Question about Onkyo TX-SR605 Receiver
Is my txsr605 compatible with a dxrd511
Will my receiver work with this cd recorder?
  • 121 Answers
Yes it will. Connect it using the ins and outs of one of the "Tape" inputs and it should work very well.
Posted on Feb 26, 2009
Vinyl recording turntable
The Denon will act just like a standard tape recorder. It should have an audio in, for recording. If that socket is connected to the audio out of a tape socket on your receiver, the Denon will pick up the signals that are sent to your receiver from whatever source. All you have to do is follow the instructions for recording on the Denon then. If you have lost the user manual for it, it's free on-line.
Jun 22, 2017 | Denon CDR-W1500 2-Disc CD Recorder
I need to record some music on a CD and I was wondering what kind of CD I need to get to record music on. Will a CD-R work for this?
If you're using a consumer home CD-R recorder it will require you to use CDR-Music or CDR-Audio blank media. A PC will use any recordable CD.
Feb 14, 2011 | Audio Players & Recorders
How do I record a CD from an album on a turntable?
Assuming you have a functioning turntable either self-pre-amplified or through a component (such as a receiver or integrated amp) with an internal Phono preamplifier just connect the self-preamplified TT directly to the analog inputs on the CD Recorder; or connect the CD Recorder to the receiver / integrated amp as if it is an analog tape deck (which it functionally is in this case).
May 01, 2010 | KLH CDR2000 2-Disc CD Recorder
C71/DIN UNLOCK
The definiton in the manual suggests you are trying to record a digital bitstream that is either dead or incompatible with the recorder. Go analog.
What happens if you skip the receiver? Be advised that anything coming in digitally through a cable/satellite box may be muliti-channel and convertible by the player to its native 44.1 khz sampling rate.
Mar 31, 2010 | Sony RCD-W500C 5-Disc CD Recorder
I have PIONEER PDR 609 C.D RECORDER AND I HAVE
Not a very specific problem description...
Did it ever work for you? You don't say what DOES happen when you try.
Is the signal reaching the recorder? Is it visible on the display when you select MONITOR?
Are you using CD-R AUDIO or MUSIC blank media? It requires them, not CD-R data disks.
Tape Input should be straightforward if you don't want to route it through a receiver - L and R Out from the deck to L and R Input on the CDR.
Through a receiver: if it has capacity for two decks, connect the PDR-609 itself as a the second cassette deck, then select copy, duplicate or whatever passes for it on the receiver to copy cassettes.
Without specifics of your interconnected gear I can't really go much further.
Phono is a whole 'nuther thing. Traditional turntables require a phono preamp (generally present in old receivers) to boost the tiny signal generated by the stylus to a usable level for downstream electronics. Most modern AV receivers DO NOT have a phono preamp.
Jan 31, 2010 | Audio Players & Recorders
Kenwood KA-72B Stereo Receiver HELP NEEDED.
Why not plug the cassette directly into the CD recorder? Are they trying to achieve some eqalization change? If not, then this should work. It's all analog at tape level.
Mar 02, 2008 | Audio Players & Recorders
Want to connect the cd player to a turntable in place of a receiver
Right, so you have a turntable, which I assume was working fine before? It must have been connected to an amplifier or receiver. Keep this connection between your record deck & amp/receiver AS IT IS.
You want to make CDs from your vinyl? The best way to do this is to use the amp/receiver's tape/md/record loop. This "loop" sends the signal you are listening to from the amp to your CD recorder, and also allows you to switch to "tape" to monitor your recording during, or after recording, without deselecting your turntable (which would leave gaps in your recording). I will try to give you some useful information, but it all depends on your equipment & sockets, so if you're still lost after trying this, please let me know the make & model of your amp/receiver so I can check its functionality & give you some more helpful advice.
Your CD recorder has 2 pairs of phono (riaa) sockets, one to receive sound (input) and one to send sound (output) to & from your amp/receiver. You should connect the CD recorder's input (or record in) to the tape out (or record out) on the amp/receiver. And you should connect the CD recorder's output to the amp/receiver's tape in. Set your amp/receiver to phono (or however you usually have it set to listen to your turntable, and you should be set to record. When starting recording, I recommend that you use a CD-RW (a re-writable disc) so you can have a play around & get a good recording level that doesn't distort without wasting any discs.
Some amps/receivers don't have tape/md/record loops, in this case things can be a little more complicated & you might need to add a junction/switching box in order for it to work. I can help you with this too.
So best of luck & let me know how you get on.
Something that seems to come up a lot here & worth pointing out is that your dedicated AUDIO CD recorder will not accept data discs, only audio ones. That will be ones that say 80mins, rather than 700MB. These are a little more expensive but your recordings ought to be more reliable.
Jan 07, 2008 | Sony RCD-W500C 5-Disc CD Recorder
Recording
It will record any line level source (CD, MD, tape, tuner). You can only record vinyl records if you have a phono pre-amp.
The best way to use a CD recorder is to use the "tape loop" on your amp/receiver. Does your amp/receiver have a "tape in" and a "tape out"? If it does you should connect your CD recorder to these in/outputs. That way, whatever your amp or receiver is set to listen to, is what you'll be recording.
Shout if you need more help!
Sep 13, 2007 | Koss CDR200 2-Disc CD Recorder
Error message
Din unlock means 'digital input is unlocked' meaning it is not receiving a signal on the **digita**l input you have selected. ( eg optical or single co-axial digital from another cd player etc) Check your connections and re-select the source using the front panel until you select the one you want. What are you recording from?
Apr 16, 2007 | Teac CD-RW880 CD Player / Recorder
Onkyo TX-SR605 Receiver Logo
29 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
