank down the straps you should not be able to move your boots or wiggle them around.
Posted on Mar 11, 2009
Broken esp youth suprahero strap
Broken esp youth suprahero strap - Fixya
Jan 8, 2013 - broken esp youth suprahero strap - Emsco ESP Youth Suprahero Snowboard question.
Where to order replacement strap for Emsco ESP Youth ...
Jan 6, 2014 - Where to order replacement strap for Emsco ESP Youth Suprahero ... The red foot strap broke - Emsco ESP Youth Suprahero Snowboard ...
ESP Youth Suprahero Snowboard ' DICK'S Sporting Goods
Dick's Sporting Goods
Rating: 3.1 - ‎31 reviews - ‎$24.99 - ‎In stock
Shop ESP Youth Suprahero Snowboard at DICK'S Sporting Goods. Find more ... It has adjustable plastic straps that easily fix over your child's snow boots. .... Nice board for a kid to use on sled hills but binding broke after minimal use. Value.
Burton 07 Custom S Bindings Snowboard Binding Small ...
Jan 08, 2013 | Emsco ESP Youth Suprahero Snowboard
Snowboard boots with reduced length
You may also want to look at how you are setting up your bindings. I have a US 11 foot (29 cm) and with my bindings set correctly have never had any issues with toe or heal drag.
The best way to set up your bindings it to take them off, remove the mounting screws, keep the base plates in and fit your boots into your bindings with the straps still undone. Then, with the board on the floor, position the binding at the angle you like (roughly) and look to see when the toe and heel over lap is even or if you are like me pull the bindings back slightly so that you have little or no toe drag and just little heel drag. It works a treat and I have done this for over a hundred customers over the years.
Mar 15, 2010 | Burton Boxer Snowboard Boots
I just want to ask if the Burton P1.1 2009 LARGE bindings will fit to my 24cm width board Thanks in advance
Should do... Though to be safe I'd take a measurement of the board width to the shop with you and have a look at the bindings on a board of similar width..
Better still bring the board and your boots in with you and have them fit the binding and then try it for feel before you buy..
Do snowboard bindings work with regular shoes?
Snowboard bindings will work with your boots as long as the binding size is small enough. You can usually get the straps tight enough to give you some leverage on the board. I actually tried this last year and used regular shoes. The only problem I had was that there was too much wax on my snowboard so it just stuck to the sand. So my only advice is to get as much wax off your board as possible before goin. Besides that have a blast!!
Dec 01, 2008 | Flow M9 Snowboard Binding
Boot size fit to board width
8 or Smaller Board Width 24cm or less (Narrow) 8.5 - 10.5 Board Width 24 - 26cm (Regular) 10.5 or Larger Board Width 26cm or More (Wide)
Dec 01, 2008 | Kicker Forum SLR Snowboard Boots
How to fit a snowboard boot?
" * Put on Snowboarding Socks or at least the thick socks that you would wear when you'll go Snowboarding. Do not try your Boots with regular socks. You might think it's irrelevant, but the added thickness of the socks matter a lot when it comes to the size and fit of your Snowboard Boots. Still, some people have strange misconceptions about socks. One of which is that you have to wear more than one pair of socks. This is certainly wrong since Snowboard Boots should fit snugly. It is all right if toes are grazing the ends of your boots, but make sure they aren't jammed. After all, when the boots break in a little they will feel more comfortable. * Loosen the outer (and inner if available) laces of the Snowboard Boot and insert your foot. Make sure the heel of your foot is locked in the heel of the boot. * Tighten the inner lacing first (again if available). Make it pretty tight but make sure your feet can still breathe and you don't cut off circulation. Next, tighten the outer lacing, again pretty tight, without killing your feet. * Walk around a bit and get a feeling for how well the Snowboard Boots are strapped around your feet. Make sure you don't feel any isolated, painful or stressful areas. * Now the most important test: strap into (or step into) a binding attached to a snowboard. Take on a riding position and move your weight to the front and the back of the board. Be sure the boots are securely keeping your feet on their place. Also, make certain that they are not slipping to the back or front, and that you are not experiencing painful or stressful areas on your feet. The Snowboarding Boots should make you feel both comfortable and securely strapped-in at the same time. * Lean forward. When you do this, make sure that your heel is not lifted, but that the entire boot, binding and board are making the forward move without your heel slipping out of the heel of the Snowboard Boot. If you do experience heel lift, your boot tech can add some fit aids like an Eliminator Tongue to reduce volume and increase responsiveness. This will also ensure that your heel is not slipping out of the boot. * When you try on Snowboarding Boots, take into account that as you use the boots more often, the inner bladder will get less compact because of the pressure that the bladder will be exposed to. Consequently, the Snowboard boots will become less tight as you use it more. Try to anticipate this trend by buying boots that are slightly tight. After the boots break in a little they will feel a lot better. Snowboard Boots come in all regular shoe sizes. Still, keep track of how different boots of similar sizes can vary in the way they hold your feet and ankles. Don't Buy Snowboard Boots because the internet or your friend says its cool, or your favorite rider has his/her name on it. What may feel good to one person may be excruciatingly painful to someone else. Make sure to try on many boots and only buy one that you are 100% sure of. Quality Snowboard Boots can last long, so you will want to put in more time and spend some money on this. Regardless of the Type of Snowboard Boots you intend to wear, choose the pair that fit your feet best. After all, you wouldn't want to be out of control and in pain when you ride down the slopes."
Snowboard boot type
"Snowboard Boots - Function and Types of Snowboarding Boots Good Snowboard Boots should give you maximum control over your Snowboard, protect your feet and ankles from the pressures of high speed turns, and keep your feet warm and breathing in all weather conditions at the same time. Boots come in many variations and Styles. There are Different Types of Snowboard Boots appropriate for the Three Riding Styles in Snowboarding. Currently, a lot of boarders prefer soft boots with Strap Snowboard Bindings, but step-ins are a convenient alternative. What follows are descriptions of the most common types of Snowboard Boots: Soft Boots Softboot Soft Boots are most comfortable and can be used with highback bindings and flow-in bindings. This type of Snowboard Boots allows for a large amount of movement in just about any direction. Consequently, soft boots are a must for pulling tricks since they are great for doing whatever you want. Soft Boots consist of two parts: an inner bladder and an outer boot. The inner bladder is padded to keep your feet warm, dry and protected from heavy impacts. It usually has its own lacing so you can tighten the inner bladder independently from the outer boot. The outer boot has a sturdy upper part that allows for ankle movement. The outer lacing allows you to further tighten the Boots. In contrast to Hard Boots and Ski Boots, Soft Boots are pretty comfortable for walking and even driving your car when you're not on the board. Soft Boots are currently the Most Popular Type of Snowboard Boots and are preferred by Freestylers and Freeriders. Although there is a wide range of Soft Boot Styles for both Freestyle and Freeride Snowboarding, the main difference in the different styles is in the degree of Boot Flex. Soft Boots with a stiffer upper boot and a higher cuff with a lace-up inner boot for enhanced firmness are Freeride Soft Boot Styles. Conversely, Soft Boots with loose, molded-foam inner boots for more flexibility are Freestyle Soft Boots. Hard Boots Hardboot This Type of Snowboard Boots is designed for precise control. Hard Boots support your foot, ankle, and lower leg firmly, making them best for racing and high-speed carving on hard snow. Hard Boots have a padded inner bladder similar to the ones in Soft Boots. The outer shell however is made out of hard plastic and is usually adjusted (or closed) using buckles or ratchet bails. The benefit of having hard plastic as an outer shell is that it gives riders more precision and power in edging movements. Hard Boots resemble the traditional Ski Boots. However, the Hard Boots have lateral mobility for the ankle. To provide some flexibility, hinges are often built into the ankles. The soles of Hard Boots usually have a mechanism that allows them to be connected to Plate Bindings. Hard Boots are often used with plate bindings by Alpine Racers who want their movement to be directly transferred from the Hard Boots and Snowboard Bindings onto the Snowboard. On the contrary, Hard Boots are not suitable for Freestyle Snowboarding tricks and maneuvers since they limit the amount of flexibility. This Type of Snowboard Boots is pretty specific and seriously lessens your freedom in choice. If you're planning to buy this, make sure you find an exact match between the Binding Mechanism and the Hard Boot Mechanism. Also, make sure you can flex the Hard Boot forward easily and smoothly so as to avoid mishaps during transitions. Hybrid Step-In Boots Hybrid boot These Snowboard Boots are a good choice for those who want the convenience of a strapless system. Hybrid Step-in Boots combine the flexible, soft upper part of Soft Boots and the sturdy hard soles of Hard Boots. They are used in combination with Step-in Bindings. People who are looking for a mix between the comfort and flexibility of Soft Boots and the control of Hard Boots will often opt for Hybrid Step-in Boots. As with Hard Boots, you will need to find a match between the Step-in Binding mechanism and the Boot mechanism. Before you buy Snowboard Boots, you must first decide whether you want to go with a Step-in Binding or a traditional Strap Binding. Remember, while traditional Strap Bindings will work with any non-Step-in Boots, Step-in Boots must be purchased together with their corresponding Bindings. Also, keep in mind that Hard Boot systems work best in harder snow conditions, while soft boot systems work best in softer conditions. "
Snowbard bindings adjustment
"With everyday use, the screws, nuts and bolts that hold the highest stress areas together tend to loosen up. Consequently, they need to be tightened regularly to ensure that a strap doesn't fall off and get lost. However, not every Mountain Resort provides tool stations, so it's important to have a Snowboard Tool within reach (preferably in your pocket) at all times. Remember, a snowboard tool is a small investment that will definitely pay off over years of riding. Also, with the standardized insert pattern of snowboards, and with the built-in adjustment capacity in most Bindings, Mounting and Adjusting Bindings has become simple quite a simple task. To be able to do this, make sure you have a screwdriver and a wrench or two. Also, it would be a plus if you have some basic knowledge about the stance width, stance location and stance angle. The distance between your front and rear foot is the Stance Width. The basic stance width is roughly the length of your shoulder-width apart (about 30 per cent of your height). The location of the center point between your Bindings relative to the center of the snowboard is the Stance Location. Conversely, the angle of the Bindings across the snowboard's longitudinal axis, wherein zero degrees represents a line that is perpendicular to the snowboard's length, is the Stance Angle. * Forward Lean For starters, check your board's Forward Lean. The forward lean is the amount of forward angle on the highback support. For more leverage and more responsive heelside turning, add more forward lean. By adding forward lean, you also force your knees to bend, consequently ensuring a good riding stance. Still, too much forward lean makes your knee bend too much. Over bending your knees put pressure on your quadriceps muscles and reduces your ability to turn easily. So don't overdo it. You can usually adjust the forward lean in soft-boot Bindings by changing the position of a plastic stay behind the highback. * Rotating the Highbacks You can easily rotate your Bindings' Highbacks if your bindings have slots on the hinges where the highbacks are fastened to the binding's baseplate. To make your heelside turning more responsive than when it is angled along with the baseplate, adjust your Bindings in parallel with the Snowboard's Heel Side Edge. You can do this by loosening the bolts and rotating the highbacks. * Adjusting Strap Position Generally, this involves unscrewing the straps from the baseplate and moving them forward or backward on the Bindings. To improve control, move the straps higher up on the foot. Conversely, move them down lower to increase flexibility. Make sure that the toe strap is resting around the base of your toes and is securely holding down the tip of the boot. Shorten your straps if you find yourself pulling on them for a snug fit. You can do this by fastening the straps to the baseplate further along the length of the strap. Most straps already have extra holes for this adjustment."
Snowboard bindings types
"Strap Bindings Highback Bindings The Strap Bindings is the original and still the most popular Binding System in Snowboarding. This is because Strap Bindings are not only adjustable and very secure, they are also comfortable. Nowadays, this Type of Bindings is designed to be lighter and stronger. Strap Bindings consists of a contoured baseplate where a rider can place his Soft Boots upon. At the back of the baseplate is a vertical plate (the highback) that rises behind your ankles and lower calves. The highbacks on Snowboard Bindings secure the heel of your feet and the backside of your lower legs. It also helps you to force the heel side edge of the board into the Snow Surface and brings the toe side of the board up. At the front of the binding are two or three adjustable straps which can be used to secure the front side of your feet and ankles to the Snowboard. Initially, you may have to sit down to strap in, but with a bit of practice, it'll be easier to strap in while standing. Strap Bindings can differ in the number of straps, the shape of the base, and highback plate. Alpine riders who need to perform high speed turns will prefer taller and stiffer highbacks for greater control and improved edge control. On the other hand, Freestylers will want a shorter backplate for more flexibility and turning power. Most people go for these kinds of bindings as they are more common, offer excellent control, and offer more options when it comes to boots-bindings combinations. The combination of the highback plate and the front side straps gives great control. This Type of Bindings is used in combination with Soft Boots. As the Binding gives all the support needed, the Snowboard Boots can remain soft and comfortable. Keep in mind that the Best Strap Bindings have ample amounts of wide padding at the toe and ankle straps. Step-In Bindings Step In Bindings It is quite hard to get into Strap Bindings since you need to loosen and tighten the straps every time you get into and out of your bindings. This is why Step-in Bindings were developed. This Type of Snowboard Bindings allow you to simply step down and click into it, thus making it easier for you to get on and off your snowboard. With this feature, Step-in Binding Systems have become quite popular with rental shops because they often give the beginners fewer Snowboard Equipment to fuss with. Still, while Step-In Bindings give you additional speed and can save you from a load of hassle, you pay for these conveniences when it comes to snowboard control. Step-in Bindings don't have any straps to give additional support, making the Snowboard Boot less flexible, and thus, harder to do Snowboarding Tricks. So make sure you get a good fit if you're planning to buy this. Step-in Bindings usually work in combination with soft boots which are somewhat stiffer than those used with highback bindings. When you opt for Step-in Bindings, you narrow your selection in choosing Snowboard Boots and Bindings since they both have to be ""step-ins"". However, there are some higher and more advanced Step-in Bindings out on the market that provide the best of both worlds. Step-ins can be used for either Freeride or Freestyle riders. Cross-over skiers will often feel comfortable with Step-in Bindings and boots since they are used to stepping in and to harder boots and just turning a switch or a latch whenever they want to get out. Flow-In Bindings Flow In Bindings Flow-In Bindings is quite new and is a hybrid of the step-in and strap systems. This Type of Snowboard Bindings tries to combine the control of Strap Bindings with the ease of Step-in Bindings. Flow-In Bindings look rather similar to Strap Bindings and also allow you to use soft boots. The notable difference is that, unlike the two or three straps that cover the top of your feet in Strap Bindings, the Flow-in Bindings have only one large tongue that covers a large part of the top of your Snowboard Boot. Getting into and out of your Bindings is a matter of flipping the highback backwards and entering or exiting your boot. Flow-in Bindings are becoming more popular as the choices and Techniques of Snowboarding improve. People love the Flow-in System as it combines all the advantages of the Strap Bindings with the ease of Step-ins. One disadvantage however is that Flow-in Bindings are more difficult to adjust than strap-ons. Plate Bindings Plate Bindings Plate Bindings, also known as Hard-Boot Bindings, consist of a hard baseplate, steel bails, and a heel or toe lever. This Type of Bindings is used in combination with Hard Boots that can be inserted into the bails. By flipping the lever, the boots are strapped firmly into the Bindings. The features of the Plate Bindings are the closest to a traditional Ski Binding and their rigid responsiveness provides maximum leverage and power for high-speed carving and riding on hard snow. Plate Bindings and hard boots are mostly preferred by Alpine Racers who need the extra edge control that they get from this combination. Baseless Bindings This Type of Bindings was introduced in the mid 1990's by several companies. In Baseless Bindings, the sole of the Snowboard Boot is placed in direct contact with the Snowboard deck by removing the Binding's baseplate. With this, the sole height is lowered by up to 1/8 of an inch. Theoretically, using the Baseless Bindings enhances the ""feel"" of your Snowboard's flex. However, this Type of Snowboard Bindings aggravates ""toe drag"" problems for people with large feet. Also, most Baseless Bindings are far more difficult to adjust (stance angle/width) than traditional ""4x4"" designs. Still, Halfpipe and park riders prefer Baseless Bindings because it provides them with a quicker edge response. The choice of what Type of Snowboard Bindings to use usually comes down to personal preference and finding the right Snowboard Boot first. If you feel that the convenience of stepping in outweighs the additional control you can gain, then it is best to go for that particular Style of Binding. Regardless of which Type of Binding System you wind up with, don't head for the slopes until you know exactly how to get in and out of them. With or Without Highbacks? The large curved piece of plastic screwed to the base of the binding is the Highback. Its main function is to give riders some control over their Snowboard's Heel Edge. These can be found on all Bindings or are built into the boot with some Step-in Systems. Alpine riders who need to perform high speed turns will prefer taller and stiffer Highbacks for greater control and improved edge control. On the other hand, Freestylers will want a shorter backplate for more flexibility and turning power. Snowboard Boots and Bindings form a combination wherein not all Kinds of Bindings are suited for each type of Snowboard Boot. It is often best to buy them together. In here, knowing your intended Snowboarding Style is crucial before buying a combination of boots and bindings. "
Flow M9 Snowboard Binding Logo
131 people viewed this question
Top Flow Winter Sports Experts
Todd Arndt
Todd Arndt
Are you a Flow Winter Sport Expert? Answer questions, earn points and help others
