Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Oil leaking underneath washer. Whirlpool
At times when we look underneath the washer there is quite a large amount of oil on the floor. I have heard I need a seal and would also have to replace the belt. Any comments ????
  • 135 Answers
Your washer does not have a belt. Your gearcase is the trouble, part # 3360629. Hope this helps!
Posted on Feb 26, 2009
Water Leaks Underneath
You really need too look underneath and see where water is coming from that means raising the machine off floor washing machine quite heavy so need to know what your doing
Nov 09, 2015 | Whirlpool WFW9050XW Washer Front Load...
Water is leaking onto the floor underneath my Whirlpool Cabrio (top-loading).
If its a small intermittent leak from the front left corner its the tub ring, whirlpool has redesigned the tub ring to fix this concern..
Sep 19, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Leaking whirlpool washer
Probably the pump seal - you need to replace the pump, which is located at the front.
Apr 20, 2010 | Whirlpool LSR5132PQ Top Load Washer
Ultimate care supreme leaks underneath
First check the hoses to the machine. If they leak the water follows the hoses and drips on floor. Also check the hose connection at the washer. They will leak inside. Next it may well be a water pump going out or the plastic hose that is under pressure when operating. The pump is in the middle of machine underneth - Sorry - Good luck
Oct 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
I have an oil leak on my clothes washer.
If you have a front loading washing machine the oil is really the grease for the bearings that support the drum. The grease seal needs to be replaced, and if you are replacing the seal you might as well do the bearings. This is not a cheap repair because of the amount of labor involved in tearing the machine apart to replace the seal and bearings. If you don't repair the seal, eventually the grease will be washed out of the bearings and the bearings will be destroyed. You can tell if you need new bearings because when the machine is on the fast spin cycle it will sound like a jet engine taking off.
May 24, 2009 | Washing Machines
Washer will agitate and drain but not spin; some oil underneath cabinet
Coupling may be bad bad the oil is coming from your transmission. It may already be locked up but certainly will eventually as oil gets lower. No real way to fix but to replace transmission.
May 18, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Oil leak under washer
if its an old ge it needs a transmission seal
Apr 24, 2009 | Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
200 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
