first, I used Adobe Photoshop CS2 9.0 then updated it to 9.0.2. Installed Eyecandy Plug-ins. It loads properly but about 5-10 mins of work. My computer starts to freeze.
second, I degraded from CS2 9.0.2 to Photoshop 7.0 and installed Eyecandy Plug-ins. Same problem.
Pentium 3 866mhz 512mb sdram 133mhz GeForce 2 MX/MX400 (with the latest forceware 91.47) 1 Seagate Barracuda 40GB 7200 RPM (C:\ 20gb and D:\ 20gb no Virtual Memory) 1 Seagate Barracuda 80GB 7200 RPM (E:\ and is set as 1024 Virtual Memory) 350w PSU
This problem seems to occur everytime, and i am unable to create a single graphics out of Adobe Photoshop.
No. With low system resources, that's for survival :-)
It might be worth resetting the Preferences file (as detailed in the FAQs) just in case they have become corrupt after a crash or bad shut-down.
And do check you have plenty of free space (and the other things mentioned above) Lack of room to breathe will close PS down in no time. If your HD is found to be fuller than expected, do a search for any orphaned .TMP files - they can be HUGE! And remember, no HD should be allowed to become more than 80% full. Otherwise you'll have no room for those dynamic temp files to expand, not to mention your regular defrag taking forever!
Failing all that, Len's suggestion of bad RAM might well be the answer. PS works RAM really hard, and many a stick has been known to fail whilst still working okay with lesser applications.
Was this helpful?
Yes
No
Solution #2
posted on Aug 02, 2007
Duke - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Chrisjbirchall,
Thats for performance, my Adobe Photoshop freezes out of just working on it after a few minutes or by applying a filter. But, thanks, I will do that when my Photoshop is fixed.
Was this helpful?
Yes
No
Solution #3
Bouncy - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
With so very little on-board memory, you need to be careful not to have the amount allocated to PS set too high.
Photoshop ships with the default allocation set to 55%. In your set-up I would take this down to 40% or lower.
If you don't, you will be starving other running apps., eg: Bridge and many of the third party plus-ins which run outside of Photoshop's allocation. Once this happens the OS will start paging out to virtual memory, slowing things to a crawl.
Also, make sure you have at least 10 to 20GB of free, defragmented, scratch space, preferably on a different physical drive to the OS.
Photoshop uses the scratch disk as it's main "memory" with the physical RAM acting as a kind of cache.
Hope this helps get things back on track.
Chris.
Was this helpful?
Yes
No
Solution #4
Horner - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Bob,
EPOX 3VSA Apollo Pro Chipset, I installed VIA Hyperion Pro 5.09A Drivers.
LenHewitt
I used to run Adobe Photoshop CS2 in this same computer before with no problems at all. Although its a bit slow, i still could make graphics out of it. And thats what i'm after. I dont really care about speed that much for graphic designs. Unless i will be using a lot of filters.
Thanks
Was this helpful?
Yes
No
Solution #5
Rank: Apprentice
Rating: 0%, 0 votes
What motherboard? There was problem way back in the day with Asus boards.
Bob
Was this helpful?
Yes
No
Solution #6
Rank: Apprentice
Rating: 0%, 0 votes
Well, you can't expect CS2 to run very well on a Pentium 3 with 512 MBytes of RAM. It really doesn't have anywhere near enough horsepower.
You should be able to run 7 reasonably well (if a bit slow) on it, however.
BUT if the whole system is freezing, that definitely points to a hardware problem - probably a bad RAM stick, but could also be your processor on the way out or a component on the motherboard failing.
Probably time for a new system as it doesn't sound as though the one you've got is worth spending money on.
I can no longer open PM65 files since I am using my laptop with Vista. I am trying to open them in...
(More)
I can no longer open PM65 files since I am using my laptop with Vista. I am trying to open them in indesigncs2 I was able to open them when I had Windows XP I am wondering if this is the difference. I get an error that says file can not be repaired. I have used CD back up and usb cards. Almost all my pm files won't open. Appreciate any help.
I can not print a 40 page layout from InDesign CS2. I can print ads that I have created in InDesign...
(More)
I can not print a 40 page layout from InDesign CS2. I can print ads that I have created in InDesign CS2 but not a layout. The printer starts to process and then goes back to ready mode. I can create a pdf and then send to print, but that takes more time. I contacted HP about their HP Color Laserjet 4700n which is a newer printer thinking that was problem. The files will still not print. HELP! My boss wants the problem corrected ASAP. Mary Van Doren
I have indesign cs2 and need to work on a file created in indesign cs3. To open the file requires...
(More)
I have indesign cs2 and need to work on a file created in indesign cs3. To open the file requires cs3 plugins such as lilo.apun and cellstyles.rpun. Is there a patch? Can I download the plugins? Thanks
Converting a Word file to InDesign to make flash cards. Questions on one side answers on the back...
(More)
Converting a Word file to InDesign to make flash cards. Questions on one side answers on the back side. Three questions per card. Can you tell me how to go about it? Art C
I've heard of this before. I don't have any rogue empty boxes floating around. What else causes...
(More)
I've heard of this before. I don't have any rogue empty boxes floating around. What else causes this? I have serious deadlines and can't figure it out. Please help!
