Question about Philips 55PP9363 55" Rear Projection HDTV-Ready Television
Fly back is arching and leaking
I have pulled the board to replace the Flyback/splitter assembly but cant seem to find the part any where.I do have the part number: HVG/32865.I was wondering if someone could help me find it?Thanks in advance.
Hi, i'm having a similar problem and was wondering if you ever got yours fixed? i've found the FBT, it's located on the bottom right side as you're facing the back of the TV and it has 3 red wires coming out the top. mine, i've noticed, sparks once when the tv is turned on. i can't find a replacement part for under $300. any suggestions?
Posted on Feb 01, 2011
I have a sony kv 21gdr2 i have replaced the fly back bec when testing flybck def wth the new flybck still arching but new
the fly back is defected although it is new take it out and return it back to where you bought it from.if after you put a new one in and it does the same check the diode that leads from the B + it might be shorted.your flyback to get damage and arch again.
Mar 06, 2011 | Televison & Video
My power button does not stay on (the green lamp)when turned on from the remote or the unit. I checked the fuses on the main circut board and the have contineuity. help model vs-50609 mitsubishi rear...
Could be h.v. splitter.pull the lead coming from the flyback that enters into the h.v.splittter. Put lead in a quart jar and turn the set on and see if you hear a hissing sound, if you don't see a blue arch also. If set stays on then h.v.splitter is bad.
Jul 07, 2009 | Mitsubishi VS-50609 50" Rear Projection...
Cant disconnect two red cables inside my panasonic projection tv
I'm assuming you mean the high voltage lines.
All you have to do is reach in to the front block' and grasp the red line that goes to the flyback.
Do not attempt to remove the fly back side.
Just be careful not to bump the CRT's.
Slide the boot off and pull!
Jun 16, 2009 | Panasonic PT-47WX53 47" Rear Projection...
No power rca d52w19
The problem is not with the mail filter board as that only supplies standby voltages to the chassis. If the led is blinking 3 times the most likely scenario is the flyback , Thats why the clicking from flyback coincides with the led's blink. If you look on the deflection board ( where the flyback Is) at the top of that board there is a u shaped heat sink that has CP150 in side the "U" chances are the top of that capacitor will be budged and possibly CP114 as well see photo below.d7cce32.jpg
Mar 14, 2009 | Televison & Video
My Flyback is burned, questions!
You can get the flyback at the following link and they will provide free tech support to help you with it as well as instant messageing tech support to help you remove the board and the Flyback wires. Its a very easy repair and it doesnt require fine detail soldering what so ever. You need flyback 259296 they will also answer any question you have by leaving them an email. heres the link.
http://servicemanuals.vstore.ca/
May 26, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
Krazy colours
Hi if picture is of it could be convergnce ic and that would require a tv tech cost is 250.00.
But the arching noise is usually your high voltage arching from fly back or spiltter you could take off back be careful it is very high voltage only do if you now this stuff, and you will see it arching when it is on and where ever the arc is coming from is the problem the fly back is a large transformer and is black with red high voltage lead coming out of it the leads could be bad to.
the splitter is where all the leads go into from tubes. i hope this helps cost to fix for tv shop is 350.00. thanks doctor video
May 04, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Rca scenium hd52w140 wont power up.... again
Sounds as if you'll have to replace the regulator and filter cap for it, at the very least. You may have taken out the flyback again, as they're not very hardy when driven with too much AC bias. The arc that you are calling a spark will have to be addressed also. If you have an intermittent connection at that point, the feedback voltage will be incorrect and you'll have the same scenario on dealing with a dead set once again. Hope this helps....accordianman
Feb 19, 2008 | Televison & Video
Blurred pic on tv
you can take the back off find your flyback (the big part with a red or pink wire going to the picture tube) and adjust the small pot or potentiometer closest to the top while the set is on in front of a mirror and try adusting the focus control.
if cant get nothing but blur replace the fly or focus assembly if not built in the fly. I would change both.
Jan 26, 2008 | Hitachi C21RF39 21" TV
Philips 55PP9363 55" Rear Projection HDTV-Ready Television Logo
254 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
