Question about Dishwashers
Whirlpool dishwasher stops midcycle and control panel goes blank
I can't figure out where to find the model number on my dishwasher. It is a whirlpool and it was in the brand new house we bought in Aug '08!
The dishwasher starts fine and then it will just shut down. The lights won't shine at all on the front. Then when you open the door there is water standing in the bottom. When you shut the door the green light start/resume starts flashing again. You start it again and then it does the whole thing all over again.....please help. I hate the thought of replacing it. Thanks!
  • 6 more comments
  • kiwilder Feb 26, 2009
    I found it!!! DU915PWPBO
    When I leave it run, it shuts down, we never get full cycle.....
    Any idea on how much that will cost? Is this something that may be covered by the warranty on the electronic control system?
    How do I check the door switches?
    Are you talking about the circuit board....this is all new to me, so I need all the help you can give me......is this what I am wanting
    http://www.partstap.com/partsearch/model... the Cntrl-elec for $69.50? Sorry, this is all greek to me.
    Sorry - I meant we bought it in Aug of 05.....My son was interrupting and I obviously messed that up! We have been in our new home for 3years +
  • Nikki Nicholson May 11, 2010
    Model number is located on the tank where the door fits into. It is a label that is approx. 2 inches long and an inch wide on either the right or left hand side. You may have a blocked drain, or the control panel that is failing. A model number will definelty help diagnose.
  • albert getty
    albert getty May 11, 2010
    inside door or on the side is model number if you leave it full cycle does it do any thing else?
  • 50 Answers
I would check you door switches.
Posted on Feb 26, 2009
  • Nikki Nicholson Feb 26, 2009
    I missed you comment that it was in your new house. I would call Whirlpool for service as it will be under warranty if the unit was installed between Mar 08 and now. To check door switches I use a multimeter and check for continuity and reaction.
  • 547 Answers
And the controls dont advance? to the end of cycle?
  • 2 more comments
  • albert getty
    albert getty Feb 26, 2009
    try replaceing controls
  • albert getty
    it should by under warrinty but you can find cost here http://www.partstap.com/ thank you for useing fixya please rate me
  • albert getty
    yes thank you for useing fixya please rate me please use warrinty first
  • albert getty
    some part's are under extended warrinty you would have to look at your owners manuel thank you for useing fixya please rate me
I have a Whirlpool Quiet Partner Two dishwasher. The rinse only light & quick wash light constantly blink and I can't run it, none of the buttons will work. Is there a way I can reset my dishwasher?
This generally means the control panel is no longer working and must be replaced. That's the entire plastic assembly at the top of the door, in which the buttons reside. Disconnect power first, remove screws inside the door which hold the panel in place. Unplug power connectors, remove circuit board control board. Find dishwasher model number and search parts for that model. The part is pricey, more than $100 last time I replaced mine. Install control board into new panel, make power connection. Reassemble door. Good to go.
Oct 03, 2015 | Whirlpool Dishwashers
Whirlpool du1055xtvq dishwasher stops starts frequently during wash cycle
This model can get broken solder joints in the control panel which causes it to stop randomly. It is a simple fix if you can use a soldering iron
Mar 10, 2012 | Whirlpool Dishwashers
Dishwasher stopped midcycle and the fuse is not tripped
Some dishwashers work the wire nuts loose in the connection box. Especially those that
are wired to aluminum wiring (these require the purple "IDEAL" brand wire nuts).
Make sure to secure power to unit before servicing.
Mar 06, 2011 | Whirlpool Gold GU2475XTV Builtin...
No power going to front panel on whirlpool dishwasher gu2455xtsso
If the model number you listed this question under is correct, there is a thermal fuse (also known as a bi-metal) located inside the control panel of the dishwasher. The part number for the thermal fuse replacement is W10258275.
If you type in your model number you can utilize the exploded view parts diagrams at pcappliancerepair.com, appliancepartspros.com or searspartdirect.com to assist you in locating the part. The fuse is listed as item 6 under the "Control Panel Parts" section.
To replace the fuse, follow these steps:
1. Make sure the dishwasher is unplugged or the breaker is turned off.
2. Open the door and remove only the top screws directly behind the control panel.
3. Remove the protective cover from back of the control panel to expose the main control board.
The thermal fuse should be mounted to the control board. If you remove it and take a resistance check, it should read close to 0 ohms, if good. If bad, replace as necessary.
If you have any questions about this repair, or require additional assistance, please let me know. I hope this helps you.
Apr 23, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Quiet Partner II not washing or sensing.
I have a whirlpool quiet partner II and for some reason it does not drain the water out any more and I cannot figure out why....people say that it is the filter but that is unbelievably hard to get to and I cannot find any instructions online or paper work that tells how to break it down. If anyone has any insight please let me know
Nov 16, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
1,010 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
