Question about Belkin (F5D72304F5D7000) Router
Macbook loses wireless internet connection
I have a Macbook that connects to a Belkin F5D8233 router wirelessly for internet access. Everything connectivity-wise works fine until my wife connects wirelessly with her Dell laptop. As soon as she does, I lose my internet connection. This happens every time. Anyone have any suggestions?
  • msivicak Mar 01, 2009
    Thanks for your help. This appears to have fixed the issue we were having.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 66 Answers
Hi 8233 is a good choice for a router
Here's your solution
1. These steps are to be performed strictly from a computer which is wired.
2.Even if you are using your mac book turn of the airport and connect it via a cable.
3. Open your router setup page by typing in 192.168.2.1 on your browser tab or typing i http://192.168.2.1 in the run window
4.An rsp will open and on the top right hand corner of the screen it will say Internet status:: connected
5.On the left hand side change you"ll see channell under wireless
6. Select it and change it to 6 or 11 for best signal strength
7.Now to the most important segment 8233 has a piculiar issue with its extra strong security
8.On the left hand side under wireless you"ll will see an option called wi-fi protected setup
9.Select it and turn it off reboot router and wow the problem should definately be resolved .
Then turn on airport and go wireless along with your wife.
10. You will still be secure with your data through security option on your router (wep or wpa )whatever you use .
Thank you and just let me know if it worked or not
Posted on Feb 26, 2009
I have a Belkin N wireless router. It's all set up but it shows as not being secured. How do I secure it? Model F5D8233-4v3
Connect a LAN cable from Belkin to your laptop/computer's LAN port, open a browser on your laptop/computer and enter the Belkin's configuration URL. http://192.168.2.1
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings to protect your wireless network and Internet from unauthorized access. Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jan 08, 2013 | Belkin Computers & Internet
My belkin n series keeps losing internet connection hard wired to my computer and three wireless computers in the house. when hard wired to the virgin broadband modem everything works fine
I would suggest taking a look at your modem LEDs. What happens exactly when you lose connection? A look at the LEDs should give you some thought as what might be causing this. You can also try resetting your Belkin to default factory settings by pressing the Reset button at the back for 30 seconds, and then putting back your Belkin settings.
Nov 16, 2010 | Belkin N1 Wireless-N Wireless Router
Belkin Nimo wireless router internet drop outs
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? Ie. change the default password, setup encryption use WAP2 or WAP, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, ard welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply) .
4. Check the channels of the wireless routers and access points in your area and and change the broadcast channel on your wireless router to an unused channel or one that has the weakest signal strength. This will minimize the interference with your wireless router from the wireless routers and access points in your area.
Sep 29, 2009 | Belkin (F5D5231-4) Router
Belkin N Wireless Router - wireless light no longer lit up
Just in case it helps anyone else, I just had to toggle between broadcasting SSID and fixed the problem.
Jul 02, 2009 | Belkin Wireless-N Wireless Router with...
F5D8233-4v3 - Belkin Wireless Router
You must configure the wireless settings of the laptop manually. It should match the wireless settings of your router. If you have wireless encryption enabled, make sure to type the network key on the wireless settings of your laptop.
Jun 29, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
I need to make our internet connection secured
this link should show you the steps to securing your wireless connection:
http://www.belkin.com/support/article/?lid=en&pid=F5D8233-4&aid=10177&scid=0
Feb 18, 2009 | Belkin N1 Wireless-N Wireless Router
Wireless Router use with Wildblue Satelite Modem
You should be aware of a class action lawsuit that Belkin and the complaintent settled recently. The lawsuit was filed complaining that certain Belkin routers did not obtain optimal speeds as advertised.
Belkin has agreed to provide affected customers a discount program to purchase a new router. You will need to search elsewheres for the details.
Sep 28, 2008 | Belkin (F5D5231-4) Router
Belkin (F5D72304F5D7000) Router Logo
1,990 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
