Question about Frigidaire 24 in. FDB635RF Built-in Dishwasher
Runs forever! even on Normal !!
Frigidaire model FDB510LC53,less than 2 yrs old.
It seems on any wash cycle, it will take 4-8hrs to complete the cycle.
We timed it today on "Normal" cycle...start time 9;45AM...Finished at 2:15pm ( 4 1/2 hrs.) is this normal///the "Heavy Duty" cycle will go nearly 8hrs.
Any hints ( othrt than total replacement??
JRW I have the same problem as jmjh2001's post. We have had this model for 5 years, and it just happened. I started it at 9 p.m. and my wife woke me up at 4 a.m. telling me the dishwasher was still running. We also got the Heating delay light. I am planning on replacing the Timer, as I believe the timer is causing the machine to run all this time.
  • perdue44 Feb 27, 2009
    Chuchserv, thanks for the info,,,,,, so as to understand, with the heating element not heating properly - that will halt the timer?
  • 50 Answers
Check to make sure you heating element has not failed. Dishwashers of today heat the water periodically through out the cycle and if the element has failed. The heating delay light is the indicator that tells you that it is trying to heat the water.
Posted on Feb 26, 2009
My 10+ yrs old Frigidaire gallery # GLTF1240AS front-loader drum won't agitate/spin
Check and see if the drive belt broke? On mechanical agitators using gears, a solenoid may fail and drive motor won't function.
Dec 23, 2013 | Frigidaire Washing Machines
Frigidaire dishwasher model fdb1500fls2
Sounds like the capacitor on the motor is bad,
May 26, 2013 | Dishwashers
The dishwasher runs for 1 1/2 hours on the wash cycle.
This may sound strange but that is a normal cycle time for today's dishwashers. They use much less water and the water is 'recycled' within the filtration system in the pump.
By reusing and filtering this water they save on heating energy and water consumption. The motors are not as powerful so they use less power even when running longer. Many machines will alternate the wash between the upper and lower arms, this type uses much less water and energy but again the trade off is long cycle times.
If you were to select a heavy or pots and pan cycle with hi temperature wash and a sani rinse your times can be up to 4 hours in some machines today.
The reason behind these savings are mostly due to the energy standards that the appliance manufactures have to abide by today.
I know this may not have been what you wanted to hear but it is how they work today.
May 11, 2010 | KitchenAid 24 in. KUDP02CR Built-in...
My dishwasher is seeming to stay on the wash cycle. How long is a normal wash cycle?
Dishwashers today use a lot less water and energy to do this they filter the water like crazy this makes the wash times go way up, the motor used today uses only a little power so a long cycle does not cost much.
They average wash time for a new machine is 90 - 120 minutes. Some high efficiency units can run 4 hours per cycle.
Apr 24, 2010 | Kenmore Dishwashers
Frigidaire FDB1050REM2 Stainless steel
They weren't lyin', with the new improved energy effeciency and cleaning units they using more "soaking" times to losen food particles to use less water and clean better. And that they deffinitly do versus old units and they save more energy by doing this also. On some makes and models theywill have cycles that still use less time but also will then use some more water during this cycle. My SEARS store "blue crew" did research and found out this cycle for me.
May 22, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Inherited diplomat dishwasher with my house
Today's dishwashers use less water and less electricity so the manufacturers have had to increase wash times to get good results. One hour is about normal for the "eco" cycle since it's always "sensing" the water turbidity (soil in the wash water) and water temperature, and making adjustments as necessary.
Your shortest wash cycle would be "delicate" but it might not give you the best results.
Mar 05, 2009 | Dishwashers
The most obvious failure would be the mechanical timer that is behind / part of the knob used to select the cycle.
But, you may want to inspect the heating element in the sump area -- some dishwashers will wait (and wait) for the water temp to come up high.
Good Luck!
Feb 25, 2009 | Frigidaire 24 in. FDB510LC Free-standing...
Frigidaire 24 in. FDB635RF Built-in Dishwasher Logo
601 people viewed this question
Top Frigidaire Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
