Question about Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500
I have started my honda civic 1994 and the wheel drive is geeting hard and not moving at all,also estarted leaking like back all the oil from the power oil stering reserv. please help me.
  • 398 Answers
Need anew power steering pump
Posted on Feb 27, 2009
Why won't my Honda civic start. 1.6 VTEC coupe 1994 dx . oil light came on. Won't start. Turns over.
That a disaster oil light on that mean no oil pressure when you still drive with the light on the engine can seize up on you first check your oil civic use lots of oil you would not be the first one that hapen saw that dozen of time sorry about good luck pierre
Mar 09, 2015 | Honda Cars & Trucks
Why does my 1994 honda civic waste so much oil. i pour oil every other day but i have no leaks
My friend;
Try this;
1. You may use bad grade {brand} oil.
2. You could be driving fast {speeding up}.
3. You may have bad cylinder / piston ring, which causing oil to leaks inside the cylinder & burn it up through exhaust.
4. Check the quality of your oil: your car must or should use 20W-50 viscosity .
5. Check your radiator it should NOT has oil mixed with its water.
Try it, & PLZ; let me know if I add any benefits to you.
I hope I add some thing valuable to you.
Regards;
MAR;
soer2@yahoo.com
Nov 09, 2009 | 1994 Honda Civic
Oil leak from the head gasket on my 1993 honda civic
dear friend-i do not think the oil comes from the hear gasket but rather from the distributor,make sure that the oil is not running down onto the head gasket and the shows as a oil leak from the gasket.
Nov 09, 2009 | 1993 Honda Civic 4 Door
1994 honda civic cx
yea, you are burning oil. piston rings, or an oil leak from some where else
Aug 18, 2009 | 1994 Honda Civic
94 Honda Civic DX idles low/rough at a stop
Check for split hose's around the inlet manifold.Sounds like a vacuum leak.
Hope this helps.
Jun 28, 2009 | 1994 Honda Civic
Automatic transmission does not move
It sounds like the filter is plugged, but the only way to service the filter on honda is to remove the transmission and take it apart. I had a honda in my shop that the owner didn't want to spend that much. So I drained the transmission. Went through the drain hole and drilled a hole in the filter. Then I put an inline filter in the cooler line. He had the exact same problem you have. That was 4 years ago and he is still driving it.
Jun 11, 2009 | 1994 Honda Civic
Radiator losing water
i suspect the water pump..
May 08, 2009 | 1994 Honda Civic
Honda civic hard start when its hot
you might have leaking valve seats they are expensive to replace, what happens is while your driving they let some oil go past them resulting in oil being dripped into the cylinderwhere the gasoline is supposed to go ..its hard to start because it needs to burn off the oil first.
Oct 27, 2008 | 2003 Acura RSX
Fuel Consumption
i have a 97 1.4 civic and i get about 280 miles from a 38 litre tank.has the car been serviced?is the oil level low?jack the car up and make sure all wheels turn freely,if not then the brakes are binding and the car has to pull harder to move,using more fuel.are your tyre pressures low?do you drive it hard?
Sep 15, 2008 | 1994 Honda Civic
Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500 Logo
66 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Dwain Pippen
Roland W VanLue
Roland W VanLue
Are you a Poulan Garden Expert? Answer questions, earn points and help others
