Question about Car Audio & Video
Aftermarket Stereo connection
I am trying to install a kenwood kdc-135cr into my 1996 dodge stratus. I have connected the wire harness to the system and connected it to the wires in the car and I cannot get the stereo to work. I connected the wire harness using color matching, did I miss a step?
  • Michael Rouse
    Michael Rouse May 11, 2010
    Do you hear sound at all?
  • 4 Answers
On older cars the wiring loom is only 5 connected pins but the unit is 6 pin. i believe pre 2000 cars ,like yours, is like this. you will need to pull the yellow constant power and join it to the red main power pin then reconect the harness's
hope this helps
Posted on Apr 08, 2012
    Scholar:
  • 61 Answers
Hi there
if you matched all the wires from the harness to the kenwood deck and its not working don't worry you just missed the last step........(all wires attached that a colour coded connected)
simply turn your car on.........now on the front of the kenwood deck there is a SOURCE button with all units it could be a (S, SRC, Power) hold the source button down till your kenwood unit powers up ..........if your unit still doesn't work check the fuse on back of kenwood unit should be a 10a fuse (blue) if the fuse is fine put the unit back in dash..........now check the fuse panel on driver side dash with the door open you will see this panel pull it off (some describe the fuse panel as looking like an air vent but its not its a handle to open) now on the panel that you just pulled off there is a fuse diagram on the inside look at it find radio fuse it will be a (blue fuse) located in the top row of fuses check it if blown replace and unit should work.............if this doesn't solve the issue than its a (sneaky) fuse not to many people know about if you pop the hood of your car there is a black plastic panel located just below the battery pins and just above the driver head light (usually black box with yellow writing on it......in this there are mini fuses check all of them do not touch the black relays in there just the small tiny fuses the fuse you will look at should be yellow 20a (this fuse is closest to engine and comes after the abs relay if you look inside the lid you took off it will have fuse locations cant remember which one it is for sure but check them..........now see if your kenwood unit powers up if not the last option is to ground to the black wire from back of kenwood unit to metal frame.............this last part is also done if your unit does power on but your car lights don't work if this happens ground the kenwood unit to the frame of car and open up fuse panel on driver side dash replace the blown fuse for lights or radio (make sure the kenwood unit is grounded to the frame before replacing the fuse in dash panel............if this doesnt help you than i would assume the kenwood deck needs to be repaired by kenwood.......
good luck
hope i was able to help and sorry this list is so long
Posted on Mar 05, 2009
How to install a Kenwood kdc 138 in a 1992 Ford Escort LX?
if its anything like my 92 ranger you take the dash apart around the radio and the stereo should unscrew, in my ranger the new cd player went in without any extra harness as it was the same size as the stock, if not you can but harnesses to go where your old stereo did, to connect the speakers you can buy a ford wiring harness from walmart or any store with an audio department. these plug in to your vehicles wiring harness so you don't have to cut it out, after that you simply match colours from the wires of the new cd player to the wiring harness
Dec 25, 2013 | Kenwood DISCONTINUED - KDC-138 In-Dash CD...
Car stereo installion
I think you left the yellow wire from the kenwood disconnected
Mar 05, 2013 | Kenwood KDC-BT752HD CD receiver
I received a kenwood kdc-mp345u cd reciever can this be installed without a wire harness? I have 99 ford explorer with a mach factory system
Any time you upgrade your radio to an aftermarket you have to have the wire harness with it to connect to your dash.
Dec 25, 2010 | Car Audio & Video
I need to know how to install an aftermarket stereo in my 1995 vw golf....
go to your local halfords or the likes and you will need to get a wiring harness designed specifically for your car.you will need to tell them what kind of aftermarket stereo you have as the harnesses are all different.
Apr 28, 2010 | Kenwood KDC-MP228 CD Player
How to hook up a kdc-105 kenwood in a sunfire
There are 3 things you need to purchase for this install. 1) The factory spec install kit. 2) The factory spec additional wiring harness. 3) Antenna adapter.
Find the easied way to remove the plastic cowling around the radio and ac controls. Usually you can locate screws helping to retain the plastic dash parts. Be careful not to break the plastic dash by taking your time and looking over and over the part ofr connection hardware. Once you have located and removed all/if any screws, carefully pry out on the piece you are removing. There are often metal clips on the back of the piece that also help to retain the dash. Once that is removed, unbolt/unclip the factory stereo and slowly pull it out of the dash. Remove the factory harness from the backside of the factory stereo. DO NOT CUT THE HARNESS!! The wiring harness you have purchased is designed to plug and play into the factory harness. All you hae to do is color match the Kenwoods harness with the one you purchased. When wiring the two harnesses together use connectors **** a **** connectors, crimp connectors so forth and so on. If there is wiring you will not be using, take some electrical tape and tape the bare wire. We don't want a short. Once you are sure and have doubled checked that all the wiring is secure and matched, reverse the order of disassembly.
The plastic install kit should replace the factory radio size difference. Just remember to take the metal sleeve tha came with the kenwood and install it into the plastic install kit via the instructions provided. Slide the Aftermarket stereo into the sleeve you just installed. Then you are ready to make all the needed connections. Before you reassemble everything make sure to do a test run with your stereo. If all is well reassemble and jam on.
Sep 10, 2009 | 1999 Pontiac Sunfire
I am trying to connect a kenwood KDC-MP3035 to a 1997 Honda Passport but none of the wires match up, what do i do to make it work?
Hello oz101ez,
The wires have to be matched by function, not by color. Here is a link to the color code for the stock radio harness in your Passport. Connect whatever color wire your Kenwood manual says is for 12V + (usually yellow for most aftermarket receivers) to the "red/white" in your Passport. Connect the Kenwood accessory wire (usually red) to the brown/white wire in your passport. Just continue matching up each wire function and colors on both ends.
Best would be an aftermarket wiring harness vehicle specific for the Honda Passport/Isuzu Rodeo. The Metra 70-7712 seems to be the correct one for your vehicle. Installer.com probably has the largest selection of wiring harnesses available anywhere. They'll even match the vehicle harness to an aftermarket receiver harness and connect them using solder and heat-shrink insulation if you desire.
Most local car audio shops will carry some wiring harnesses. Also retailers like Best Buy may have them, albeit at much inflated prices. Online car audio retailers like www.crutchfield.com and www.soncielectronix.com have a good selection and their prices will probably be somewhere in between, lower than local but higher than Installer.com
Hope this helps.
Aug 05, 2009 | Kenwood Car Audio & Video
Im trying to find where i can gt a complete guide on how to install a car stereo from color coding the wires to installing a dash kit
  1. DISCONNECT THE NEGATIVE TERMINAL ON YOUR BATTERY!
  2. For an old stock stereo, you may have to remove the dash or certain parts of it to access the stereo. Do that by locating screws and bolts and taking them off. Make sure to keep them in a safe place.
  3. For an aftermarket stereo, insert DIN tools into each slot on the stereo behind the faceplate. Slide the whole stereo out.
  4. Disconnect the antenna wiring (The wire with the big metal tip)and the stereo head unit wiring (wire harness).
  5. Reconnect the antenna into your new stereo.
  6. Use **** connectors and wire crimps to connect the stock wire harness with a car specific one that is sold seperately. The color of the wires on each harnass should match up.
  7. Reconnect the negative terminal on your battery and see if it works.
  8. Slide the stereo back into the dash and remount the dash that you removed, including screws and bolts.
hope this will help you
Jun 05, 2009 | Kenwood KDC-MP208 Car CD/ MP3 Player
I am trying to install a Alpine CDE-7822S stereo into my 1996 Toyota T100. What do I need?
ok here is what you need to install>>>>you will need an install kit which is for the after market stereo to fit in the space your factory one was in also you will need the WIRE HARNESS for that year and model of vehicle...sometimes when you buy the insatll kit it will come with one....once you get that all you have to do is remove the stock radio and then wire the wires from harness to your wires on aftermarket radio and just plug the harness into the black picece behind dash
Jun 04, 2009 | Kenwood KDC-MP228 CD Player
What wiring harness do I need that works 1996 Toyota Tacoma
Hello shonk_patric,
You'll have to go to Kenwood or to the audio dealer where you purchased the receiver if you do not have the harness that plugs into the back of the radio.
One vehicle specific aftermarket harness for a '96 Tacoma is the Metra 70-1761 available here at Crutchfield.
Hope this helps.
May 20, 2009 | Kenwood KDC-MP228 CD Player
Car Audio & Video Logo
208 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
