Question about Mx Max Cn890s Coil Nailer O`ring Parts Kit
Max 890s coil nailer does not advance nails when operated.
The gun has been serviced by two different tool repair shops but never fixed.It will fire a nail,if you pull the trigger one shot at a time,about every 4th shot.If you just hold the trigger it will fire the first shot but not advance the coil of nails any further.Any suggestions before I toss it away?
  • 67 Answers
Make sure you have at least 100 psi available and I would pretty much drown the sliders and other moving parts in something like Marvel Mystery Oil.
Posted on Feb 26, 2009
Nailer wont advance the nails then it shoots blank
Try ez test to check for proper operation. Remove nails and air supply, point nose of gun up then down again. The driver should not move from the top of cylinder position. If driver is moving up then down replace the driver oring. If driver oring seems ok then connect air supply and bump fire the nailer without nails against soft wood and door open so that you can see the driver and feeder moving. Bump fire the gun and make sure that the driver is moving all the way back up to top of cylinder and the feeder is moving rapidly back and forward. If movement seems ok then hold the nose down on soft wood and depress and hold the trigger. This will fire the gun but driver will stay at the bottom position and not return until you release the trigger or lift the gun. When holding the gun with the driver down position, no air should leak out the top or bottom of the gun. If air leaks out bottom, replace lower bumper, if air leaks out the top replace the upper bumper. Good luck
Mar 19, 2015 | Porter Cable Coil Roofing Nailer
Looking for the nearest repair shop for paslode nail gun in Northren Va
Have all the nails been cleared out of the tool where they were jammed? If not take the fuel cell out of the tool, and remove the battery before working on it. If still persists come back to this website for further help.
Sep 19, 2014 | Omega Paslode 901000 Impulse Cordless...
New nailer double firing and jaming
Some trigger valves (tva6) are sensitive (defective?) however there are some things you can try to change how the gun acts. I have noticed that the brand of oil has an effect on the orings. Some brands will swell the orings, I like Paslode nail gun oil. Do not wash the gun with gasoline or wd40. Use diesel. Change the nail depth setting one position. Lowering the air pressure will make a difference. I find that most operators use too much pressure. A stronger safety spring under the trigger will separate the trigger and firing pin quicker. Finally you could use single fire trigger. Good luck
Jan 16, 2014 | Stanley Bostitch Rn461 Gun Coil Roofing...
My hitachi nail gun NV 50AA will fire, but won't advance the nails on a regular basis
NV50 nailer is very difficult to repair due to complicated feeder /feeder spring / feeder retainer pin design. You most likely need to replace the orings on the feeder piston. Problem is that you must remove the feed pin/ spring to get the piston out. If you are going to attempt to replace the orings, study how the pin is installed otherwise you will make it worse. Order new springs (2 different springs ) and install them when you are going back together. Good luck
Mar 03, 2013 | Tools & Hardware - Others
Nail gun problem
This is a bottom fire tool. (NV83A2) You need to hold the trigger down and then as you place the nailer to the wood the safety will depress and it will fire once. This is usually done in one, swift action. If you do this in the opposite way by placing the tool to the wood and then pulling the trigger they often will double fire.
Jul 05, 2012 | Nailers Hitachi Nv83a2 3 14" Coil Framing...
My makita an451 roof nailer keeps shooting 2 nails I've tried 2 different brands of nails
Nailers that use strips of nails (one nail directly behind the other) will sometimes drive two nails at once and is caused by damage to the driver. The nails are so close together that the driver will hit the first and part of the second nail head. Coil nailers, as your an451, use nails seperated by welded wire making it very difficult the the driver to hit the second nail. Usually when a coil nailer shoots two nails, it is acutally the trigger valve that acutates twice (two very rapid fires). Two very rapid fires is caused by faulty trigger valve. I have seen a roofing coil nailer fire one nail and a second nail drops out of the gun. Caused by weak / malfunction of nail feeder or wire used to weld nails together is too thick.
Sep 17, 2011 | Makita Roofing Coil Nailer AN451
I only shoot one nail and the rest is air. i need to push up the magazine to advance another one. This is my first finish nailer, is there something i'm doing wrong or is it the gun. I just purchased this...
Possibly, I would make sure that you are using the right guage nails first with the proper collation. You can go to Dewaltservicenet.com and download a breakdown for the tool and also a users manual.
Jul 19, 2010 | Dewalt D51256K 16 gauge finish nailer kit
Senco finish nailer not firing nails
firing pin called the driver is probably broken or needs new seals max air pressure 125 psi senco sells repair kits
May 13, 2009 | Tools & Hardware - Others
Feeding nails
Your nailer shares design features with Milwaukee and Ridgid. All three brands experience the same issue. Lets go thru a series of simple tests to determine the problem. First and most simple test, manually load the nails and fire the gun untill miss-fire. Upon mis-fire disconnect air, open latch and check if the driver is all the way up into the cylinder or is partially down blocking next nail. If driver is down blocking next nail, replace the driver oring and retest. If driver is up all the way, remove nails, reconnect airline, leave latch open and fire gun against rubber (old tire or coiled up waterhose/airhose) this time holding the gun down and keeping the trigger depressed. In this position, the driver will remain down and feeder will remain retracted. With feeder retracted and screwdriver in hand carefully check the spring tension on the feeder (should be rather firm tension on spring and the feeder must retract with good force). If no tension or weak, replace feed spring. When you finally release the trigger, the driver will retract and the feeder should return with good force. If feeder does not return with force, replace orings and spring behind feed piston. If all tests are ok, remove head, check lower bumper in gun for cracks or missing pieces. Replace as necessary. Lube all orings with silicone lube available at Lowes in the plumbing department. (Danco brand) Good luck on your repair and email your questions.
May 06, 2009 | Porter Cable Cable RN175AR Reconditioned...
Nail Guns Safety problem
Professional-grade varieties are automatic, and fire a nail directly upon pulling the trigger. A semi-automatic nail gun is more appropriate for beginners, since it requires a two step process: pull the trigger and then tap the barrel against the wood. This safety feature protects the user from accidentally firing a nail gun and injuring himself or others.
Aug 27, 2008 | Arrow No.ETF50PBN Extra Heavy Duty...
Mx Max Cn890s Coil Nailer O`ring Parts Kit Logo
199 people viewed this question
Top Mx Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Mx Air Tool and Compressor Expert? Answer questions, earn points and help others
