Question about Lexmark X5150 All-In-One InkJet Printer
My lexmark x5150 printer won't print the last two inches of printing on the right hand side of the paper. how do I fix this?
  • 109 Answers
Is it from every progam/application? If it's only from MS Word for example, it could be your margins.
If it's from all applications, maybe your paper size is set to something other than what's really in there?
Steve
Posted on Feb 26, 2009
Lexmark printer won't print on bottom half inch of page
Make sure to set the correct paper size when printing. Letter - letter; legal - legal size.
Sep 21, 2012 | Lexmark Platinum Pro905 multifunction...
Printer lexmark x5150 not print
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 2600 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
After printing the test page, try to print a document again to verify that the problem is fixed.
Nov 11, 2011 | Lexmark X5150 All-In-One InkJet Printer
It only prints on the left side of the paper. The print fades and then there is nothing on the right hand side. It doesn't matter what you print or from what program, only about 2" prints down the...
1. Take the toner out and shake it side to side so you even the toner level in the cartridge.
2. If this won't fix it, check toner level, might be low. If low, you need to replace toner.
3. Last option, you might have to replace the Photoconductor Unit.
Nov 11, 2010 | Lexmark C543dn 26B0000 Workgroup Up to 21...
X5150 printer turned; no paper in printer; paper feeder continues
Unplug the printer and then open the front and look at the Rear right side and you should see a small ce6913f.jpg
Tab If it is bent then gently with a pencil or pen push it back and try printing if it still gives you problems then contact Lexmark and if you still have a warranty they will replace it if not then you will have to get a new one.
Best suggestion for a new printer that is almost the same is the Lexmark X3550 printer.
Apr 07, 2009 | Lexmark X5150 All-In-One InkJet Printer
Error 0502 on lexmark 5150
does it happen when you want to print? when you want to print u must choose the long way, then select ure printer on the screen (windows office) and print with that, it can be that someone else used your printer,, and changed the options
Mar 21, 2009 | Lexmark X5150 All-In-One InkJet Printer
Printer will only pull the paper in from one side.
Hi !!
Usually this problem happens if there is something wrong with paper feed rollers which is inside the printer .
But to fix teh problem you can try this ---
take out ink cartridges, all the cables, power adapter (black rectangular box at the back) and papers from the paper feeder . Then take the printer in your hands, keep it like upside down and shake it for a while .Then keep it back in its position
Afetr 10-15 mins , install cartridges, cables, power adapter and just 1 sheet of paper on the printer . try to print somethg if still it dows same thg then it means that This is a time to buy a new printer on this christmas !!
Regards
Priya
Nov 25, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark x5150 color printing issues
Sometimes ,poor print quality may be due to ink build up in the maintenance station ..
Your ink cartridges stay in the maintenance station when not in use. Depending on the printer model, the maintenance station may be located on the right or left side of the printer. NOTE: You do not need to remove the cover in order to access the maintenance station.
To access the wiper for cleaning purposes:
Unplug the power cord from the back of the printer.
Move the ink cartridge carrier to the left by gripping the top of the rubber carrier belt and gently pulling it across towards the right-hand side of the printer.
Take a warm, damp paper towel or napkin and gently clean the wiper on the right-hand side of the maintenance station.
Mar 03, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X5150 paper feed problem
the rollers may be dirty or there is a small piece of paper stuck down in one of the tracks or channels..
Lexmark X5150 won't accept paper.
More then likely with it doing that. Something is in the paper path blocking one side of the paper.
Feb 23, 2008 | Lexmark X5150 All-In-One InkJet Printer
Printer has suddenly stopped printing envelopes
Just fixed it thanks to Lloyd at Lexmark.com Go to Technical Support > LIVE CHAT. To print envelopes all I needed was to check the print in "Black" only button. Under Quality make sure the Print Color images in Black box is checked, select Apply and OK.
Jan 16, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X5150 All-In-One InkJet Printer Logo
53 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
