Colors wrong on DVD player
While a DVD was playing on my Toshiba D-RW2SU, the red spectrum disappeared and now all the colors are off whenever I try to play a DVD. This is not the fault of the TV it is playing through as televison programs are fine.
  • 121 Answers
The problem is with the cabling, assuming you are using component cables please make sure that the cables are in the proper locations (red to red, green to green, blue to blue) and firmly seated. There are also issues with using cables of various lengths where the signals to not all arrive at the same time.
Posted on Feb 26, 2009
No sound while playing a dvd or cd in my valor dvd headunit radio has sound just not when i play a dvd or cd
Make sure your cables are in right spot on both..
DVD player (if using the composite cables yellow white red)
on DVD makes sure it says Video OUT and color match
TV look at the back and dont just plug in cuz you see colors. look at rear.
On Back where they are at should say Video 1 2 3 whichever one has the red yellow white cables and say Video IN. match colors then try. should work.
Mar 02, 2014 | Car Audio & Video
Set up to play dvd movie on TV
You just need an RCA cable. Find the output from your dvd and connect to the input of your tv. The cable has three connectors in three colors...red/white/yellow. Res and white is audio and yellow is the video.
Dec 22, 2007 | Televison & Video
When I play a DVD the colors are all wrong. It doesn't happen when watching regular TV.
Check your cable, if possible try another input on your tv. If not your dvd player is gone...
Mar 14, 2011 | Toshiba Televison & Video
Blue ray will not play dvd but will play blue ray samsung db p1500
Blue ray uses a blue laser spectrum and DVD uses the red spectrum. The blueray player must have dual capability to play both red and blue spectrum discs. If it has been and is broken, contact the manufacturer for the 1 year warranty. If it has never played DVD then most likely its not compatible.
Jan 12, 2011 | Samsung BD-P1500 Blu-Ray Player
Color Problem. No red, and none of the colors are bright.
The color curcuit for the red spectrum has blown or has a loose wire. This is the most likely cause of both problems, colors will darken if one color fails because the true color has all three displaying. When one color disappears, the rest seem dull.
I would suggest having the wires on the red relay checked to see if a fuse has blown or whether the wire itself has just blown...
Hope this helps :D
Anymore questions, just ask!
Nov 23, 2010 | Zenith R49W36 49" Rear Projection HDTV
The colors are looking strange when the DVD plays. The colors look blue, neon greenish-yellow, but no reds. The colors are perfect when tv is on, but dvd screen, once movie begins, has strange colors. ...
Try placing the dvd-player as far as you can away from the TV. It may be creating EMI (electro-magnetic interference). Ensure that the wires from the DVD-to-TV are not positioned close to other electronic devices -try moving them.
You say the TV works fine on its own, so that is good; there is probably no big magnet or speaker near the TV.
If it is not anything external causing interference, then yes, your DVD player is probably malfunctioning. Try borrowing a friends..
Aug 30, 2009 | Panasonic DVD-RV32 DVD Player
Spectroniq DVD Recorder SDR-205 Disks do not play with proper col
the remote control doesn't work with new batteries
Nov 16, 2008 | Spectroniq PDV-70X
How do we hook up the D.V.D. player to the T.V. We think we have done it correct but it does not play.
couple of ways but the easiest way would be connecting the video and audio out from DVD (need rca connections yellow red and white)
Yellow --- Video
white and red is audio out left and right.
find in your tv set inputs with similar colors its going to be input 1
or input 2 (as an example)
once you conect the cable matching colors yellow to yellow red to red and white to white make sure you select the same input on your set (video 1 or 2) that its throu input selection in remote control from tv or set itself.
Jul 03, 2008 | Televison & Video
Color problem
CONNECT YOUR DVD PLAYER TO SOME OTHER TV .IF THE COLORS ARE OK ,THEN YOUR TV IS AT FAULT .
THE COLORS OF YOUR TV CAN EASILY BE RE ADJUSTED BY A TV SERVICE MAN.
THE CORRECT RATIO OF RED ,GREEN ,BLUE NEEDS TO BE ADJUSTED .
Jun 02, 2008 | Sanyo DVW-6000 DVD Player/VCR
Viewsonic Projector not displaying RED
Hi there
This could be a problem on the Mainboard - because all the proccessing from your inputs is done on the Mainboard.
Try replacing it , I'm sure you'll have joy then.
Dec 28, 2007 | ViewSonic PJ551 Multimedia Projector
Televison & Video Logo
406 people viewed this question
Top Televison & Video Experts
