Question about Hotpoint Refrigerators
I can not find the freezer temperature control
I have a hotpoint model ctx14cyxkrwh and I see the fridgerator temperature control in the fridge, but see not temperature control for the freezer. Can you help?
  • 410 Answers
This model refrig does not have a seperate freezer control. the only control will be the refrig control. thanks peyton
Posted on Feb 26, 2009
I have a GE Hotpoint fridge Model CTX14CAXKRWH. Freezer is over freezing & main unit warm/wet with condensation. Is this a thermostat issue? Is it even worth replacing in a unit from 1994?
Check the freezer fan motor if one. Also check the doorway that allows freezer air into the refrigerator part for proper operation.
Feb 22, 2017 | GE Refrigerators
Hotpoint frost free fridge freezer the fridge not working but freezer is
Hi Reginald
Most refrigerator / freezer units chill the fridge area by venting some fraction of the very cold air from the freezer into the fridge compartment through a channel that has a mechanical air valve in it. In this way, it can control the chilled air flow, and aim for the set temperature, all the way down, in some cases, to freezing, or even colder, on the fridge side.
That vent unit, depending on your model, sill be somewhere in the wall that separates the freezer from the fridge. What can happen is that moisture condenses into the louver that slides to control the airflow, it freezes, and then system is stuck, since it's cold on the freezer side, and this keeps the louver frozen stuck. If that is the case, shutting the unit off for a while may recover function, though getting it to where ice is melting in an interior wall may be more risk of food spoilage than you'd want. Otherwise, use a search engine to look for 'how to test freezer / refrigerator vent in make/model', and you'll likely come across all sorts of youtube and step-by-step tutorials.
Good Luck!
D
Nov 30, 2015 | Hotpoint Refrigerators
Not Cooling properly...The dial at bottom left side of fridge---if I turn it will it help in cooling fridger more??
First the levels should never be set to the highest level? as this only stresses the compressor and runs to much cold air in only 1 compartment. If u have a cooling problem I would check my thermistors fridge and freezer side but check at very cold temperature not at room temperature. and check for continuity and for the OHMS rating as well according to ur schematic. also check ur cold control thermostat. and air flow control damper
Mar 21, 2015 | Hotpoint Refrigerators
Hot point fridge freezer CTX14CYXKRWH
have the thermostat checked as it sounds like it is not working
Oct 07, 2013 | Refrigerators
Freezer high temp light is on. So is fast freeze. It's been plugged in at least 24 hours but not freezing.
FREEZER HIGH TEMPERATURE WARNING LIGHT DOESN'T GO OUT.HOW TO CANCEL OR RESET?FOR HOTPOINT FFA74.THANK YOU
Mar 11, 2011 | Hotpoint FFA70 Bottom Freezer Refrigerator
The temperature of the fridge has risen to 11/12 degrees & wont come down? Freezer works fine! Any answers please
Don't know the make and model of your fridge, but most fridges have only one evap coil located in the freezer. The fridgerator compartment is cooled by a fan to blow air from the coil back into the fridgerator section. Check that the fan is working and the vents in the fridgerator are not blocked. Often the problem might be that the defrost circuit is not functioning causing ice to build up on the evap coil thus block the air flow to the fridge. If you seen any ice build up in freezer or refrigerator that could be the problem. If that is the case, then you need to have the defrost circuit troubleshot, typical failures are the heater itself or the defrost timer if you have an older model. Hope this helps you.
Oct 08, 2010 | Refrigerators
Looking for cu. ft. info on fridge - hotpoint
It's in the model number.
ctx14<---- 14 cu ft.
Apr 24, 2009 | Refrigerators
Smell from fridge freezer even after thorough cleaning and disinfecting and defrosting Model Hotpoint RFA52. Temperature control OK
Put Charcole brickets in the refrigerator. Charcole works better than baking soda and usually take care of the smell.
Feb 20, 2009 | Hotpoint Freezers
Ffa70 hotpoint fridge freezer
Adjust the temperature control for the freezer to a normal setting. Fast freeze is only for when new products are put in that need to be frozen. This locks the system into a continuous run mode and could be responsible for the freezing condition in the refrigerator section. Check the temperatures with a thermometer as the sensor for the freezer temperature could be bad causing the light to come on.
May 18, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Refrigerators Logo
362 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
