Question about Insignia IS-LCDTV32 32 in. Television
26" Insignia LCD TV will not power up. Green Light Blinks 1x
26" Insignia LCD Tv will not power up. Green light comes on and blinks one time about every ten seconds or so. Is this a power supply issue or something else?
  • 2 more comments
  • whiteyball Mar 16, 2009
    Did you get this fixed?
  • Anonymous Mar 17, 2009
    Getting power to tv, but when I push the power button, it goes from red to blue, the screen flashes and will not come on
  • Mom2CrzyKids Apr 30, 2009
    My husband felt a "shock" when he tried to turn on the TV. Now it won't go on at all. The green light blinks, but nothing happens.
  • bassbegruven May 10, 2009
    The same situation happened with my husband last night, he went to shut of the tv and got shocked. The tv has been in the blinking green/red state ever since. Mom2CrzyKids -Did you guys figure out how to fix problem? Or Guest?
  • Insignia Master
  • 19,396 Answers
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on Apr 19, 2009
WE NEED TO SEE IF WE CAN FILE A COMPLAINT AGAINST THE TV BRAND. IF THERE IS A GLITCHE WE SHOULD NOT BE EXPECTED TO PAY FOR THESE REPAIRS. I CALLED INSIGNIA WHO DIRECTED ME TO BEST BUY. BEST BUY DIRECTED ME BACK TO INSIGNIA.INSIGNIA HAS TO BE WELL AWARE OF THIS ISSUE.
Posted on Nov 21, 2010
    President:
  • 814 Answers
Try calling this number for Insignia technical service help : 1-877-467-4289. The shocks are from static electricity discharges that can come from the person to the television or the television to the person. Static electricity will build up on the chassie of the television and discharge to a ground source. In this case the person touching the television, If you live in an area with lots of static electricity you should check the television before touching it by waving your hand around the chassie and see if it raises the hair on your arm or you feel a **** sensation as you move your hand around the television.If any fo these things occur you should use rubber gloves to turn off the controls. Do not touch the television for awhile and check it again for the same sensations, if they are gone then it is safe to touch the television. The problem with static discharges is that they overload the input circuits and can cause severe damage to the switchboard and other circuits inline with switches. The source of the electricity can be caused by bad wiring and loose gound connections in your hook-ups or the cable connections.This all should be tested and repaired. If you live in a house with deep carpeting, you are going to have a problem with this static electricity build-up as you move accross the carpet. Also it will affect the electronics in your house due to random discharges caused by something grounding the charge.Try wearing rubber soul shoes and slippers to isolate yourself from the electric build-up in such situations. It will be hard to determine the damage done by such a discharge so it is best to have the unit checked out by a service center. If you are under warranty try to have them service it for you. Warning they may not cover this kind of damage. So you amy want to tell them that you could not run on your televison after using it the last time.Giving no explanation for the problem. Let them find the problem for you.If not under warranty you will have to try to find a service center to look at the unit for you and see how much damage was done. You dcan find parts for this unit at this telephone number: 1-888-237-8289. You can all so use the Best Buy parts website and put in the model of you television and it will find all available parts and prices for you. Just google it. To be safe you should check all the wiring in you set-up for proper grounding and hopefully find the cause for this problem. Hope this helps you with you problem.
Posted on May 14, 2009
I have a sharp aquos tv model lc-32m400x. When i turn the power on via button at the back the green light comes on for about 10secs then turns to red and flashes about every 11/2 - 2secs. Any ideas.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 11, 2017 | Sharp Televison & Video
My tv cuts on but flashes red light 5 times and shuts off
http://electro-medical.blogspot.com/
Jan 10, 2017 | Televison & Video
I have a 60 inch sony tv that have a red flashing on the lower left side,no picture when I turn it on and there is ringing sound.
Jan 09, 2017 | Sony Televison & Video
Insignia NS-51P680A12 TV won't turn on. I have a blinking light that I am sure is a trouble code, but I can't find the codes anywhere online.
Jan 09, 2017 | Insignia Televison & Video
I have a Sony LCD Digital Color TV Model KDL-40S5100
try this --as you are wasting time and will eventually waste money---take it to a repair shop for a proper diagnosis and quote
Jan 08, 2017 | Sony Bravia KDL-40S51009 40 in. TV
I have a lg tv 60 inch tv ln5600 when powering on red stand by light blinks 3 time then no light pic or sound not backlight and no image when using flashlight treid replacing power board does same
Jan 08, 2017 | LG Televison & Video
My sony wega kf-50E200A tv keeps turning off. during each cycle the green light blinks 42 times and the tv comes on again for about 3 minutes and it happens all over again
More than likely the power supply is defective, but without testing and the repair manual that is just a guess, you make the decision to replace or repair the TV.
Jan 07, 2017 | Sony KF-50E200A TV Lamp with Housing
I have a HL67A750 Samsung no picture no sound blue light luminated on front 3 LEDs flashing
Jan 05, 2017 | Samsung Televison & Video
Sony bravia shuts off
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 30, 2014 | Televison & Video
No Video Or Sound - Stand By Light Flashes 5 Times
If the tv was made before December 2008, there is a capacitor settlement from a class action lawsuit by Samsung. Supposedly (at no charge) they will send a repairman to replace the capacitors.
Nov 27, 2013 | Televison & Video
Insignia IS-LCDTV32 32 in. Television Logo
2,125 people viewed this question
Top Insignia Televison & Video Experts
Dave Naylor
Dave Naylor
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
