Question about LG 32LX5DC 32 in. LCD TV
Ps3 wont work on lg tv with hdmi cable
We have sound but no picture
  • rhettwoodc Feb 26, 2009
    I have done this and it works. But as soon as the movie starts to play the screen says no signal. so as long as your not playing anything it works. whats up
  • 121 Answers
With the PS3 and the TV properly connected and both units off turn on the TV and set the input to the proper HDMI setting then press and hold the power on button on the PS3 until it beeps twice. This should resolve your issue. Please let me know how it works for you.
Posted on Feb 26, 2009
  • Jim Bay Feb 26, 2009
    It would seem that others have had a similar issue but have stated that the pictures comes back and stays after about 5 minutes. Is this true with your system as well?
    I realize this is no solution and certainly not an acceptable situation but there are really big HDMI issues going on here as you can see by reading the Playstation websites troubleshooting section.
How do you use PS3 and DVD player with the Toshiba 32Dtu2 LCD TV?
The PS3 can be hooked up to the tv using either a HDMI cable or the old RCA (Yellow, Red, White) cables. If you are having problems viewing a picture or hearing sound, here is some trouble shooting you might want to try.
Connect the PS3 using both the HDMI and RCA cables. select the HDMI input on your tv. turn on the PS3. If you cant see a picture, press and hold the power button until you hear 2 beeps (this will take about 15 seconds). This resets the PS3 to the old RCA cables. Select the RCA input on your tv. Hopefully you can see the image and hear the PS3 now. Go to the settings on the PS3 and change the display settings to output video through the HDMI. Remember, your tv can only go as high as 1080i resolution, so you wont see anything if you select the 1080p resolution.
If this didn't work, you might have a bad signal though the HDMI cable. Unplug the tv and PS3 for atleast 30 minutes, and then connect the PS3 to the tv before you turn either one on.
If this doesn't help, then you might have a HDMI cable that isn't recognized by either your PS3 or your tv. Try replacing your HDMI cable.
Hope this helps!
Sep 19, 2011 | Toshiba 26HF84 26" TV
My samsung tv wont connect to my ps3 through the hdmi cable, the tv works if i connect my laptop or anything else to it. iv tried my ps3 on my lg an it work just fine just cant get it to work on my samsung...
When you have PS3 connected to the TV with HDMI connector, hold the ps3 power button down for 5 seconds, when u hear 2 beeps, release it and it should display standard format on the TV, thats when you'll get the option to correct the picture mode for the PS3. Hope that helps.
Dec 23, 2010 | Samsung LN52A650A LCD TV
I am having connection issues with an LG 55lh40 television, a HD DVR from Directv, a PS3 and a DVD/VCR combo. The TV seems to be working good, but does not seem to be picking up an HDMI cable of any kind....
No picture
when connecting HDMI:
Check HDMI cable over version 1.3.
The HDMI cables don’t support HDMI version 1.3, it cause flickers or no screen
display. In this case use the latest cables that support HDMI version 1.3.
Feb 14, 2010 | Televison & Video
How would i know if my HDMI ports are working or not?? Tried to connect a PS3 to it but nothing. Thought it may have been the cable so checked someones that i know is working and still nothing. Checked...
As you already checked PS3 and HDMI cable,
select HDMI input in TV and connect PS3 via HDMI cable. TV should show PS3 picture.
And if still no joy then HDMI input port in TV is bad and need to replace input board/ main board.
Jul 08, 2009 | LG M227WD-PZ LCD TV
PS3 - Sony Reciever HT-SF2300 - Aquas A83 LCD TV
Make sure you have selected the HDMI output option in the PS3 menu, otherwise you will get no picture or sound, connect you standard cable to your tv first which came with PS3 to do this first.
Nov 25, 2008 | Sony Playstation 3 (PS3) Console
No sound through ps3 hdmi
I have sound on video 2, and when on a static channel but not on the usual channel 3 which is TV. Just stoppen working one day and cant figure it out... Please help!
Oct 19, 2008 | Televison & Video
Compatibility ps3 lg rz32lz50 tv
Sounds like your DVI converter. DVI provides picture only, no sound. If your TV has an digital optical input socket, it's best to connect PS3 to TV using this, then digital stereo sound should be yours..
Sep 06, 2008 | LG RZ32LZ50 32 in. LCD Television
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
Jan 08, 2008 | LG 42LC2D 42 in. LCD HDTV
Hdmi
I can't be exactly sure without more information, but it sounds like you ps3 is outputting from another port. My ps3 originally was outputting from the component/composite cable port so in order to use the hdmi output I had to do a soft reset. That makes the ps3 sense what cable is plugged into it and automatically output through that port instead of using whatever is the saved setting.
With your ps3 turned on hold down the power button for a few second until it beeps and flashes 3 times (should be about 5 seconds). You might have to try it a few times to get it to work, but you should get picture and be able to adjust the settings on the ps3.
Dec 08, 2007 | Sony Playstation 3 (PS3) Console
LG 32LX5DC 32 in. LCD TV Logo
719 people viewed this question
Computer Repairing
Computer Repairing
