Home | Canon | EOS 30D Body Only Digital Camera | Canon EOS 30D exp...
Canon EOS 30D Body Only Digital Camera
Problem for Canon EOS 30D Body Only Digital Camera
Canon EOS 30D exposure metering not working
By steve_kosica on Feb 26, 2009
My wife dropped the EOS30D together with a Speedlite flash gun - and initially the only damage appeared to be the broken hot shoe foot on the Speedlite. To my alarm I have discovered that the exposure metering on the camera is not working as expected. In all full or semi-automatic modes the camera wants to use an exposure in excess of several seconds. The exposure varies dependent on whether the camera is pointed at dark or light subjects, so there still seems to be response from the sensors, however it appears either the metering sensor or the electronics are providing confusing data... I came to this conclusion after trying out various other lenses I own and with any of these the camera stillexhibited the same problem, i.e. I have eliminated the possibility of the fault being caused by a damaged lens.
I can use the camera in manual mode, which is quite annoying so I might have to send the camera in for repair. On the other hand, given that the expected cost of repair might far exceed the camera's re-sale value, and being a bit of a technology geek myself, I was thinking about attempting to fix this problem on my own. I expect the only thing that could have happened when the camera fell is that either some circuit connection or the sensor itself got dislocated. I doubt the camera being dropped would have actually physically damaged any component inside, as these are usually firmly fastened with screws and especially as there are no marks on the surface of the camera indicating any problems whatsoever.
If there is anyone out there who could point me in the right direction, i.e. where is the exposure sensor and ambient light sensor located and where are the circuits processing the signals these sensors produce. I did find a good disassembly guide here: http://mbignell.com/2008/08/02/disassembling-the-canon-eos-30d/ so that could be the start of it..  Any help or information is much appreciated!
Cheers,
-Stefan
Comments:
Feb 27, 2009
- Same thing, just did a test shot in my study. Normally would have expected the flash to pop out, however all I got is a 2.5 second exposure.
Clarification Request
Posted by JohnLeF on Feb 26, 2009
What happens on full auto - does the camera take reasonable pictures then or still over-exposed?
Best Solution
posted on Jun 30, 2009
Very Helpful)
pepeik
Rank: Apprentice
Rating: 100%, 2 votes
your ae sensor which is loacated on top of the pentaprizm , the reflex box , it has becomed unglued , it is located right in between the wiew finder and the reflex chamber
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Nov 05, 2009
Not Rated)
sashabphoto
Rank: Apprentice
Rating: 0%, 0 votes
I an experiencing the same problem, how was the problem fixed?
Was this helpful?
Yes
No
Solution #3
posted on Aug 24, 2009
Not Rated)
birnbacs
Rank: Apprentice
Rating: 0%, 0 votes
Follow any guide on the net for repairing/cleaning a broken trigger button for disassembling the 30D. You will need one small PZ screwdriver and possibly a toothpick or the like.
The AF sensor can be seen on this very helpful picture: http://www.flickr.com/photos/andygock/3332063787/sizes/o/in/photostream/ . It is the orange item with two black dots and an orange connector that runs from top of the view finder past the view finder focus wheel to the right and underneath the green plastic adhesive patch.
Hint1: use a two-component glue so that evaporating dissolvent from the glue will not condense on any optical part. Especially, do NOT use superglue, it will produce extensive white condensation. Transparent 5-minute-epoxy seems a good choice.
Hint2: use PostIt stickies "bottom up" to stick all the different tiny screws to and label them according to where you found them.
Was this helpful?
Yes
No
Popular Solutions for Canon EOS 30D Body Only
Questions and Unsolved Problems for Canon EOS 30D Body Only
Do you recommend Canon EOS 30D Body Only Digital Camera?
Answer
Answer
When I try to view images on a tv the connection in the camera does not hold and the image does not... (More)
Answer
Describe your how to fix the light meter inside canon 30d slr Problem
Answer
after cleaning the sensor (with a bulb air cleaner) the high-speed setting no longer works correctly... (More)
Answer
after beep sound of focusing,shutter is not clicked
Answer
Same thing, all images are extremely over-exposed. When using flash, however, exposure is (more or... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon EOS 30D Body Only...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 881
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
