Question about JVC RX-6042 Receiver
Overload flashs keeps going in too overload when turned on with nothing hooked up too it overload flashs on the front screen what ic needs to be replaced as there is 5 in it can i unplug each one too see if that s the one that is puting it in too the overload thanks
  • Rob McCutcheon
    Rob McCutcheon Feb 26, 2009
    yes i mean nothing hooked up no speakers or dvd players i just plug it in the wall and it turns on for a sec then gos too overload
  • Jim Bay May 11, 2010
    When you say nothing is hooked up to it do you mean no inputs (DVD players etc.) as well as no outputs (speakers)?
  • 336 Answers
There will be 6 amp circuit in your receiver. you can't unplug them one by one. with a multi-meter you may be able to find the shorted channel. (most JVC receivers use discrete circuits instead of an output IC) Check for shorted transistors attached to the heat sink. You will possibly find some open resistors also. Generally this is a job for a pro.
Posted on Feb 27, 2009
Replaced IC's and standby light flashes 4 times when powered up no screen
Thanks for your posting in FixYa.
I think the IC placed in it is not compatible. So you need to go for a repair shop to diagnose it thoroughly.
Dont forget to vote me. Have a Nice day.
Regards
ELLIN
Sep 24, 2008 | Samsung HC-P4752W 47" Rear Projection...
Every time turne on my tv the menu screen keeps blinking on and off and won't
dead capacitor or short transistor.....that;s why it always blink.
Aug 25, 2010 | Televison & Video
The screen won't turn on. The tv just clicks and
The power board ic coverter it dead.
U need to replace the power board.
U can go the web and buy this board changes
or get the tv repair man replace part and labor $575.
Aug 13, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Convergence on a 61
Have you replaced any of the resistors? RK42 3.3ohms /RK46 1.8 RK50 2.7 / RK54 1.5 / RK58 3.9 / RK62 2.2 ,ALSO remove front cover on TV looking at front of chassis is a button on board that has ICs/ press and hold for 3 secs with TV on ,then up should be convergence Pattern for alinement.
Jan 03, 2009 | Televison & Video
Receiver overload
Maybe the audio amplifier IC are in short circuit you need to replace him.
Aug 18, 2008 | Audio Players & Recorders
Overload
The audio amplifier IC of your device are damaged you gotta send to a repair center.
Jun 04, 2008 | JVC RX-6042 Receiver
Philips 46PP9302 46 in. Rear projection -
The power supply section is not working.
Common possibilities are:
- Convergences amps have failed overloading the supply
- High-voltage section (flyback transformer) has failed
(happens sooner or later, about 8 years typical))
- CRT tube has failed overloading the supply
- Power surge has popped the power input circuit.
(Fuse, rectifier diodes, turn-on relay etc)
- One of a hundred of electrolytic capacitors has failed short overloading the supply. They dry out with age, are cheap to replace, but hard to find which one it is.
- Or any of many other possibilities.
In short, you need a experianced tech to troubleshoot this.
Jan 22, 2008 | Philips 46PP9302 46" Rear Projection...
PDP 503 hde will not turn on
You need a new y-drive board and possibly a couple of buffer ic's replaced.The ic's definiately need to be replaced by a tv tech.
Oct 10, 2007 | Pioneer PureVision PDP-503HDE 50 in....
JVC RX-6042 Receiver Logo
605 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
