Question about Technics SL-PG480A CD Player
CD's which I burn come out distorted on the technics player. This has happened since I got it serviced. Can you recommend a brand of disc which will work?
    Genius:
  • 1,148 Answers
TRY A LASER LENS CLEANER,,CHANGE UR RCA JACKS TOO
Posted on May 15, 2009
I have a Technics CD changer SL-PD867 it will not play re writable disc's any other disc ok
Not all CD players can or will play CD's burned in a PC. Sometimes the CD player is to old, so not compatible with these CDs. Sometimes the player just does not play these CD's, because of rights protection.
A CD burned in a PC is less reflective than an normal music CD. Normal CD's do have a metal coating and are highly reflective. Burned CD's have a dye, and where the laser burned the dye, it only changed colour. Making it less reflective.
All modern CD playes should be capable of playing CD r's. But the player that is really compatible, is labelled CDr and CDrw compatible.
May 11, 2014 | Technics SL-DZ1200 CD Player
My Technics SL-PD987 5-Disc, does not read CD any more. First did not read burned CD, after did not read original CD.
Power the unit off. Unplug it. Press the power button for 30 seconds. Plug it back in and try again.
If this doesn't resolve the problem, I recommend a CD cleaner. This is a CD that has a small brush attached. It will clean the dust from the laser reader.
If this doesn't work, I'd suggest a professional repair shop.
Apr 15, 2011 | Technics SL-PD987 5-Disc CD Changer
I burned a CD on my PC to keep in my car and it plays OK in the car and on my PC, but does not play on my Technics SL-PD687 5 disc cd player. It's recorded in *.cda format and it's on a CD-RW. Any...
The problem with old CD Players are that they sometimes are a little fidgety when it comes to reading CDRs.
You could try burning a new CD on the lowest possible setting, say 2x or 4x.
Also try changing the CDR brand as some cheap CDRs are prone to not reading in old CD Drives.
Try using a regular CD-R (CD recordable - record only once) instead of a CD-RW (CD rewritable - rewrite multiple times). CD-RW use a different "ink" to write the data to the disc and can be re-recorded/erased a couple of times before it loses its ability to write effectively to it.
Mar 05, 2011 | Technics SL-PD687 5-Disc CD Changer
I have burnt a bunch of CD's for my Sony CD player. It holds approximately 400 CD's. It seems that last few songs on the burnt CD's are played with a lot of distortion. They have become progressiveley and...
I've had the same thing happen to me.
Minute variations from one machine (or disc) to the next would explain the different results. As the CD standard allows for error detection, correction and concealment as required, one machine may be exhausting its capabilites while the next is either correcting or concealing the problem inaudibly.
Try this: If your source material is not available for a new burn, COPY one 'bad' CD to a fresh disc CD-R (data disc) on your PC. The data copy process is not in real-time like music burning or listening is, so the PC may be able to retry and correct data errors in the source and write perfect data on the copy. If the PC can't read the data it will fail right away, but it will retry it a few times before giving up..
However, if the brand of media you're using is the problem you might just be making another copy that will degrade with time. No maker is immune to bad media. Sometimes one batch will have a problem while others won't.
Feb 04, 2011 | Audio Players & Recorders
Technics SL-PD888: Output signal is distorted/overdriven.
I can't find a manual. If it has both analog and digital outputs, compare both for sound quality and report the results. Also try them on different INputs of your electronics to eliminate that as a problem.
Let's examine THAT side, too. What are the components involved and how are they connected?
Feb 21, 2010 | Technics SL-PD888 5-Disc CD Changer
What the E-20 showing on my cd player
Hello! The "E20" error code loosely means that the CD player cannot focus, or read the disc properly. This could be from a number of reasons, dirty pickup lens, dirty/scratched disc, excessive humidity, or using a burned/copied CD that was burned at a speed that was too fast to provide a "deep" enough burn to the disc. And lastly, I know GM's Delco radios in the late 90's had issues reading CD-RW's; but read CD-R's fine (if burned slow enough)
My first suggestion would be to see if this happens on all CD's - originals and/or burned ones. If it only happens on burned/copied discs - I'd recommend slowing down the burn speed to no faster than 16x and retrying. If it does happen with both types of discs, then I'd purchase a CD lense cleaner and run that through a couple of cycles.
Hope this helps and good luck! Thanks for using FixYa!
Sep 26, 2009 | 1997 Pontiac Bonneville
CD doesn't work. LED readout says FRMTREAD, error 12. ;what's happening?
If this error appears on any music CD (burned or store-bought), it's likely the laser/lens assembly is having trouble focusing well enough to read the disc. You can try resetting the unit (use a paperclip or ballpoint pen to press the button in the small hole next to the eject button), but there's only a small chance this will help. You could also take it to an electronic repair shop to see how much a cleaning would cost (usually more than the player).
If it only happens on burned discs, try changing brands of CD-Rs or even burning the disc at a slower speed. If the songs are burned from iTunes, try burning other formats (i.e. MP3) via a different method.
Mar 16, 2009 | Pioneer DEH-P6800MP CD Player
CD's come out distorted on the TECHNICS SL PG 580A
TRY NEW RCA JACKS AND TRY BLOWING IT OUT,,GET YOU A LASER LENS CLEANER
Feb 26, 2009 | Technics SL-PG480A CD Player
Cdj 800 error 8301
Error Code
E-72 01
E-83 01
E-83 02
E-83 03
E-91 01
Description
Player unable to read TOC data.
Disc is rotating, but rotation cannot be ascertained.
Player unable to play back currently inserted disc.
Mechanical operation has failed to complete within
specified time interval.
Possible cause and recommended action
Disc is cracked.
= Recommended action: replace disc.
Disc is soiled or dirty.
= Recommended action: clean disc.
If other discs play normally, the problem is with the disc itself.
Dust or some other form of foreign particles have found their
way into disc insertion slot.
= Recommended action: remove dust or other foreign particles.
Error Type
TOC READ ERROR
PLAYER ERROR
MECHANICAL TIME OUT
Jun 11, 2008 | Pioneer CDJ-800 Turntable
Distorted sound when playing CD
have you tried cleaning the cd lens ?insert a lens cleaning cd , follow the voice instructions and your cd player will be as good as new.HAPPY LISTENING.
May 30, 2008 | Technics SL-PD687 5-Disc CD Changer
Technics SL-PG480A CD Player Logo
55 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
