Question about John Deere Garden
Mower runs for 10-15 mins. then shuts off.
I CAN MOW FOR 10-15MINS. AND ENGINE STARTS TO SPIT AND SPUTTER. IF I DISENGAGE THE BLADES THE ENGINE RUNS SMOOTH FOR A MIN. THEN SHUTS OFF.
  • 3 Answers
I would agree with the gas cap being the problem. There should be a insert inside the cap which helps with the tap pressure. If this is lost then the engine will run for a few min. and shut off.
There is one other thing and that is the float in the carb bowl. It may be allowing in just enough gas to fill the bowl and then it is sticking. This would account for just enough fuel to run for a brief period and then shut down.
VTX Guy
Posted on Mar 10, 2009
  • 3 Answers
Check your gas cap. There must be a vent for the gas to flow joedog
Posted on Feb 26, 2009
Mow for 30-60 min.mower shuts down. Sometimes you can mow all day.start goin up hills mower will shut down,about the second or 3rd trip.what's the problem?
Don't know what kind if engine you have but many have low oil shut down float switches inside the engine..when operating on hills or side if hills too long the oil will flow to the low side and the low oil switch will pick it up as low oil and shut it down..look for a small wire attached to the crankcase it most likely is that low oil switch..the next time this happens try disconnecting it and tape the end if the wire..try starting and run on the hill..it should not shut Down..just remember it is a safety switch to protect the engine from damage from low oil operation.try running the hills where the oil runs to the wire side of the engine..won't trick the low oil alert...Good luck..
Aug 08, 2015 | Garden
Pto won't engage blades
ether switch bad fuse blown behind dash or pto bad if pto 300.00
Sep 12, 2014 | Troy Bilt 25HP VTwin Hydrostatic 50" Cut...
I was mowing with a timecutter 4200 the blades stopped and won't restart what do i do
check fuses and then start testing the wiring and clutch
Sep 12, 2014 | Garden
I have a 18.5 Poulan Pro riding lawnmower that runs fine untill I activate the blades. It then dies after mowing for a few minutes. I disengage the blades and it runs fine. Any solutions?
does it loose power then die or just shut off?does it run rough then die?try and run it with the gas cap loose th event could be plugged and the extra fuel needed to mow the vent might not be keeping up or a plugged fuel filter
Jun 06, 2012 | Garden
My riding mower keeps shuting off after using it for a little while
try and run it with the gas cap loose maybe the vent is plugged
Apr 28, 2012 | Garden
Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
May 14, 2009 | Mtd Garden
Blades will not operate
Hi..my name is Keith..i dont know how new your mower is..but on the fairly new to new ones..there is a safety switch on the reverse that will shut the engine off if your try to mow in reverse...and thats the one that sounds like its at fault..i hope this has helped
Apr 11, 2009 | Garden
Mower runs for 10-15 mins. ands shuts off
I had the same problem on my craftsman 18.5 hp, the problem was in the choke, the spring was broken, and the choke was not free, replaced the spring and it is fine now. Check it out. Good luck.
Feb 26, 2009 | John Deere Garden
Garden Logo
585 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
