Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Installed new soap dispenser; forgot to mark wires
I installed a new soap dispenser on my Frigidaire Dishwasher model FDB1250REC2, but forgot to mark which wire goes where on the actuator. One has a red wire, one has a white wire. Which one goes on the front prong and which one on the back prong?
  • 70 Answers
It does not matter. you can place them either way :-)
Good Luck!
Posted on Feb 26, 2009
Soap door opens during cycle, but soap does not dispense??
Hello Eric, thank you for your post!
I understand that the dispenser on your Frigidaire dishwasher opens but the soap is not dispensing into your dishwasher. How old is your dishwasher soap? If it is around a year old you may need to discard it and use a new soap. Also check to make sure when you stack dishes that they are not obstructing the arms from reaching the dispenser. Make sure your spray arms are clear of any debris that could block the distribution of water inside of your dishwasher. You may need to connect with a professional technician for proper repairs if these steps do not correct your issues. I hope this information is helpful to you. -Matt
Aug 02, 2015 | Frigidaire Dishwashers
I have a Frigidaire Dishwasher Model # FFBD2411NS0A. It cycles but does not clean AND the soap dispenser does not open during cycle. Im handy but not an electrician. Is this a power issue or.....?
You will need remove the door panel and look at the device directly behind the soap dispenser. It will have 2 wires to it. If the wires look OK and not unplugged, that little device will probably need replaced. Thats what opens the soap cup.
Feb 22, 2015 | Frigidaire Dishwashers
Good afternoon Derek, I appreciate your post!
I understand that you are experiencing an issue with your Frigidaire dishwasher not cleaning and not dispensing soap. This may be a possible issue with your dispenser, water, or soap. I would suggest when you load your dishwasher to make sure no plate or stemware is blocking the dispenser. Also if the water pressure coming into your dishwasher is not between 20-120 PSI it will not provide enough pressure to open the dispenser or dissolve the soap. The water temperature should be above 120 and below 130. If you review all these troubleshooting steps and continue to have issue it could be a possible problem with your spray arms or motor. I would then recommend seeing assistance from a professional. This may help you avoid unnecessary part purchases. I hope this information is helpful. -Matt
Dispenser door will not open
Hey friend, thank you for the post!
I understand that your soap dispenser door will not open on your Frigidaire dishwasher, LGBD2432LW0A. You could possibly be seeing an issue with soap dispenser not getting water into it to release the soap from dispensing. I would check to make sure there are no dishes blocking or obstructing the soap dispenser. You could also remove the soap dispenser to clean it and make sure there is no buildup of any previous detergent remaining that would cause the door to not open. If those steps do not solve the issue it could be a problem with the dispenser and I would recommend having a tech come out to the home to properly diagnose and repair the dishwasher. Hope this is helpful. -Matt
Jul 28, 2014 | Frigidaire Dishwashers
I just bought a brand new dishwasher and the soap dispenser opens but the soap is still in the dispenser clamped up like sand. It doesn't happen every time. The same thing started happening with my old...
Try using the soap tablets instead. The frigidaire units use a small cylinder to actuate
the soap dispenser and if just a little too much soap is used the latch will bind and not
release. Alternatively, make sure the dispenser is only about half to 2/3 full if you need to
use powder detergent. This is a common problem with the frigidaire/ whirlpool/galax/kenmore
models. Hope this is useful.
Apr 04, 2011 | Frigidaire Dishwashers
Soap dispenser flap (door?) does not open during cycle
Be sure that the lower rack is installed correctly, If reversed, the rack will block the soap door shut. One side of the rack has opening for the door.
Sep 18, 2010 | Frigidaire Professional Series 24 in....
Soap dispenser doesn't open for wash cycle
I noticed you didn't rate out chat and saw that your problem was posted. I'm happy to continue to help you if you encountered problems or were not happy with the solution in your chat session.
Jul 07, 2008 | Frigidaire FDS251RJ Free-standing...
UNDISSOLVED SOAP RESIDUE AND
Dispenser door sticking. Run it a few cycles by putting the tablet in the cutlery basket.
Mar 22, 2008 | GE 24 in. GHDA986KSS Built-in Dishwasher
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
97 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
