Question about Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
SALUDOS, ESTOY EN VENEZUELA, TENGO UNA ASPIRADORA Shop-Vac QSP plus 8 GALLON Y NO CONSIGO EL FILTRO DE CARTUCHO (903-04) NI LAS BOLSAS DESECHABLES (906-71). ES URGENTE. GRACIAS. MI Email: gusmary88.gustavo@gmail.com
  • 547 Answers
Http://www.shopvac.com/parts_pdfs.asp please go here for replacement part's or customer service
Posted on Feb 26, 2009
Where is the circuit breaker on a wet/dry shop vac
There is a thermo fuse in the field winding under the tape. When it overheated the fuse went bad.
Apr 07, 2013 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
Is the shopvac qsp 10 for water
yes it is wet and dry cac go to link below for deiails
http://www.shopvac.com/pdf/Shop-Vac-QSP.pdf
Nov 08, 2012 | Vacuums
How can i replace or unclogg the hose ?model qsp 8
Remove the hose and lay it straight. Then using a broom or mop handle, push it into the hose and collapse the hose on the handle as far as you can. (Think crinkling your socks to pull them over your feet). You'll be doing much the same as you pull the hose up onto the handle. If you have no resistance from one end, then do the same things from the other end. Then replace the hose onto the vac and turn on the power. Your pushing with the broom/mop handle should dislodge whatever is caught and the suction from the vac should pull it through the rest of the way. I hope this helps. If so, please rate my solution. Good luck!
Dec 22, 2010 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
Can't find manual
ask your local vac shop,they should be abel to get you one. they can help with any questions.
Oct 23, 2009 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
On the back of the shop vac there's a hole...what is supposed to go in there...i turn it on and dust blows out of it like crazy
should have a exhaust filter in the hole. it is round and 5-6 inches long with a type of filter on the end.
Oct 22, 2009 | Shop Vac Shop-Vac 905-65-00 1-1/4" by 8...
Craftsman shop vac no power when turn on
I just picked up a similar model someone was throwing away. turns out there is a thermal fuse inside the motor housing that blew. I just need to find the values of the fuse and repalce with appropriate size. motor runs when fuse is bypassed.
Apr 14, 2009 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
Need new switch for Shopvac QSP Pro 10 gallon unit
I just went through the same problem with a Shop Vac. The switch is easy to replace but not easy to find. After removing the switch, I found a match made by Sigma Switches. They directed me to contact a local RV dealer and look in either their Coast Supply or Stag/Parkway Supply catalogs for the appropriate switch (an H2-28 in my case for a QPL45 Shop Vac). After ordering the switch and $5 later, it snaps in like the original with no problems. Certainly beats $70 for a whole new motor assembly.
Dec 28, 2008 | Shop Vac 285-00-10 Back Pack Vac Wearable...
Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum Logo
188 people viewed this question
Top Shop Vac Vacuums Experts
Roger Potts
Jim Parker
Jim Parker
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
