F2 indicates that temperature inside the oven has gotten to high. The sensor should read around 1000 ohms at room temperature if not it is bad. Here is the part to order.
SOURCE: My oven keeps beeping F2
checkout this link...
http://forum.doityourself.com/showthread.php?t=75624
SOURCE: ge gas oven/ranger xl44
The F2 is the code for the board seeing a temp higher than 600 degrees. It could be one of two things. The temp sensor is out of range, extreme high resistance. If you ohm it out it should read approx 1100 ohms at room temp. The other would be a welded bake relay on the board itself. Check the temp sensor first. If you are getting the F2 in the cleaning cycle, check the temp sensor, welded clean cycle contacts on the board or both contacts on the lock switch are closed at the same time. This is for the model posted JGBP90.
SOURCE: Ge oven codes
F2 means your oven temp got too high. At least, that's what the control boards thinks. More than likely you have a bad oven sensor or bad wire to it or a bad connection somewhere between the board and sensor.
SOURCE: baking cake and F2 signal
F-2 on your range indicates a bad temperature sensor. Please replace your temperature sensor in the oven.
SOURCE: why is the electric stove JCBP65SKS beeping F2
look on google and you will find the meaning of the codes for your stove.
